Jump to content
dzog
IIe card can't read 5.25" disks?
Recommended Posts
Greetings Apple II friends. I am attempting to repair a IIe card I received in a lot. I recapped it and it seems to work OK, except for reading 5.25" disks.
My lack of Apple II knowledge and experience is hindering my debugging ability.
I was able to get it to read a ProDOS 3.5" disk (via the host Macintosh) and run applications. No obvious issues there. But, reading a 5.25" disk just makes the initialization(?) noise and then fails. So, it's talking to the disk somehow. I've tried cleaning disks, 3x different drives, and a bunch of different disks, all the same result. I unfortunately don't have any other Apple II gear to test with.
Is this a known Apple II failure mode of some sort? A failure of a certain chip on the board?
Any pointers are appreciated!
Share this post
Link to post
Share on other sites
11 hours ago, Realitystorm said:
I assume you checked the drive model already to make sure they are supported?  https://support.apple.com/kb/TA47189
Yeah - they are all model A9M0107. As shown in the video, they make a satisfying noise but never seem to actually load any data.
Edited by dzog
Share this post
Link to post
On 5/18/2020 at 2:45 PM, bibilit said:
IIRC capacitor goo can be present under the pds connector or even corrode pins.
Good call - I could just make out some unwashed goo/corrosion underneath the PDS slot near the cap. Hard to reach, but I poured in some vinegar, and also ran it through the dishwasher with detergent. Re-tinned the PDS pins with flux and a mini dab of new solder each.
Haven't broken it worse yet :) but still not reading any floppy disks!
Is it interesting that the drive does do the "init" sound when access is attempted, but apparently will not read? Maybe I can get some sort of diagnostic software running via 3.5"/ProDOS; perhaps a disk copying software would lend some insights.
Share this post
Link to post
I did get a disk copy program running via 3.5" ProDOS. This is what I get reading from a 5.25" drive with a disk inserted. Error on every read. The Red LED lights up on the drive, and every 8 blocks it makes a small noise.
Video shows the behavior and the drive noise; apologies for the sad-sounding HDD in the background:
Edited by dzog
Share this post
Link to post
Grasping at straws here:
In your recapping thread for this card, you posted a picture of the card after corrosion was removed w/ vinegar. That picture showed the component labeled SOMC1603, a resistor pack, and it appears that several signals going to the floppy port go through that component. Many of the solder joints on the resistor pack look dull/crusty; perhaps a bad connection on it is causing this problem?
Share this post
Link to post
That wasn't _quite_ it but it certainly led me down the path - thank you.
We have victory!
First recap quickly became first IC remove-and-reflow and finally the hacky (but working) fix you see in front of you:
Sequence of events:
- Retinned RP1 and a variety of other things to no avail
- Started testing everything with a multimeter
- Culprit! Cap goo (which I had thought looked so minor) opened a trace going from RP1 to the IWM. Barely visible damage near the junction.
- First attempt at fix (jumper from RP1 to IWM) first worked, then failed.
- Newbie debacle interlude: in a debug attempt, I tried to "reseat" the IWM with a heat gun (a $30 basic low/hi 250/350C one I use for heatshrink) instead of retinning with the iron like I'd be doing with the others. Oops, the chip slipped and now it's totally misaligned. Beat myself up a bit. Ended up removing IWM completely, cleaning off pads, and using solder paste for the first time to reflow. Paste is magic! But I used too much and had to clear 4 bridges, total PITA.
- The fix was flakey as RP1's leg was corroded and weak. It soon fell off. Quite fortunately it's a simple 100 ohm resistor pack and I have plenty of resistors on hand.
- Ultimate destination is one of the connector pins; wiring straight into there was easiest for me.
It's not the prettiest thing in the world, but it does mean I get to play with Apple II stuff now :D
The happiest sounds:
Edited by dzog
Share this post
Link to post
Glad you got it working, I've had a lot of fun playing with mine in my LC 475 (originally in a CC that needs a recap).
I've put together a partial guide for using the card that you might find useful
https://www.savagetaylor.com/2019/12/04/setting-up-an-apple-iie-emulator-card-in-your-68k-macintosh/
If you haven't already created ProDOS partitions, that should be a next step, it will give you a lot of flexibility for using the card.
I have 4 setup on my SCSI2SD
http://www.savagetaylor.com/2019/12/19/how-ive-setup-the-scsi2sd-that-i-use-in-my-lc-475/
Share this post
Link to post
Thanks for putting those helpful resources together :)
Fix is working reliably for a few days now.
Eventually I think I'll want to make this board repair a bit nicer for the long-run - get a replacement resistor pack, redo the pad and trace, a nicer reflow on the IWM. But for now I'm just stoked to be up-and-running with it. And, heck, the "homebrew" look is a bit endearing ;)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
