Jump to content
Johnnya101
John's Classic Restoration Thread
Recommended Posts
Just got this from TechEdison the other day. :) Have been wanting a Classic for a while now. Will probably sell the SE that I was going to restore to fund this restoration instead.
This is the most yellowed compact I have ever laid my eyes on. How is it even possible to get this yellowed? The photos show it as a light beige. It is not. Its like a rotting banana almost. Its bad. Splotches of white all over. Baaaaaaad.
Not a sign of burn in AT ALL. Thats pretty amazing considering it is a lowly Classic. Tested it last night, 4MB ram but no sound :(. True survivor with original caps. Got to get those replaced. (Still havent found anyone to replace them yet... Anyone want to give this Classic a recap? ). The video was stable and bright, so I am not going to recap the analog board just yet, Ill wait and see what happens. Took the back off. Logic board has the caps just starting to leak. Its the cleanest compact Ive seen on the inside.
Classics dont tend to get the love they deserve. Hard to believe this was just (Without the ram expansion of course) under $1000.
First thing I have to do is find someone to recap the LB. Once that is sent out, I will retrobrite the case. It is baaaaaaaaaaaaaaaaad. Think i will try to find one of those huge seal-able clear bags and use that, but if not, Ill just brush it on. The front emblem is kind of faded, I dont mind it much besides the fact red is pink. Think Ill try and touch it up with a red marker? Ill clean and service the floppy drive, etc. Looks like a nice candidate for restoration. You dont see restored Classics that work too often.
Share this post
Link to post
Share on other sites
Its take apart time :)
Lets start.
First, get a Classic. These steps probably apply to the Classic II as well.
Open it up
Discharge the CRT
Remove memory card (If you have one)
Unplug hard drive cables
Unplug logic board cable (FINALLY Apple engineers realized the stupid setup in the earlier ones where it is buried inside. This one is easy to reach)
Pull logic board out a little
Disconnect floppy cable
Pull out logic board fully.
Unscrew the two analog board screws
Take note on how video board is installed
Remove ground lug screw
Remove video board (Sorry, no photo :/ )
Unplug both connectors.
Remove CRT screws
Remove chassis screws (There are 4)
Remove hard drive because you didnt notice that one of the chassis screws is hidden underneath.
Unscrew the last chassis screw
And its done
Pop out the Apple logo if you are retrobriting (Which I am)
Share this post
Link to post
The classic may not be a great mac but it was the prettiest compact mac and the most iconic in appearance
Edited by Bunsen
really excessive quote
Share this post
Link to post
I agree. Really, when you think about it, it's just a slightly faster Plus or SE with a hard drive and updated everything. For everything people use compacts for today, they are more than adequate. Besides the logic board caps always leaking, I can't seem to see why they are hated on. Oh, and I guess the capped expansion capabilities. But for most people, that's not an issue.
Share this post
Link to post
I agree with you, if anything they’re probably the best compact for nostalgia classic mac-ing its got a hhd, 1.44mb floppy, MacOS7.1 in rom and cheap to buy, making it easier to setup and just use than any other compact. If you dont want to mod your mac it makes perfect sense. I think the reason its disliked is because of what it signifies about apple at the time. I mean from the highes of the SE/30 and IIfx’s to some underwhelming yet over priced macs that followed as apple was losing its way. The classic was made so apple had a sub $1000 machine for schools and families to compete with cheap pc clones, yes it was a re hash of a 6 year old design in a new shell but that doesn’t mean it was bad. For me i love pimping my machines so SE/30 for me but over a 512, plus or an early SE with no hdd and 800k drives I’d go Classic especially as it is the best looking.
Edited by SE30_Neal
Share this post
Link to post
Yup. Couldn't agree more. I don't know what it is with the SE design, but it just does nothing for me. Plus and earlier, yeah they look great, the classics look amazing, but SE just looks... Weird. Just too boxy I guess.
Share this post
Link to post
Yup, doing that now. Its outside on some newspaper with brushed on cream. Ive been moving it around every 20 minutes and spraying water on it. I see loads of little bubbles so I know its working. Ill post a day 1 photo later.
Share this post
Link to post
Glad that thing is getting retrobrite. I agree it was quite intensely yellow. Would you believe me if I said my Plus was worse :lol:
im surprised at how much dust accumulated. I cleaned that thing inside quite extensively (with a dry toothbrush and damp paper towel).
My partial disassembly can be seen here:
the 68k also happens to be my profile pic.
Share this post
Link to post
I'll wash it off within the next hour and see how it did for today  and will post results. Definitely got the nasty yellowing out, appears to be a beige now.
I'll mask the emblem and go over the faded red with a sharpie.
Share this post
Link to post
It may need 2 attempts to get it back, mine did but I believe you’re weather is better in us that here in the uk which helps when doing retro brite
Edited by SE30_Neal
Share this post
Link to post
It will need a lot more than that, lol. Its orange almost. I was only able to have it out from 2-5 today, which isnt a whole long time. Ill try and get it out a few hours a day.
Share this post
Link to post
Well... It certainly looks better... You can tell what was facing the sun. Some streaking on the top. Exactly where my SE/30 has it. :/ Still a lot more deyellowing to do, so it should go away. Definitely doesn't look bleached. Cant get a better photo because this room has no lighting except for one small lamp. Plus, its dark out. Not much to see except the color difference.
Share this post
Link to post
Very nicely done. I have yet to experiment with Retrobrighting. Excellent take-apart pictures, i must say. It's been a while since I was inside a Classic.
Share this post
Link to post
I retrobrite differentlt from most and mine worked on all really well, its worth it to make it look original :) agree with you over Jonny’s great strip fown photos, great work
Share this post
Link to post
I just paint on the peroxide cheam from the bottle and then cling film it in so it doesn’t dry out, then leave it outside for a 1-4 hrs depending on how sunny it is.  I’ve done 3 computers and a few a accessories now and not one has gone wrong or streaky. I do check every hour and rub it to make sure no blobs appear.
that it, no mixes
Edited by SE30_Neal
Share this post
Link to post
Just simple Sally beauty supply 40 volume. Any lower and it will still work, just slower, any higher and you'll burn it. The white stuff, not the clear (I haven't heard of anyone using the clear, might work still though?)
Doing a session now inside in the heat with sun shining through the window and a UV lamp on it. Definitely getting brighter.
I don't typically recommend using cling film. I've had awful results using it. It's not worth the risk. Many others think the same. If the item fits in a ziplock bag though, just use that. A compact Mac is a little too big.
Share this post
Link to post
I use same as Jonny. My daughter works at a hair salon and gets me a generic 40% volume peroxide white cream.
i have a uv lamp which i have used but sunshine works better.
i have heard others having bad results with cling film but its worked perfectly for me with the neat cream.
like I mentioned I always check and turn items every hour and rub it to make sure no streaks occur.
Edited by SE30_Neal
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
