AdonVonPanzern Posted March 11, 2020 Report Share Posted March 11, 2020 I have recently have been looking for a boot disk for the Macintosh plus and stumbled across a post of someone using a SCSI IOmega zip drive to download System 7 and boot a Macintosh. is this possible? And can someone explain it to me? and is it easy? Quote Link to post Share on other sites
LaPorta Posted March 11, 2020 Report Share Posted March 11, 2020 Yes, although it is tricky. It involves putting Iomega Driver 4.2 or earlier in the System Folder of the Zip, and not using the disk with version 4.3. or greater. I will cut and past here a guide that I downloaded for it a long time ago. This is the quick and dirty details, as the whole thing is too long to put here: Recently I got bitten by the bug and once again am a zealot for the plus- For some odd reason, I've decided to do whatever I can to help make these wonderful machines as useful as possible. Quick Instructions Create a SSW 6.0.8 boot disk with the Iomega 4.2 driver installed. With Plus powered off, Zip Drive powered off, attach the Zip Drive to the SCSI chain. Make sure the zip drive termination is set to "on" if it is the LAST device in the chain- set to "off" if other devices are AFTER zip drive. Power on all items on the SCSI chain. Power on Plus, booting from the floppy. Your Zip Disk should NOT be inserted in the drive yet. Insert the Zip Disk- it *should* mount. Select "Erase Disk" from the Special menu. This will properly format the disk for use with a Plus. Install System Software on to the Zip Disk. Place the Iomega 4.2 Driver into the System Folder (SSW 6.0.8) or the Extensions Folder (SSW 7.x). You *should* now have a bootable Iomega Zip Disk! NOTE: The above procedure WILL NOT work if your zip disk is PC format- Iomega Tools are required if you have a PC format Zip Disk, and Iomega Tools does not work on a Plus. Quote Link to post Share on other sites
AdonVonPanzern Posted March 11, 2020 Author Report Share Posted March 11, 2020 (edited) 7 minutes ago, LaPorta said: Yes, although it is tricky. It involves putting Iomega Driver 4.2 or earlier in the System Folder of the Zip, and not using the disk with version 4.3. or greater. I will cut and past here a guide that I downloaded for it a long time ago. This is the quick and dirty details, as the whole thing is too long to put here: Recently I got bitten by the bug and once again am a zealot for the plus- For some odd reason, I've decided to do whatever I can to help make these wonderful machines as useful as possible. Quick Instructions Create a SSW 6.0.8 boot disk with the Iomega 4.2 driver installed. With Plus powered off, Zip Drive powered off, attach the Zip Drive to the SCSI chain. Make sure the zip drive termination is set to "on" if it is the LAST device in the chain- set to "off" if other devices are AFTER zip drive. Power on all items on the SCSI chain. Power on Plus, booting from the floppy. Your Zip Disk should NOT be inserted in the drive yet. Insert the Zip Disk- it *should* mount. Select "Erase Disk" from the Special menu. This will properly format the disk for use with a Plus. Install System Software on to the Zip Disk. Place the Iomega 4.2 Driver into the System Folder (SSW 6.0.8) or the Extensions Folder (SSW 7.x). You *should* now have a bootable Iomega Zip Disk! NOTE: The above procedure WILL NOT work if your zip disk is PC format- Iomega Tools are required if you have a PC format Zip Disk, and Iomega Tools does not work on a Plus. could I do this on a windows pc with system 7? also im trying to do this without a bootable drive as I have no 800k floppys with the system Edited March 11, 2020 by AdonVonPanzern Quote Link to post Share on other sites
LaPorta Posted March 11, 2020 Report Share Posted March 11, 2020 I don't think that is feasible unless somehow one of us (meaning perhaps me) can make an image of a Zip set up this way (I just so happen to possibly have one), and you can use Cider Press or some windows equivalent to make the image onto the Zip disks you have. It will take me until at least this weekend to get that going if you want to try the disk image route. I am assuming you have a PC Zip drive. Quote Link to post Share on other sites
AdonVonPanzern Posted March 11, 2020 Author Report Share Posted March 11, 2020 (edited) 4 minutes ago, LaPorta said: I don't think that is feasible unless somehow one of us (meaning perhaps me) can make an image of a Zip set up this way (I just so happen to possibly have one), and you can use Cider Press or some windows equivalent to make the image onto the Zip disks you have. It will take me until at least this weekend to get that going if you want to try the disk image route. I am assuming you have a PC Zip drive. I don't own one but they arnt too expensive to get I would have to get a usb version though and get a usb to scsi adapter or if you were up for it I could possibly paypal you for the amount of the disk plus shipping. Edited March 11, 2020 by AdonVonPanzern addons Quote Link to post Share on other sites
El reeko Posted March 24, 2020 Report Share Posted March 24, 2020 (edited) Hi, I make using a zip drive in windows ME with Basillisk via parallel port and hfe explorer. You have to configure a scsi drive in Basillisk, make a format inside OS 7 or 6 and that's it! you can use in a mac plus. Edited March 24, 2020 by El reeko Quote Link to post Share on other sites
Recommended Posts
Join the conversation
