Jump to content
Sign in to follow this
Papichulo
Powerbook 100
Recommended Posts
Hello
I just got a powerbook 100. It looks good and has a working screen
The issue is the ac adapter port is loose and when i plug it in it makes a static noise with the sad mac sound.  I got it to start up to a flashing disk since theres no hd but then back to static noises. Is that because the ac plug is loose? I scrubbed the boards down to. Thanks
Share this post
Link to post
Share on other sites
Check the tip of the power jack plug. If there's a chip in the insulation DO NOT USE THAT A/C ADAPTER AGAIN!!!!
There was a longstanding silent recall deal when it was new. A chipped plug can trash the motherboard completely, happened to mine. The new MoBo/Power Power Adapter replacement repair was free. If you do need to get an new adapter, make sure it's the original part number or the low power version, the full power 100 series version will blow up a PB100 or Lugggable.
Share this post
Link to post
The PowerBook 100 is also known for having capacitors issues (Logic board side)
apart from  having a bad connector (maybe just bad or broken connector solder) i will replace caps first (never seen one with good ones)
Share this post
Link to post
The powerbook makes a regular chime but only when i hold the plug down. The ac adapter works but the ac port is cracked on the solder part under the board. I saw the question mark screen once and it was clear but not since.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
