Jump to content
Recommended Posts
Hi!
I have Xserve G4 slot-loading (https://everymac.com/systems/apple/xserve/specs/xserve_g4_1.33.html). I've noticed that Diagnostics tab of System Information shows L3 cache failure. I reset NVRAM, ran Apple Service Diagnostics and it shows L3 cache 0 bytes. I physically removed the CPU and looked at two Samsung memory chips there — it is GBA soldered. What to do, how to enable L3 cache again? Is it a software restriction (if yes, then where to enable)? But I think it is a hardware failure, who and how fixed it? It it enough to re-solder two memory BGA chips, or need chips replacement, or something else?
Edited by m_emelchenkov
Share this post
Link to post
Share on other sites
Cache failures seem often to be CPU related, so swapping the cache chips itself is probably not going to help you.
I have been testing a few CPU modules that reported L3 cache failure and the L3 started to work again after swapping the CPU.
As MDD/XServe modules are cheap and easily available it is not worth it to even attempt this repair as you would need another CPU card as donor anyways.
Edited by Bolle
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
