Jump to content
plb007
Strange card on a mac plus
Recommended Posts
Hi,
I have a mac plus with an extra db9 cable going through the security hole and don't know what is it.
The computer was heavier than the others. As I have a sad mac icon at startup, I decide to open the computer to have a look inside. The computer is very full of extra component.
IMG_8884.thumb.JPG.496088a42fb45e7237b3cf074ce0e8c1.JPGIMG_8885.thumb.JPG.ac9a125322613562632192101f73ad57.JPG
It looks that there's an extra power supply just under the screen, an extra card at the back of the computer, an extra card packed at the logic board and a extra fan (or a relocation) to cool everything. IMG_8886.thumb.JPG.762367e03884019d128df5a8e14f2b71.JPGIMG_8888.thumb.JPG.384c852bae002c1bb7eadebc1afc291a.JPG
Does someone have information on this setup ? The back's card has "Micrographic mega screen written) I assume the db9 port is VGA or component (RGB) ? IMG_8889.thumb.JPG.c7e4e86a682487e01dadb2c32567532d.JPG
It looks very complicated to remove those cards, lot of extra screws and extra wiring to deal with.
Have a look at the pictures
Share this post
Link to post
Share on other sites
Now THAT is some strange setup!
http://www.digibarn.com/friends/janek-kaliczak/index.html
This one (and that cutoff "P" in your pic) makes me think you have the Plus version, possibly with accelerator? HDD? That is one big PCB running from front to back over the Logic Board!
Link found here: http://myoldmac.net/SELL/MacSE-MegaScreenCard.htm
Edited by Trash80toHP_Mini
Share this post
Link to post
This might be an Megascreen I as there's a cooling fan in the setup. I'll try to take it apart. I can't remove the logic board as it seems to hold a cable to another board. I need to figure out the disassembly order first. I'm impressed how they packed all that stuff inside this small case.
I guess there's no hard drive inside.
What's the sad mac 02FFFF meaning ?
Share this post
Link to post
02 usually means bad RAM but I'd be willing to bet the add on card is the cause of this issue. I'd say the additional PSU has failed (recap in order?) and can't drive the Megascreen card properly, which in turn causes issues with the Mac's logic board in the RAM department.
The analog board still seems to have enough juice left to power the display and the logic board. If you can get it further apart, I would recommend trying to disconnect the add on card from the logic board. You can still leave the additional PSU connected to the Analog board as it seems to be fine with that.
Share this post
Link to post
Thanks for your answer, I tried to dismantle everything today with no luck. I mean I think I can take it apart but with no idea how to reassemble it later. Some bolt and/or nuts will fall inside the computer and I have no idea how to put them together. For now it's on hold as I need some place in my desktop. There's no need to rush as nothing seems to leak everywhere in the main board. I'll try first to power it as if it is from stock and then add elements one by one.
Share this post
Link to post
MegaScreen "1" and MegaScreen Plus appear to be the same
Your MegaScreen Plus(?) appears to have some interesting features.
That circuit board bolted up to the Logic board has some interesting possibilities. The Macintosh Plus wouldn't need the internal HDD option where the 512k would.
edit: all(?) compacts with expansion boards require spreading the chassis tracks for installation/removal. Maybe someone can post linkage to a good howto vid, page or manual for you.
Share this post
Link to post
Yep, that's how you're supposed to remove the board when you have accelerators etc on early macs. It's a different story for compacts SE onwards.
Start by positioning the Mac on its face and look at the bottom (logic board), grab the left side of the chassis (if needed, rotate yourself to the left so that you can see the floppy drive), put your thumb inside the Mac where the red arrow is and carefully bend the chassis (and the tracks) outward to 'release' the board.
Share this post
Link to post
Not all that different sometimes. The slot for Radius FPD and TPD cards at the rear of their Accelerator boards required the Killy Klipped card method as it blocked slotted track removal. Was it much the same story with the socketed PowerCache board in the SE/30?
Share this post
Link to post
I can remove the Powercache and the logicboard as one unit without bending the chassis at all (thanks to the tracks in the chassis being different and better IMO). Same thing with the Micromac 030 in my Classic although I do have to slide it all the way up. I don't have a FPD yet so I don't really know about those. I thought the accelerator or the Magicbus card could stay on the board and be removed the same way.
Now that I think of it, probably all cards that have the same width as the logic board need to have the chassis bent a bit to be removed. So that's almost all early mac boards, plus some (most?) of the SE cards. My bad.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
