History_SE30_Dude Posted March 25 Report Share Posted March 25 Has anyone done this I haven't been able to find any instructions other than it is optware. My thought was to have it encapsulate IP packets in Appletalk and for those machines that can only connect via Localtalk would have access to the internet. For example possibly play some Bolo on my Duo 2300. Quote Link to post Share on other sites
68kMLA Supporter mactjaap Posted March 26 68kMLA Supporter Report Share Posted March 26 Better have a look at http://www.macip.net and have a look at an easy solution. Quote Link to post Share on other sites
Cory5412 Posted March 26 Report Share Posted March 26 Can DD-WRT run Netatalk? That might have been for use as a file server, lots of routers DDWRT supports have USB ports that were originally meant for file sharing. EDIT: it seems like most people wanted it for Time Machine purposes, as an alternative to connecting a disk directly to their mac and as an alternative to buying a Time Capsule or Airport. From an ultra-quick Google though, this works poorly and probably using regular linux/bsd + netatalk or a purpose-built NAS or any of the other vintage-friendly solutions is probably a better plan. In terms of a MacIP bridge for machines w/o ethernet, the macip VM or pi image is probably the way to go-- at least short of having another Mac to use as such a gateway. Quote Link to post Share on other sites
History_SE30_Dude Posted March 27 Author Report Share Posted March 27 On 3/26/2021 at 2:45 PM, mactjaap said: Better have a look at http://www.macip.net and have a look at an easy solution. Thanks, I’ll give it a go. @Cory5412 you’re right thanks I had some wires crossed in my head. Quote Link to post Share on other sites
History_SE30_Dude Posted April 5 Author Report Share Posted April 5 @mactjaap @Cory5412 thank you for the help. Yeah got a Duo 2300c system 9.1, and a Portable with system 7.1 both onto the web to various degree last week. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
