Von Posted January 22, 2018 Report Share Posted January 22, 2018 (edited) Hi All, I got a chance to inspect each of the 3 SE/30 motherboards I have for 2 systems. It has been a few years since I have looked at these and I am pretty certain I sent 2 of these away for a recap job however I am not an capacitor expert and could use help identifying the work done on each. Apology in advance for the quality of the photos. This is the board that came in my original SE/30: I thought I had this one worked however those appear to be the original caps. Is that correct? This is a socketed board I got off of eBay that looks like work has been done to it: This is the board that came with a system that had a Daystar 030 Accelerator attached to the board. The original non-socketed CPU was removed for the Daystar to plug into, however, the photo has the stock CPU inserted... This one too looks like it has had work done however the caps are different than the stock socketed board... THx! Edited January 22, 2018 by Von Photo order Quote Link to post Share on other sites
techknight Posted January 22, 2018 Report Share Posted January 22, 2018 3rd board is bone stock with no work done to it. first 2 boards have been re-done. Quote Link to post Share on other sites
Juror22 Posted January 22, 2018 Report Share Posted January 22, 2018 (edited) None of these have what appear to be original caps, even the one on the bottom, with electrolytic caps do not appear to be the 'stock' caps, unless they are missing their markings. https://www.flickr.com/photos/66071596@N00/3847352863/in/photostream/ above is a link that displays an original board prior to re-cap. Edited January 22, 2018 by Juror22 add Quote Link to post Share on other sites
techknight Posted January 22, 2018 Report Share Posted January 22, 2018 (edited) umm... As I said, bottom board IS bone stock. even has the 1989 date code on the caps. The Axial leaded caps are about as stock as they get. Matter of fact, all 3 boards have the original axial leaded caps. They need changed as well as the SMD lytics. Edited January 22, 2018 by techknight Quote Link to post Share on other sites
Von Posted January 23, 2018 Author Report Share Posted January 23, 2018 (edited) 6 hours ago, techknight said: 3rd board is bone stock with no work done to it. first 2 boards have been re-done. Thanks for this and phew...that is what I thought I had done. 6 hours ago, techknight said: Matter of fact, all 3 boards have the original axial leaded caps. They need changed as well as the SMD lytics. Not being a cap expert, are the 2 blue ones what you are referring to? Finally, is there someone on this group that does recap work? I have seen someone on eBay offering this service. Edited January 23, 2018 by Von Quote Link to post Share on other sites
techknight Posted January 23, 2018 Report Share Posted January 23, 2018 There are a few people. Uniserver is one of them but I dont think he is a member here anymore though. Quote Link to post Share on other sites
bibilit Posted January 23, 2018 Report Share Posted January 23, 2018 Where are you based ? Quote Link to post Share on other sites
Von Posted January 23, 2018 Author Report Share Posted January 23, 2018 Bothell WA USA Quote Link to post Share on other sites
Recommended Posts
Join the conversation
