Jump to content
JDW
SE/30: RAM configuration with 16MB SIMMs
Recommended Posts
Low End Mac mentions that any RAM configuration above 32MB is no specified by Apple and therefore there are no specific guidelines for higher configurations.  I therefore am curious to hear from those of you who own 16MB SIMMs to see if you experience matches my own.
I have an SE/30 with the stock SE/30 ROM and a CPU-socketed 50MHz Daystar 68030 Power Cache accelerator.  When I fill all 8 RAM slots (motherboard RAM slots -- the Daystar card has no RAM), the SE/30 powers on with with the normal bong (although the bong sound is cut short a bit at the end for some reason) and I can confirm 128MB of RAM when I boot.  But when I put only 4 of those 16MB SIMMs in Bank A or only 4 in Bank B (for 64MB RAM total), I get the chimes of death (full chime sound, not cut short) and see the following garbage on screen:
This is true even with no ADB devices attached, no internal HDD, and the internal Floppy Drive disconnected.  The motherboard, analog board and SONY PSU are all recapped.  And nothing is in the PDS slot.
Have any of you SE/30 owners had success filling only 4 slots (Bank A only or Bank B only) with 16MB SIMMs?
Share this post
Link to post
Share on other sites
Yes, I have 64mb in bank A in my se/30 and the configuration works. Worked with both DiiMo & Daystar PDS-based accelerators, haven't tried socketed yet.
EDIT: I am wrong, you need to have Bank B filled with something for Bank A to use 16x4 (64mb)
Edited by nickpunt
Share this post
Link to post
Hmmm...
Thank you for sharing.
Another interesting thing is that when I replace the stock ROM with a IIsi ROM and fill all 8 slots (128MB RAM), when I switch the power ON, I hear the full bong sound but see the same garbage on screen as shown in the photo of my opening post.  That screen never changes and I cannot boot.  But again, with the stock ROM, all is well.
Share this post
Link to post
I use Dougg3/BMOW ROMinator based on IIsi ROM with my machine along with the stock se/30 ROM and both work fine. I use OWC's 16mb chips.
Apologies, looking at my notes just using Bank A with 64MB won't work according to a table I copied from this page. However with Bank B filled with anything (1mb x 4 or higher) works. I run this config (68mb, with 4mb in Bank B). Also, apparently larger / higher density RAM must be placed in Bank A not Bank B.
Also, an 8mb (2MB x 4) configuration using 2-chip sticks didn't work for me. Apparently this is not a valid config. Only 4mb (1mb x 4) and 16mb (4mb x 4) work with just Bank A filled.
Here's some other links from my notes that may be helpful:
MacFAQ Memory
Old 68kmla post that said 2-chip and 3-chip ram worked in se/30 (these are known to be more flakey, so they may not always work)
Old 68kmla post on a sadmac error 0300FF that is memory related, this time due to ram chips being the wrong speed (ns) and solved by changing ram chips
Edited by nickpunt
Share this post
Link to post
The short chime should be normal when you have any kind of PowerCache accelerator in there.
All my Macs with a 030 Daystar do this.
Just as nickpunt said you need something in the second bank when you fill the first one with 64MB.
Share this post
Link to post
@Bolle, thank you for the tip about the "short chime" being tied to a PowerCache being installed!  I appreciate it!  By the way, do you have a copy of PowerCentral newer than v2.2?  (I have
@nickpunt, I put in my ROM-inator II MEGA and it has its own chime and boots normally (whether into its own ROM or from my FloppyEMU or HDD).  So no problems there.
Wow! I just put my IIsi ROM back in and waited 5 minutes.  This time it booted, despite the garbage on screen!  Hmmm...  Well, at least that proves my IIsi ROM is still OK.  I guess I forgot just how long it takes to check 128MB of RAM, even with an accelerator!  Even so, the garbage on screen is curious.
