Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9896 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39189
      posts
    3. Trading Post
      52303
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1481
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      482
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45103
      posts
    2. Mac II, Quadra & Centris
      12846
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7880
      posts
    4. 68k PowerBook
      9717
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13669
      posts
    4. PPC PowerBook & iBook
      8940
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7307
      posts
    2. Newton
      1062
      posts
    3. Software
      17332
      posts
    4. Hacks & Development
      18323
      posts
    5. Peripherals
      14403
      posts
  • Posts
    • I finally found the problem ! After cleaning the logic board, replacing the capacitors on both boards and two diodes on the analog board (as suggested by @bibilit on another thread), still nothing worked. My voltage was a little bit better, but still not enough. So I changed the CNY75GB optocoupler, and now everything works perfectly fine !   Thank you all for your help
    • That's absolutely insane. I definitely would have given up fore sure.    You're an inspiration Potato.    All that hard work and what it looks like now, it might actually, possibly, hopefully, with some wood-touching, power on to maybe something on screen.
    • This is a fantastic worklog / guide so far, and I can't wait to see where it goes.
    • Thanks for the rundown, Compgeke.  If you like, I'll edit a link to that post into the head comment of the thread.
      Can anyone definitely say what all other models fit in under "etc"?
    • The Bluetooth modules on all of the G5s (and G4s and some if not all Intel models) run over an internal USB interface. So you're really not saving any cycles by using the internal USB-based card vs. an external USB device, except you'd maybe save a little clutter and maybe have a better antenna with the internal card.
