Jump to content
Crutch
Micron Xceed Color 30 fail
Recommended Posts
My recently acquired Xceed Color 30 worked a few times ... then started failing intermittently (popping noise from the analog board, and bright scan lines on the screen with no video) before failing completely (same symptoms, 100% of the time).
I noticed the IC at U1 gets extremely hot (painful to touch) quickly when powered up.  I'm hoping that replacing it will solve my problem...  two questions for people here smarter than me:
1.  That IC is labeled "TIT131FS F74".  I'm hoping it's one of these three flip flops.  Is there a way to tell which one?  Does it matter?
TI SN74F74D = https://www.mouser.com/ProductDetail/?qs=AMJt07B76usCaqNdeb4hlg%3d%3d
TI SN74F74DR = https://www.mouser.com/ProductDetail/?qs=sbcp%2f4gpy0%2bgzMKzFBFFrA%3d%3d
TI SN74F74DRG4 = https://www.mouser.com/ProductDetail/?qs=mE33ZKBHyE7Fs3ZxegDeVA%3d%3d
2.  Any thoughts on something else I might be missing?  Is replacing this IC actually likely to help?
Thanks for any help or ideas!
Share this post
Link to post
Share on other sites
I can't say if replacing it would help your problem or not, but when replacing 7400 series logic IC's (which includes this flip-flop) you should generally use parts from the same (or compatible) family. In your case, the family is 'F' (for Fast), so it can be replaced with any 'F' family 74xx74 IC. In other words, all of the replacements you listed should work fine.
Share this post
Link to post
Welp a 74F74 is a Dflop, and since its near the oscillators, its probably part of the frequency divider network.
Why it failed? really hard to say but I bet its not a lone-wolf. Hope it is, but eh i dunno.
Share this post
Link to post
I suppose the SE/30 works fine without the card?
If the card doesn’t receive the sync signals from the logicboard it will not work and I guess things will get weird.
Share this post
Link to post
Well unfortunately (not surprisingly) you were right TK.  I replaced the Dflop, and it no longer gets hot -- which seemed like great news until I hooked it up to the CRT again.  Same issue:  bright scan lines, no raster (see pic).
Here's the other thing that's happening (unchanged since before replacing the IC):  on power on, I hear a couple soft pops/sizzles that seem to be coming from around the flyback transformer, at which time (I just noticed tonight) I see the grounding wire connected to the screw at top left of the CRT wiggle perceptibly (see short video).  The wiggle happens at exactly the same time as the sizzle.  At that time using my meter I can also measure a sudden 5 mV potential between the CRT grounding screw and the chassis, which seems like it shouldn't happen and makes me wonder if some component on the board is shorted out to ground somewhere.  Nothing seems to get particularly warm since replacing U1, though, even after several minutes.
Any ideas much appreciated -- would hate to give up on this board!
(I hear the sizzle even without the grayscale adapter vertical CRT board connected, and all of the above happens with two different known good power supplies and analog boards, so it's definitely an issue with the Xceed Color 30 board.)
Share this post
Link to post
The slight hissing on powerup seems to be normal. My grayscale setup is doing this as well.
What happens when you install the card but don’t hook up the wiring and CRT board and run on stock harness and CRT board?
Does the card work with an external monitor when installed without the grayscale hardware?
Edited by Bolle
Share this post
Link to post
Thanks Bolle. I would never have guessed that hissing is normal!
When I install the card into my PDS slot but run with stock harness and CRT board, everything is fine.
You are implying maybe the problem is actually with the CRT board after all? I did test all the electrolytic caps on the CRT board with an ESR meter and they look good - maybe one of the transistors is bad?
I havent tested with an external monitor yet because I don’t have one - sounds like I should.
Share this post
Link to post
I was asking because there might have been the chance that it is a logicboard problem. I have seen boards giving those scrambled scan line picture exactly like yours once you install certain PDS cards.
The cards I did test were fine and the problem was somewhere with the logicboard as I ruled out all other possibilities.
You don't happen to have another logicboard you could try just in case though?
Also I get a short spike with visible scan lines when the CRT kicks in as well. Have you tried adjusting the cutoff on the analog board? Had to turn it down quite a bit when I installed the grayscale setup if I remember right.
Share this post
Link to post
Thanks Bolle (and thanks for the video). Good ideas but I just tried cranking down the cutoff (and also tried fiddling with the pot on the grayscale CRT board itself) with no luck. Also as it happens I do have a spare known good logic board - just swapped it in, also no luck there.
I had thought the pop/hiss from the analog board on startup is new since the Xceed card started failing ... but I wouldn’t swear to it. Maybe I just didn’t notice it when everything was fine.