Anyway, one bad thing about the ROM-inator II is that I sometimes get errors when I first switch on power.  They unfortunately made the PCB a tad too thin so the ROM SIMM pads don't touch the motherboard pins as firmly as with Apple stock ROMs.  Of course, their documentation suggests using either a rubber band -- which is crazy because rubber bands disintegrate rather quickly over time -- or a metal paperclip as a brace -- which sounds a bit scary to me since if that thing ever popped off while your up and running, goodness knows what it would short out!  I thought about hot glue to secure it, but if the pads aren't getting good contact anyway, hot glue isn't going to be a fix here.  Maybe I should add solder to all the ROM-inator pads front and back to make them push against the motherboard pins better?  Anyone thoughts?
Share this post
Link to post
Well, nobody replied to my previous post :-(, so I will at least answer my question put forth to @Bolle.  I found the last update to the Daystar Digital software downloads page.  It seems that PowerCentral v2.2 is the last version ever released.  So that question is answered.  By the way, Bolle, in your last post to me you said I "need something in the second bank when you fill the first one [A] with 64MB."  Which implies that one can fill ONLY Bank A and get away with it, which is what @nickpunt said, however, that is only true in the stock condition and obviously doesn't apply when one has a Daystar PowerCache socketed accelerated installed like I do, which for some reason prevents installing 4 16MB SIMMs (64MB total RAM) only in Bank A.  Here's a photo of one of my 16MB SIMMs, by the way:
@nickpunt, I think you missed the question I put forth to you in my previous post so I will repeat it...
One bad thing about the "ROM-inator II" is that I sometimes get errors (can't boot) when I first switch on power.  They unfortunately made the PCB a tad too thin so the ROM SIMM pads don't touch the motherboard pins as firmly as with Apple stock ROMs.  Of course, their documentation suggests using either a rubber band -- which is crazy because rubber bands disintegrate rather quickly over time -- or a metal paperclip as a brace -- which sounds a bit scary to me since if that thing ever popped off while your up and running, goodness knows what it would short out!  I thought about hot glue to secure it, but if the pads aren't getting good contact anyway, hot glue isn't going to be a fix here.  Maybe I should add solder to all the ROM-inator pads front and back to make them push against the motherboard pins better?  Anyone thoughts?
Thanks.
Edited by JDW
Share this post
Link to post
I'm not sure about ROMinator solutions. I have one that no longer works in SE/30 (but fine in Iici) and another that works fine.
As far as RAM in Bank A, I'd assume regardless of having an accelerator (socketed or pds) or being stock, 4 x 16mb in Bank A alone is not going to work. Only 4 x 1mb and 4 x 4mb work. Feel free to try all the permutations, but I'm not sure you'd get a different result than from the Japanese repair link posted earlier. If (sans accelerator) you're able to get 4 x 16mb to work in Bank A alone, then that's a new finding.
Share this post
Link to post
I've had success adding solder to only one side of the ROM SIMM. Since you're probably not going to be able to make all pads the same thickness, you just make that side a bit thicker so that the unchanged side is more firmy pushed to the contacts of the socket.
Share this post
Link to post
I finally fixed the ROM-inator II Mega with a thicker paperclip as I describe in this post.
Share this post
Link to post
I couldn’t get the rominator II to work on my SE/30 using macos7.5.5 without doing a major os wipe as it needs downgrading, some systems changes before upgrading it back again to 7.5.5 which i couldn’t be bothered to reinstall all my configuration and software so i took it out will try again at somepoint maybe when i get scsi2SD.  Back to the memory i installed mode32 and used 8 x 16mb  OWC Memory modules and it worked great be it after long ram check. I had similar screen with previous cheap ram Which thankfully went away once the OWC memory went in. And it only took 3 days to arrive in the uk from us. Neal
p.s rubber band worked on the rominator for me before i took it out
Edited by SE30_Neal
Share this post
Link to post
Neal, you are not supposed to use the Mode32 extension when you use the ROMinator.
And as to getting system 7.5.5 or 7.6.1 or OS 8.1 to work with the ROMinator,  you must use resident to hack the System file as per the instructions given on the ROMinator product web page.
