Jump to content
Reverse Engineering the Macintosh SE PCB & Custom Chips for 1:1 reproduction
Recommended Posts
  • Replies 1k
  • Created
  • Last Reply
Top Posters In This Topic
Definitely +1 for AbeBooks, looked there first yesterday and search reported the title was sold out. Didn't know Amazon owned them or I'd have been more hesitant to use them in the past. Finally got past my hatred of Amazon, now it's just skin-crawly when I buy from there.
This time a couple of Amazon prices are lower:
https://www.amazon.com/gp/offer-listing/0201192551/ref=tmm_pap_used_olp_0?ie=UTF8&condition=used
Link to post
Share on other sites
  • 68kMLA Supporter
I'm thinking my analogue board is potentially in need of repair as well - seeing as the video is very off centre as well as being wonky...voltages are something i'll have to measure....if only i had an extension cable to be able to test this flat on a bench! Anyone make one at all?
Link to post
  • 68kMLA Supporter
Knocked up an adaptor for the SE ROM's - i have a funny feeling mine aren't making proper contact in the sockets, the legs, even cleaned, are tarnished...the ones from the spare board i have...well i tried removing them and the legs stayed in the sockets, so i now have a load of icosaoctaplegic Mask ROM's :D
I have 10 prototype boards in a panel with ENIG and V-Scored edges on the way from PCBWay (Making use of the $100 or so commission i earned from the Amiga stuff i've done in the past) so if anyone wants to test these, i have 9 available.
Link to post
Losing legs from a ROM, ouch.  The price of those DIP64 IC test clips just keeps going up and up, but they're at least out there...
https://www.digikey.com/en/products/detail/3m/923739-64/12091
Another note, I also looked deeper into the Unitron's logic equations and tried coding them up in Verilog mainly to run a simulation that I could compare the BBU's waveforms with.  Indeed this was helpful in answering a few last questions, though it did feel a bit like a "distraction" from the BBU.  One interesting note, though, I found the Unitron's C3.7M clock is generated by inserting two C16M cycle waits every eight C4M cycles, rather than one C16M cycle wait every four C4M cycles.  It could be that the original Macintosh actually used this behavior, but of course there's no need to copy the inferior approach for the BBU.
Edited by quorten
Fix minor error
Link to post
  • 68kMLA Supporter
If you want a spare "stock" set I can drop some in the post to you.
Link to post
  • 68kMLA Supporter
OK - work has been manic (office move of the whole IT store and comms room to new building) and i've yet to have enough time (or space) to sit down and solder anything. I have, however, come up with a few little bits like the ROM adapter, and now, i have this - behold, the PLCC84 breakout adapter! Desolder the BBU socket, solder this in its place, then solder a new socket to that board - voila, signal breakout!
@quorten would this be of use to you in your BBU reverse engineering?
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
