Kai Robinson Posted September 2, 2020 Author Report Share Posted September 2, 2020 AAAAHA! OK, so that should solve the problem. Quote Link to post Share on other sites
techknight Posted September 2, 2020 Report Share Posted September 2, 2020 You might be able to just temporarily drill all those out. Quote Link to post Share on other sites
Bolle Posted September 2, 2020 Report Share Posted September 2, 2020 Was just going to say that... I was staring at VCC and GND layers and saw nothing but it jumped right at me when I activated the outline Layer. Quote Link to post Share on other sites
techknight Posted September 2, 2020 Report Share Posted September 2, 2020 8 hours ago, Bolle said: Was just going to say that... I was staring at VCC and GND layers and saw nothing but it jumped right at me when I activated the outline Layer. Yea, need to make each of those holes a part of the circuit and connected to ground, so the layout engine knows what to do with them, and can do its thing. Quote Link to post Share on other sites
quorten Posted September 2, 2020 Report Share Posted September 2, 2020 I'm kind of wondering about the mention of ground connection, the Macintosh SE/30 schematic does say that hot and cold ground are connected together, is this also the same with the Macintosh SE or are they kept separate? I've assumed that the wire to the chassis connected it to protective ground on the AC plug and this was kept separate from the PSU common ground, but I haven't looked carefully to verify it. Quote Link to post Share on other sites
techknight Posted September 2, 2020 Report Share Posted September 2, 2020 There is no such thing as hot or cold ground unless your dealing with a power supply. with a logic board, you have analog and digital grounds. Or, Filtered/Unfiltered grounds. Quote Link to post Share on other sites
Kai Robinson Posted September 2, 2020 Author Report Share Posted September 2, 2020 Rev 1.4c now in production - I know i can drill these boards, but i'd need to buy a drill for that...and to be honest, it's part of the process of prototyping - it's less expensive to spin up a batch of 10 more boards, than to get a dremel and whatnot - and probably just as quick to order. Thanks to @techknight and @Bolle for helping with the Gerber evaluation - fingers crossed 3rd time is the charm! To the people waiting on a board - i thankfully hadn't sent out a faulty one yet. I've received some donations in the past few weeks to help with the costs of the project, just need to go and get more passives, now! Quote Link to post Share on other sites
Phipli Posted September 3, 2020 Report Share Posted September 3, 2020 Daft question... I'm interested down the line in a working board, but would you sell me a spare faulty one (or two) to hang an SE motherboard on the wall? I'm UK based. Assuming you are? Awesome work by the way. Looking forward to seeing the end result. Quote Link to post Share on other sites
buserror Posted September 3, 2020 Report Share Posted September 3, 2020 Actually I'd like to do the same, ie buy a dead board to support this awesome project :-) Also in the UK, PM if if suitable. Quote Link to post Share on other sites
fehervaria Posted September 3, 2020 Report Share Posted September 3, 2020 @Kai Robinson It is very amazing project! I love to see how you go through on each reversengineer's problems and do beautifull job at the end. Do you plan to rebuild the Macintosh SE "only" at Logic Board level, or are you planning for the Analog Board too? Or the Magical Miniscribe 8425SA harddisk, what was the original for that SEs? Quote Link to post Share on other sites
Kai Robinson Posted September 3, 2020 Author Report Share Posted September 3, 2020 @Phipli & @buserror - You're welcome to a faulty one for £10 + the postage - DM me with your addresses @fehervaria - Analogue board is doable, much easier than the logic board, just need a dead one sent to me - they're single sided boards, from what i can see. I do have the SE/30 boards arriving, and the Mac Classic (which is a cost reduced SE) boards, so they're in the pipeline, but i can knock out the Analogue board over a weekend, probably, if someone has a dead one! Quote Link to post Share on other sites
buserror Posted September 3, 2020 Report Share Posted September 3, 2020 Right, I've added a bit of sponsorship to @Kai Robinson for my wall-board, if anyone else feel like helping, remember you would be hard pressed to find something you would hang on your wall for less than £30 Also, on a side topic regarding the attiny85 RTC chip, I'm the author of https://github.com/buserror/simavr - I can simulate pretty much any AVR firmware with simulated external input before you have to flash it and put it on a board, if anyone needs a bit on support getting that working, feel free to ping me. Quote Link to post Share on other sites
Phipli Posted September 3, 2020 Report Share Posted September 3, 2020 (edited) Just a thought... I know Compact Macs are very popular atm, and the SE/30 is a worthwhile follow up to the best computer ever made (the SE)... but it might be good to do a IIcx or something rather than every compact Mac first. Consider that it is easier to build up a new desktop as you can use an ATX supply and an LCD screen! Also not a huge difference between the SE/30 and IIcx designs. Note this isn't specifically a request / demand, I'm over the moon to see this project happening as I have an SE. Edited September 3, 2020 by Phipli Quote Link to post Share on other sites
Kai Robinson Posted September 3, 2020 Author Report Share Posted September 3, 2020 @buserror - welcome to have a crack at the ATTiny85 RTC code, the more we can replace with off the shelf, the better! Still want to try and get the GLU logic chip and the ADB done - the ADB might be simpler....is there any way of reading out the ROM contents of the chip? It's a PIC16CR54. Quote Link to post Share on other sites