Share this post
Link to post
No mode32 is for 24bit dirty rom, rominator is 32bit clean.
yes you need to res edit system code but the process means it needs to be done on 7.5.1 i think then add the 7.5.3 and 7.5.5. There’s instructions on the rominator site. For me i have my se/30 setup nicely with a bunch of software and utilities so didn’t want to wipe a 2gb worth of stuff and re-install it all for the clean rom and quicker boot time.
I still have it and will likely add it in future when i have time to do some hdd upgrades.
neal
Share this post
Link to post
Right.  In your earlier post you first mentioned your use of the ROMinator II and then you spoke about the need to add Mode32, which I assumed you meant you were still using the ROMinator, in which case you would NOT use Mode32.  Of course you need Mode32 under the stock SE/30 ROM, although you would not need it for the IIsi, IIci or IIfx ROMs, which all work in the SE/30.
As to the 7.5.5 hack, I've not hacked mine in a while, but if you already have 7.5.5 installed, I don't see why you need to install 7.5.1, then do the hack, then upgrade over that hack.  I would think all you would need to do on an existing 7.5.5 install is do the ResEdit hack as described on the ROMinator web page.
Share this post
Link to post
Ah sorry I probably wasn’t very clear because i put it in, took it out etc..
yes i went back to the standard Rom with mode32 as it worked. I had tried the hack with 7.5.5 and couldn’t get it to work unless it was using just the rominator with 7.1 and the internal 8mb on the rom simm but it wouldn’t boot with my hard drives so i just put it back to standard and back with mode32 and live with the ram check
Share this post
Link to post
When you had the ROMinator II installed and when you tried to boot System 7.5.5 (with hacked System file), what did you see on the internal CRT during boot time?  Sad Mac?  Gray screen with no content?  Disk icon with flashing "?" inside?
Share this post
Link to post
1 hour ago, SE30_Neal said:
It was a while back, from what i recall just blank grey screen
It may have had the flashing disc come to think of it. I can’t quite remember
Share this post
Link to post
It's been a long while since I booted into 7.6.1 and OS 8.1, but I tried it just now without problem using my ROMinator II MEGA.  But I had already hacked the system files, so it wasn't surprising I was able to boot without problem.  Interestingly, I have "Wish I Were" installed in my 7.6.1 System Folder and set to "IIsi," but I don't even have it loaded on 8.1 and 8.1 works fine.  According to the ROM-inator II documentation, OS 8.1 should have Wish I Were set to a Quadra 700 for some reason.  You can read that here:
https://www.bigmessowires.com/mac-se30-with-upgraded-rom/
What does "Wish I Were" even do?  It's obvious it's not needed in OS 8.1 as per my test just now working fine without it.  But I'm curious if there are some situations that may require it. (Apple System Profiler in the Apple menu won't load and just beeps at me under OS8.1.  Curious if that is a "Wish I Were" related problem or just a ROM incompatibility.)
By the way, if you're wondering whether to run 7.5.5 or 7.6.1 (or even OS 8.1) with a non-stock ROM, check out this LowEndMac Article.
Edited by JDW
Share this post
Link to post
Yes thats the notes i used. The Hack itself from what I remember was pretty easy just changing something like 05 to 08 In a few res edit files.
never heard of Wish i were? I have no idea what it does! So do you have 8.1 on at SE/30?
Share this post
Link to post
Download: Wish I Were
Yes, I have the best of all the compatible systems on the same 1GB HDD partition:
  • System 6.0.8
  • System 7.1 (the best System 7 in terms of speed)
  • System 7.5.5 (for software that won't run in 7.1 or below)
  • System 7.6.1
  • OS 8.1
I have a IIsi and IIfx ROM which allows running of all those operating systems.  But I like my ROM-inator II Mega better because it has an additional hack that allows my HD20 to work with the SE/30.  (Yes, I have a real HD20 HDD drive.)  But mostly I liked the HD20 compatibility because it allows me to run my FloppyEMU in HD20 mode, which in turn allows me to boot off a 212MB "*.dsk" I created that has System 6 and lots of software -- all from the floppy port.  I could make an even bigger dsk if I wanted, up to 2GB in size with System 6.
