Jump to content
Bama
Steel ball bearing as Duo 250 trackball
Recommended Posts
Hello All,
I need a replacement 19mm trackball. I have a 19mm steel ball bearing.  Is this safe to use the metal ball bearing as a replacement?  My reason for asking is that I can see what looks like copper at the base of the trackball assembly.  I attached a picture.
Thanks,
Bama
Share this post
Link to post
Share on other sites
Fabulous idea, I hope it works out. Is 19mm the trackball spec or did you use a caliper on the original?
I don't have a Duo open ATM so I couldn't check. I don't think the ball would touch the brass, check if the rollerball is supported by the mechanism's rollers? If the copper/brass ring is the bottoming out support it's a no go. If so the weight of the ball bearing may stress the support structure? Dunno, I've got one colored ball so I haven't looked for them, but if marbles are available in 19mm they'd make some crazy trackballs.
Smoothness might be a concern in terms of frictional interface differential with the roller material?
On a side note, the mass of a bearing would have made tweaking Bezier control points a lot more accurate given the inertial upgrade when I was doing that in the field.
Share this post
Link to post
Just checked marbles out, a 3/4 inch "Shooter" is 19.05mm!  [:D]
edit: Just checked the PB100 trackball is about .9885" and Outside the North America, 1-inch marbles are sometimes used as shooters.
One wonders what  was used in trackball protyping? 100 series Powerbooks are an oddball size at 1 3/16 in. so they're 3/16" short of the 1 3/8" marble standard.
Edited by Trash80toHP_Mini
Share this post
Link to post
19mm steel ball bearing works terrific!   Now I only need a retaining ring. (I don’t want a loose ball bearing bouncing against my glass screen when the lid is closed.)
Any ideas for this part in the United States?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