I noticed Dead Mac Scolls pp 168-68 describes identical symptoms with stock equipment and points to either a bad IC on the analog board (but I’ve seen this with two analog boards that otherwise work) or a transistor on the stock CRT board, which is why I was considering desoldering and testing the three Xceed CRT board transistors next, for lack of any better ideas (and since I already tested the electrolytic caps). But better advice most welcome.
Share this post
Link to post
Way to go.
At least everything else has been ruled out now if the second logicboard is showing the same symptoms.
Share this post
Link to post
Aaaand I desoldered the three CRT board transistors to test them, and they seem fine. So I’m baffled. I could try getting an external monitor to see if the Color 30 card can drive it ... but honestly I’m not sure what I would do next if that worked or didn’t work!
Share this post
Link to post
I wouldn't totally rule out the video board yet.
You could hook up a scope to the input pin on the CRT board carrying the actual video signal and see if anything at all is coming in there.
If you have a signal there check the output of Q2 if the signal makes it through the amplifier circuit.
Micron Xceed Grayscale DIY
Share this post
Link to post
You need to verify the video card is "actually" working. The fact that you get that screen when hooked up into grayscale mode tells me the video card isnt driving the CRT. do you have a DB15 video harness for it? Maybe try an external monitor.
Share this post
Link to post
Thanks @Bolle and @techknight for this good advice.  I took a break from this project and just got back to it.  I did the following tests with the Micron card in the PDS slot and the harness connected, but no CRT board in place:
1.  I hooked up an external LCD with a VGA adapter to the Xceed’s external monitor port and was thrilled to see it worked perfectly.  But:
2.  I am not sure there’s a video signal coming out of the card to the CRT board.  I think the video should be on the yellow wire connected to the second pin from the bottom, rear row, on the white Molex connector on the card (Bolle, do we know how the pins are numbered in the diagram you linked, by chance?).  That pin looks very quiet on my scope.  I’m not sure exactly what a CRT video signal should look like, though — the one on the other yellow wire (coming out of the analog board, going to the pin just above on the Micron card, third from the bottom) looks like a high frequency signal bouncing around between 0 and about 1V.  Is that what I should be looking for?  If so, and I have the pins right, something is definitely wrong.  Absent a schematic for the video card, I’m not sure what else to do in that case, other than go Micron Xceed shopping again ....
Share this post
Link to post
Pretty sure video output to the CRT board is not switched on if there is no video board connected.
There is a sense line going there to see if the board is actually there or not:
Pin 3 on the card connector gets grounded once the CRT board is connected and that flips a bit in data registers (DBB2 is the internal screen sense line) on the card which I think is then read out by the driver to see if it should be switching to internal or external video modes:
Edited by Bolle
Share this post
Link to post
Wow thanks. Ok now I feel dumb for having the CRT board disconnected - I was being lazy (because I haven’t yet resoldered the transistors after removing them for testing) and thought I would “obviously” see a video signal even if it had nowhere to go. That’s great news though. I will reconnect the board and check that signal again!
Share this post
Link to post
Thanks again for that tip @Bolle. Unfortunately reconnecting the CRT board didn’t make a difference - I still see nothing on the video out pin. Poking around the Maxim video switch IC at U12, I find a good video in signal on pin 5 but nothing on pins 9 or 14 (video out). I am trying to figure out if maybe this IC is bad, or if it’s not getting whatever signal is supposed to be driving it to doing the “switching”. (The sense line DBB2 is indeed grounded by the CRT board.) Unfortunately I’m not sure exactly what the Maxim chip is supposed to be doing, beyond realizing its one of these: https://www.mouser.com/datasheet/2/256/IH5341-IH5352-255453.pdf
My external monitor continues working fine via VGA, just the internal screen shows nothing.
Share this post
Link to post
OK, I’m slowly learning how this is maybe supposed to work.
Per the spec sheet, it looks like the Maxim video switch IC at U12 should connect D1 (pin 3, “IOB”, maybe the “blue” channel which is used as then single channel for grayscale images?) to S1 (pin 14, “Vid Out”) if IN1 (pin 12, “In.Select1.GS”) is high, and should likewise connect D2 (pin 5, “Vid In”) to S2 (pin 9, connected to pin 14 so also “Vid Out”) if IN2 (pin 10, “In.Select2.Passthrough”) is high.  With an external display connected (and working fine), using my scope I can see that pin 10 “In.Select2.Passthrough” is at 4.2V (and pin 12, “In.Select1.GS” is at zero), but I have nothing on Vid Out despite a good signal on Vid In.  Also if I short pins 10 and 14 myself, I can see a gray desktop pattern on my internal display — so the CRT board is presumably good!
