cocoadelica Posted February 23, 2020 Report Share Posted February 23, 2020 Hi, has anyone had any luck using a 3Com Megahertz Ethernet card model 3CXFE575CT on OS9 is a 2400c? Quote Link to post Share on other sites
trag Posted February 25, 2020 Report Share Posted February 25, 2020 The trick is to find a card which uses teh same chipset as was used by a card for which there are Macintosh drivers (extensions/CP). 3Com tended to make their own chipsets, so unless there was a 3com based Macintosh card, that's probably not goign to work. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
