Jump to content
kater
Macintosh 12" Monochrome Display M1050 - retrace lines
Recommended Posts
Picture faintly visible.
Moved thread from here:
Replaced caps and tested transistor PH2369 (fine on my cheapo tester).
No other result.
But i never gonna give you up. :)
thanks!
Edited by kater
Share this post
Link to post
Share on other sites
Before you fire that thing up, you must reconnect all the grounds back on the CRT board if you want to run it without the shield for troubleshooting. Otherwise you must reinstall and resolder the shield.
From looking at the design, the ground shield is the ground that connects everything together, once removed, it will fail to work right.
Edited by techknight
Share this post
Link to post
So it might be the ground shield was not properly soldered back? Seems i wasnt the first one opening it.
As i can't test the IC (with my knowledge), would it make sense to replace it just in case?
(I'd order some anyway for future use)
Still having a hard time comparing ICs - could you recommend a similar one, preferable available in EU?
LM1201N
https://www.mouser.at/
thanks for your great support
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
