Sunoo Report post Posted January 2 I just got this NIC for an SE/30 that was sold as working, but I can't figure out who made it, so I can't get the right drivers. The seller claims to not know either. Any help would be greatly appreciated. Share this post Link to post Share on other sites
beachycove Report post Posted January 2 Install A/UX and it should work, plus give you the details with a little prodding. It only takes an hour or so, assuming you have the right gear. Share this post Link to post Share on other sites
Sunoo Report post Posted January 2 Are you saying this won't work in Mac OS? Or just that I need A/UX to identify the card? Share this post Link to post Share on other sites
Johnnya101 Report post Posted January 2 He’s saying AUX will give you the details. i think I have a card that looks the same. I used regular old Asante drivers and it worked. I’d try using those first, it’s quick and easy to check. Share this post Link to post Share on other sites
Sunoo Report post Posted January 2 Thanks, I'll give that a shot. Share this post Link to post Share on other sites
Bolle Report post Posted January 2 Fire up NewerTech SlotInfo and see what it tells you. Share this post Link to post Share on other sites
Sunoo Report post Posted January 2 Any suggestions where to find that? I'm coming up empty in my searches. Share this post Link to post Share on other sites
Sunoo Report post Posted January 2 I tried the Asante drivers, no luck. I couldn't find SlotInfo, but I found TattleTech, and it identifies as being made by A-Series? Share this post Link to post Share on other sites
Sunoo Report post Posted January 2 Okay, I found another thread where it said to use the Farallon drivers. I had that driver disk on hand, so I tried it, and it seems to be detected correctly now. Now I just need to find an ethernet cable and see if I can convince it to connect. Share this post Link to post Share on other sites
Johnnya101 Report post Posted January 2 Yours is very similar to mine. Same components for the most part, just moved around. And what do you know... Mine also says ASERIES V1.0! And it was Farallon I was thinking of, not Asante (as you found out yourself). Must have been some generic card sold back in the day. Share this post Link to post Share on other sites
SE30_Neal Report post Posted January 4 As long as it works! Share this post Link to post Share on other sites
