Trash80toHP_Mini Posted February 21, 2012 Author Report Share Posted February 21, 2012 It may be almost four years old, but I really enjoyed this article by Charles Moore: Low End Mac's Compleat Guide to the Pismo PowerBook. Quote Link to post Share on other sites
Bunsen Posted May 17, 2012 Report Share Posted May 17, 2012 http://www.jcsenterprises.com/Japamacs_Page/Processors.html An excellent page on compatibility of G4 CPU modules between different models. From theos911's post here. Also: Subject: G4 processor swaps You can use Sawtooth/Gigabit Ethernet CPUs in a Digital Audio without any changes at all. Apple System Profiler may say it is running slow but other programs can generally detect it properly. (I have personally tested this, including changing the resistors and running benches) The only issue is that you are running a really slow CPU and the bus gets dropped down to 100MHz but it is good for testing a suspect motherboard or CPU.I have not tried in a QS, but the QS is similar enough to the DA that it *should* probably work. ymmv Quote Link to post Share on other sites
Bunsen Posted June 6, 2012 Report Share Posted June 6, 2012 Daystar PowerCache and 030 (SE/30/IIsi) PDS adapter Subject: SE/30 Powercache adapter? Finally got some high resolution photos here: Unresized scans: http://farm8.staticflickr.com/7079/7316874112_6efd540116_k.jpg - underside http://farm8.staticflickr.com/7077/7316874656_6e5525e0ed_k.jpg - topside Best I can do with the scanner I have on hand. Friend of mine has a really nice, really expensive DSLR that I'm sure would do a better job. This sucker is for sale if anyone is interested; still untested but I'd accept a return+refund if it didn't work. Quote Link to post Share on other sites
Bunsen Posted November 30, 2012 Report Share Posted November 30, 2012 MinerAl's logic board interchange chart. Which Mac logic boards share the same form factor and can be fitted in the same cases. Quote Link to post Share on other sites
Trash80toHP_Mini Posted May 10, 2013 Author Report Share Posted May 10, 2013 Need link to the old Ports & Pinouts(?) document that shows the @$$end of Macs up to the day the document was created. edit: I found it on the QS'02, the filename is mac_ports_pinouts.pdf for my copy, coul Didn't find a link, so I may have changed the name. It's a VERY useful Apple Document. Ports and Pinouts ServiceSource Document Quote Link to post Share on other sites
Bunsen Posted May 11, 2013 Report Share Posted May 11, 2013 This seems like as good a place to leave this as any, at least till we have a functioning wiki again. The "Family tree" of development and technical documentation for early macs: Subject: Another IIci ROM hack Here's the RoadMap: . . . with a couple of other Titles I'd like to nab! Here's the .TXT info: Quote Link to post Share on other sites
Bunsen Posted September 8, 2013 Report Share Posted September 8, 2013 High res versions of above: Quote Link to post Share on other sites
Trash80toHP_Mini Posted May 24, 2018 Author Report Share Posted May 24, 2018 (edited) Link from v1.0 of the project re-discovered: Room of Duo is a fabulous resource for the PowerUltraBook crowd. p.s. the links project is supposed to be a community effort. All contributions welcome (begged for actually) and encouraged. I can't believe we've neglected this stickied topic for six five years now . . . Edited May 24, 2018 by Trash80toHP_Mini ID10T error correction Quote Link to post Share on other sites
Recommended Posts
Join the conversation