What I really wish is that there was a SCSI drive that was similar to the FloppyEMU -- something I could easily connect and disconnect EXTERNALLY to move software faster and easier than even the FloppyEMU (which is slow because it connects to the floppy port).  Of course, the FloppyEMU is powered from the floppy port which is nice.  And a similar SCSI drive (with SD card) connected externally would need its own separate power source.  Even so, it would be nice to have.  SCSI2SD is for internal installations, not external.
Share this post
Link to post
Blimey you have your system setup sweet, I didn’t think you could even run 7.6.1 or 8.1 without accelerators and hacks.
i’d like to be able to run multiple OS on mine although only considered 6.06, 7.1 & 7.5.5.
how did you install all of those? how do format your hard drives into the correct sizes for each os?
i have 1gb internal hd & scsi avid external 2gb hd, zip drive and have it networked to my PowerPc and g3 imac.
Share this post
Link to post
The SE/30 has a stock 16MHz 68030 CPU.  Even 7.5.5 is a bit slow on the stock CPU.  7.6.1 isn't really slower than 7.5.5, but it has a longer boot time.  OS 8.1 even with a 50MHz 030 accelerator is a bit sluggish due to all the eye-candy Apple added.  An 68040 is nice for 8.1, but a lot of older software, especially System 6 apps, crash under the 040.  A 50MHz 030 is really the best acceleration option for the SE/30, I think.  But you also need a lot of RAM if you want to run 7.6.1 or 8.1.  I would recommend at least 16MB.  32MB is ideal.  128MB will let you do anything you want, but 16MB SIMMs are not always that easy to come by.
Currently, I have a 4.5GB IBM DGHS-04Z spinning platter hard drive inside an Apple external HD20SC enclosure, which I can switch between each SE/30 I use.  I also have internal drives for those machines as well, but those are all less than 1GB in size.  I've long been considering the purchase of a SCSI2SD but I've never got around to it.  Anyway, I keep all partitions to 2GB or smaller on my 4.5GB HDD to ensure System 6 can see all the partitions.  I have a 1GB boot partition on that same drive which contains all my operating systems, and System Picker allows me to switch between the operating systems.
I tend to use System 7.1 more than the other operating systems because its fast and compatible with a lot of software.  I need System 6 to use some older apps.  And let's be honest, System 6 flies even on a stock SE/30.  I love the speed.  My System 7.5.5 folder is currently not hacked in case I need System 7.5 on an SE/30 with a stock ROM.  If I want System 7.5.5 features on a non-stock ROM, I can use 7.6.1 because it's largely the same as 7.5.5.  OS 8.1 is there mostly for fun.  Seriously, if you need an OS that new you're probably best served with OS 9, but that won't run on 68k Macs.
There are times when I want to run much older software -- games like MacAttack and the like.  For that I would need a Mac Plus or older.  And I just happened to have a couple 512k Macs, one with a GCC HyperDrive inside, both with the original 64k ROMs (which mean they use 400k floppy drives).
Share this post
Link to post
There is - check the SCSI2SD V5.5, which is a bus powered external SCSI device you can plug directly into the DB25 SCSI port much like a USB thumb drive (only not hot swappable!).  You might have the contact the designer to see if he has any for sale - mine looks a little like a prototype but I'm delighted with it - 128GB fast external SCSI drive I can switch around to all my Macs, with a backup of all my 68K/PPC software and MP3s on it.
Edited by Byrd
Share this post
Link to post
37 minutes ago, Byrd said:
There is - check the SCSI2SD V5.5, which is a bus powered external SCSI device you can plug directly into the DB25 SCSI port much like a USB thumb drive (only not hot swappable!).  You might have the contact the designer to see if he has any for sale...
The WIKI still says V5.5 is "coming soon."
I'd love to see a photo of yours!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