Next:  I unplugged the external monitor and rebooted.  Then I saw that pin 12, “In.Select1.GS” was at 4.2V (pin 10 is now at zero), but similarly there was no signal on “Vid Out” despite a (now) good signal on IOB.  So I manually shorted pin 3 (IOB) to pin 14 (Vid Out) and ... HEY LOOK a perfect grayscale image on my internal CRT!
This all makes me think U12 has to be dead.  It looks like that part is obsolete, unsurprisingly.  I wonder if there’s a suitable replacement available.  Otherwise I think I could permanently jump pin 3 to pin 14 on the Maxim chip, and I’d have workable internal grayscale albeit with no external monitor support (which I don’t really care about anyway).  What do you think?
(By the way, I haven’t done much other work on this particular SE/30, I’m wondering if the 4.2V levels on “high” signals indicate a bad PSU.)
Edited by Crutch
Share this post
Link to post
Nice error chasing going on right there.
Good to see the schematics were kind of useful and I didn’t waste all those hours buzzing them out. :tongue:
I would go with jumpering the signal until you run across a replacement part.
There still are switching ICs but you would have to look at datasheets on how they handle video (or higher frequency for the matter) signals.
I used some switching ICs to switch analog audio signals and they were fine for that... gotta look up what chip I used exactly and what frequency range they support. Also totally not sure if they would end up to be pin compatible with the Maxim chip.
Share this post
Link to post
Oh yes, I was remiss in not saying BIG thanks for the schematics ... I would have gotten nowhere without them.
Yeah I looked around but it looks like all the new analog switching ICs on Digikey/Mouser now use another package (not DIP-14) or have entirely different pinouts due to supporting more channels (plus to your point not obvious if they'd work for these video signals).  However I found someone in China selling the exact Maxim IC for $5 plus shipping on eBay.  I just ordered one, hope it's legit :) otherwise I'm following your advice and jumpering the signal.  Thanks again!!
Share this post
Link to post
Im just thrown this out there. Have you inspected the back of the Micron board? I have a couple Micron boards and one would not work. Tried all sorts of stuff until I noticed a through hole lead was bent and pressing on another causing a short. The leads on both my boards should have been cut shorter, many are way too long.
Share this post
Link to post
Thanks unity. I checked that (would have been good to have an explanation for the gradual failure of the board!) but the leads look OK, if slightly on the long side.
Share this post
Link to post
Many thanks once again @Bolle for all your help above. Today thanks to your assistance I replaced the Maxim video switch IHC5341CPD with a replacement IC I found on eBay, shipped from China but looks legit. After soldering it up, my Micron Xceed Color30 with grayscale adapter instantly works 100% perfectly. Attached is a photo of my repaired card, I had replaced U12 (Maxim chip)  and (earlier, because it was overheating) U1 (yeah you can tell I didn’t have a very steady hand when I surface-mounted my replacement IC at U1, but all the contacts are good and secure).
I feel pretty lucky to have a working grayscale adapter that didn’t cost me $2000. Now for an exciting game of Tetris Max ...
Share this post
Link to post
@Crutch I too have a Micron Xceed Color30 PDS video card and the official grayscale adapter.  I've noticed a horizontal "twitch" on my internal CRT (with the screen with decreasing and increasing very slightly (a couple millimeters only), yet quickly and somewhat noticeably).  I am thinking if could be the electrolytic capacitors on the grayscale yoke board that need to be replaced because when removed the Xceed video card and grayscale card and put the stock yoke board back in, I don't see the twitch anymore.  Have you noticed this horizontal twitch on your grayscale setup?
Another question...
To properly discharge the CRT, you are suppose to put the ground lead of the discharge tool to the ground lug in the upper left corner of the CRT and NEVER to connect it to the metal chassis, as that could zap the motherboard.  However, the Micron Xceed grayscale adapter splices the ground wire that leads to the CRT upper-right corner ground lug to the chassis ground!  In other words, the wire harness coming from the back of the Grayscale adapter connects chassis ground to the CRT upper-right ground lug.  I actually discharged the CRT a couple times without thinking.  I don't see any ill effects, but perhaps the bleeder resistor in my machine had already discharged the CRT before I manually tried it.  I would think it potentially could be a problem for the logic board.  Have you discharged your CRT with the motherboard still connected?  I'm really curious why they connect that CRT ground lug to the chassis ground.  It's a bit unsettling.
Thanks.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
