HAL2001 Posted November 8, 2019 Report Share Posted November 8, 2019 I want to repair the trackpad of a iBook G3 clamshell. It’s not working. I reseated the cable but that didn’t help. The trackpad Control panel says there is no trackpad available Quote Link to post Share on other sites
bibilit Posted November 8, 2019 Report Share Posted November 8, 2019 Probably the better solution will be to replace the unit. Quote Link to post Share on other sites
Mighty Jabba Posted November 8, 2019 Report Share Posted November 8, 2019 Yeah, I'm not sure they are really repairable. Hopefully it's just the cable or trackpad and not the connector on the board. Quote Link to post Share on other sites
HAL2001 Posted November 8, 2019 Author Report Share Posted November 8, 2019 I noticed that the trackpad is glued to the uppercase. Is it worth trying to open it? Quote Link to post Share on other sites
Mighty Jabba Posted November 8, 2019 Report Share Posted November 8, 2019 You're basically going to end up destroying it, I'm afraid. Quote Link to post Share on other sites
HAL2001 Posted November 8, 2019 Author Report Share Posted November 8, 2019 It’s installed with the universal 9.2.2 disc from macos9lives. That disc has no trackpad control panel. Is it even necessary on os9? Can I do something on the software side of things?thanks! Quote Link to post Share on other sites
Byrd Posted November 8, 2019 Report Share Posted November 8, 2019 Even without the Trackpad control panel, it should still function as a normal mouse. Try a retail OS install of OS 9.1. Reseat cable, check for damage - they were easily severed. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