quorten Posted September 3, 2020 Report Share Posted September 3, 2020 @buserror Nice -- that would help sidestep one issue in testing. Namely, I say this is only for the sake I am new to AVR/Arduino and I need to figure out what is the problem with the currently written I/O routines using Arduino-specific libraries, otherwise the correct code to program the chip with comes pretty much straight out of existing Macintosh emulators, Mnii vMac I was looking at. I did fix a few errors in the current code... but probably I'm just going to rewrite it from scratch using emulator source code as a reference to get a clean, bug-free implementation. Quote Link to post Share on other sites
Kai Robinson Posted September 3, 2020 Author Report Share Posted September 3, 2020 (edited) Well, if people send me dead logic boards i can have a go Edited September 3, 2020 by Kai Robinson Quote Link to post Share on other sites
cheesestraws Posted September 3, 2020 Report Share Posted September 3, 2020 8 hours ago, Kai Robinson said: Well, if peope send me dead logic boards i can have a go Absolutely just misread this as 'if the pope sends me dead logic boards' and for a moment I thought we had some unexpected company in our hobby, but apparently not... Quote Link to post Share on other sites
Kai Robinson Posted September 3, 2020 Author Report Share Posted September 3, 2020 Haha - corrected the spelling now! XD Quote Link to post Share on other sites
techknight Posted September 3, 2020 Report Share Posted September 3, 2020 Well as soon as you get onto the SE/30 project, im ready to jump in for prototyping. I have a few battery kaboominated SE/30 boards. Quote Link to post Share on other sites
quorten Posted September 4, 2020 Report Share Posted September 4, 2020 Alright... I've cleaned through the existing source code for the replacement RTC and should have a feature-complete version now, with no fundamental design flaws like the previous versions had. However, it's not tested yet, so there could be a few bugs. Anyone interested to code review this or even try a spin with physical hardware? The source code compiles with avr-gcc (and avr-libc) and it no longer has any dependencies on Arduino code libraries. There are two versions you can compile, the 20-byte PRAM chip and the 256-byte XPRAM chip, 256-byte XPRAM is the default. https://github.com/quorten/macsehw/blob/1e91a8b426ecac3230fe9b218b4f3b2720658943/firmware/rtc/MacRTC.cpp Quote Link to post Share on other sites
buserror Posted September 5, 2020 Report Share Posted September 5, 2020 14 hours ago, quorten said: Alright... I've cleaned through the existing source code for the replacement RTC and should have a feature-complete version now, with no fundamental design flaws like the previous versions had. However, it's not tested yet, so there could be a few bugs. Anyone interested to code review this or even try a spin with physical hardware? The source code compiles with avr-gcc (and avr-libc) and it no longer has any dependencies on Arduino code libraries. There are two versions you can compile, the 20-byte PRAM chip and the 256-byte XPRAM chip, 256-byte XPRAM is the default. https://github.com/quorten/macsehw/blob/1e91a8b426ecac3230fe9b218b4f3b2720658943/firmware/rtc/MacRTC.cpp Couple of question here: is there a pullup resistor on the board for the data line? If so, you probably should not /drive/ the pin as an output, but configure it as open drain, this is pretty much to ensure both end are not driving the pin at the same time (which would damage both drivers). Also, for the clock pin, I notice it is also INT0 as well as PCINT2 on the AVR, so you could use an interrupt vector for that, and put the AVR to sleep in between. Rigth now the AVR runs full speed all the time to resample the clock signal. /Ideally/ you would put the CPU to sleep /all the time/ and let the clock pin interrupt wake you up, process the current clock cycle, then go right back to (deep) sleep. With that the CPU will use power just when it's driven, and for toggling the RTC pin on a separate timer handler... Quote Link to post Share on other sites
Kai Robinson Posted September 5, 2020 Author Report Share Posted September 5, 2020 I used the test function on sprint to map the RTC chip connections - they all lead to the 65C22. Quote Link to post Share on other sites
Kai Robinson Posted September 5, 2020 Author Report Share Posted September 5, 2020 Quote Link to post Share on other sites
quorten Posted September 5, 2020 Report Share Posted September 5, 2020 Yeah, I thought about using edge interrupts for the serial clock pin, that would make the code more elegant too (and more similar to Mini vMac). Now I'm getting around to testing this design under simulation, and I found that the clock divider wasn't actually configured as it claimed to be... TCCR0B should be 0b011, not 0b111. However, even so when I configure it like that, looks like I have the annoying problem that the one second pulse is consistently stretched a little longer than one second. I'm guessing this must have to do with something like interrupt processing slowing down the timer counter advance or something. Quote Link to post Share on other sites
buserror Posted September 5, 2020 Report Share Posted September 5, 2020 @Kai Robinson I couldn't find the RTC chip on the schematic. Do you think the 65C22 has internal pullups? @quorten I noticed you enable/disable interrupt in various places in the firmware, in some place I don't think it's actually necessary to do so (when reconfiguring ports for example) -- it's possible that the 'stretching' that occurs is because the interrupt is delayed by one of these blocks. You could see if it's the case by tracing the interupt generation vs the interrupt delivery. What sim are you using? Quote Link to post Share on other sites
Recommended Posts
Join the conversation
