Jump to content
tthoms
Testing a Quadra 660AV Power supply..
Recommended Posts
So, as I try to restore the Quadra, I thought that I'd start with the power supply.  Searching the forums, I didn't find anything related to the pin configuration for the 9 pin socket that goes to the motherboard.  I took a volt meter to it and this is what I found:
Positive lead (Black) to Negative lead (Blue): Voltage seems to oscillate between 3-4 volts.
Positive lead (Yellow) to Negative lead (Black): Voltage seems to oscillate between 7-8 volts.
Positive lead (Red) to Negative lead (Black): Voltage reads in at 4.2 volts
Any idea what that means?  Assuming that Black is ground, it seems noisy at least.
I looked for a way to open the PSU, but I can't seem to find anything that isn't taking a screwdriver and prying the sheet metal apart.  If there is a useful trick, I'd love to hear it.
Thanks for any advice you can offer.
Share this post
Link to post
Share on other sites
So, I figured out how to get into the power supply.  At first glance, everything looks good.
No bulging capacitors, the board looks really clean,  until....
There seems to be a lot of grease or goo around the transformer.   Is that normal?  if not, can you replace them?
Share this post
Link to post
My 660av came dead and I ended up replacing my PS and it worked. I meant to see if I can fix it but have not got around to it (fixing PS is not my favorite thing to do).
Anyway I might dig it out this weekend and take a look. Are there more then one model of supply for the 660av?
Share this post
Link to post
Well I was down in the lab working on a DELL and the PS was close by so I took a look at it.
Astec AA16990 Apple 614-0022
Capacitor ,Voltage, marked uf, test uf, Ohm, Voltage drop %
c25 , 10, 470, 544, .19. 1.3
c27 , 25, 220, 212.5, .19, 1.2
c11, 25, 47, 49.39, 1.2, .9
c28, 16, 1000, 917.4, .18, 1.3
c29, 16, 1200, 1095, .09, 1.3
c26, 10, 2200, 2216, .06, 1.8
c9, 200, 330, 312.6 , .11, .7
c10, 200, 330, 305.5, .14, .4
c45, 10, 220, 236, .28, 2.0
c46, 25, 47, 48.7, .95, .9
c30, 35, 10, 10.96, 4.9, 4.1
C30 seems a bit funky at first look at the numbers.
Share this post
Link to post
Not to my knowledge, but I'm new at this.
Share this post
Link to post
We seem to have the same model.
I haven't even looked at the capacitors.  Does your transformer have orange grease/ goo on it?  I'm also curious about the voltages that you get out of the motherboard connector.
Share this post
Link to post
Using a 12 auto lamp (the kind for static timing adjustments) the new readings are:
Yellow  11.8 V
Blue 10.9 V
Red 4.3- 4.4  still some oscillation on this circuit.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
