Jump to content
Sign in to follow this
johnklos
Trick to using old ethernet cards on new switches?
Recommended Posts
Many older NuBus / LC ethernet cards work fine with 100 Mbps and gigabit switches with auto negotiation. However, certain cards seem to not want to work. Some have a jumper which causes the link to stay on regardless of the physical connection.
Does anyone know how to make these cards work with standard 100 Mbps / gigabit switches?
For instance, I have a couple of Asante "MacCon LC-A" version 1.1 cards. I prefer to use them because they have a socket for the m68881 or m68882 FPU. However, I can't get a link on anything. Without the jumper, it gives a blinking link LED, and with it, it gives me a solid link LED, but nothing on the other end either way.
In the past I used to keep around 10 Mbps hubs just for connecting older machines with cards like these. Is this still the most straightforward way?
Share this post
Link to post
Share on other sites
I use a cheap managed switch for my network, which lets me have a block of ports where autonegotiation is turned off and the port is forced to be 10mbit.  It seems to work for me but I don't have any *really* abstruse network cards.
Share this post
Link to post
I have an old Cisco 1800 for that. Let's me set port speed and duplex manually and worked with anything I could throw at it so far.
It makes some other fun stuff possible as well because it can still do AppleTalk with the correct IOS version installed.
For example I am running a MacIP gateway on that thing to get Macs online that are sitting behind my Asante Localtalk/Ethernet bridge.
Share this post
Link to post
2 hours ago, olePigeon said:
I have my trusty old blue Netgear 10/100.  Works as a great intermediary.
Me too-- I have a little 5 porter that I got on sale eons ago. It has survived multiple purges so now it's just considered a rightful member of the family.
Share this post
Link to post
@MJ313  Ditto, but 8 port.  What's funny is that I have stacked on top of it an 8 port Netgear Gigabit managed PoE switch.  The cases are identical, they haven't changed them in all these years.  If it ain't broke, don't fix it. :)
Share this post
Link to post
If you connect to another computer using a crossover cable or network card that supports MDI-X, you can disable auto negotiation to allow the link to work.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
