Jump to content
sclements
A/UX running on SE/30
Recommended Posts
Hi everyone! Long time lurker, first time poster. I hope this is the right place to brag about finally getting an SE/30 of mine in good working order, resurrected with help of @PotatoFi, and running A/UX! It was a gift to me from a high school buddy. Several years back I learned about leaking batteries and caps and after a few cross country packages and some judicious parts swapping from donor machines, it appears that my long awaited "perfect" A/UX machine is up and running! It's sporting the factory spinning drive, 128M of RAM, an ethernet adapter (which works!) and a BMOW 32bit clean ROM. Seemingly A/UX can address all of the memory using the ROM. I'm still getting A/UX install boot failures (I installed it on the factory ROM), but it seems that when you swap out the ROM post-installation, it boots and operates just fine! Now once my clear case comes in for it, I'll swap in an SCSI2SD adapter and industrial SD card and re-build it again for my perfect dream machine! Pics attached. I hope someone enjoys this half as much as I do. :)
Keyboard and mouse will eventually be vintage correct, but it appears the machine is pretty dang functional at this point!
Share this post
Link to post
Share on other sites
This is awesome. I'm looking forward to you getting your case from @maceffects, and installing the SCSI2SD. An SE/30 with 128mb of RAM, a twisted-pair ethernet adapter, BMOW 32-bit clean ROM, SCSI2SD, SCSI CD-ROM (you have that too, right?), A/UX, and a clear case sounds like the ultimate SE/30 to me.
Where did you go to find all of the A/UX how-to?
Share this post
Link to post
Thanks @PotatoFi! An external CD-ROM is of course a must have for the build. :) I went to the definitive A/UX resource on the internets:
http://www.aux-penelope.com
I had to make a couple of inferences and assumptions (especially around memory management and the BMOW ROM), but by and large, it was pretty straightforward if you've got a little bit of UNIX know how.
  -Sam
Share this post
Link to post
  -Sam
I also made this one based on my experience: https://wiki.preterhuman.net/Newbie_Guide_To_A/UX_(Apple_UNIX)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
