Jump to content
Sign in to follow this
travistouchdown
Factory 32mb Video Card for G4 Cube
Recommended Posts
So i've tried once to upgrade the video card for my G4 cube, which has 16mb VRAM from the factory.  I have found that the few other cards for G4 tower computers that technically *will* fit in the Cubes short AGP slot, but do not fit well, they need things removed, don't fit flush (ie are recessed and monitor cable doesn't plug in well), etc. etc.
The G4 cube supposedly had a factory 32MB options from two companies (source Low End Mac):
  • ATI Radeon with 32 MB of VRAM
  • Nvidia GeForce2 MX with 32 MB VRAM
Had anyone seen these in the wild ever?  Do both of them exist to peoples knowledge?
Would love to find one someday, but starting to lose hope on the factory upgrade card.
Share this post
Link to post
Share on other sites
Find an Apple Radeon 7500, take off the slot plate and throw it in.
No flashing necessary, totally supported in any OS a Cube can run, no hassle.
Unless you are constantly plugging/unplugging the monitor cable it will be fine. The Apple card supports ADC displays as well as VGA.
It's my favorite card to put into the Cube. Anything bigger/better/faster is wasted unless you have a CPU upgrade, etc. and I don't know if you want to get on the CPU/VRM/Fan treadmill with your Cube :-)
My 2 cents...
Edit - there's currently a seller on the 'Bay for $12.00 BIN with plenty available. I may buy a couple myself!
Edited by ScutBoy
Share this post
Link to post
I've got a Radeon 7500 in my Cube as well and it works great.  That being said, I feel like this is one of those situations where it would be silly not to pick up a few more of these.  $12.00 BIN with free shipping is probably the cheapest they'll ever be and since it looks like the seller has sold 267 of them you have to wonder just how many they have left.
https://www.ebay.com/itm/252074230275
Share this post
Link to post
I am running a Radeon 9250 in my Cube. It’s tiny, doesn’t use much power and it is as fast as it can get for OS9 in the Cube without stressing things.
I have a GeForce 4 Ti 4200 that can be made to fit the Cube and is accelerated in OS9 but I do not want to risk to blow the VRM and kill everything.
I have not yet seen the Cube Radeon in the wild yet but I do have some of the GeForce 2 cards right here.
The only thing that differs from the tower variants of those cards is the bezel.
You can swap those bezels around between genuine Apple cards no problem.
Share this post
Link to post
You guys are the best!
Going to snap up a 7500 today and attempt to put the baseplate from my 16mb factory card on it.  If not, oh well, I keep my 17" Studio Display plugged into the ADC port full time anyway.
Thanks again!
Share this post
Link to post
How does that card compare to my NVIDIA GeForce4MX. I may need a card for the QS when I set up the MDD a/o one for the DA when I play with it again. Dual Head 24bit at 1920x1200 off ADC and 1600x1200 off VGA under OS9 for Illustrator 9 would be the target.
7500s for $12, gotta get at least one I think, still have the Rage128 in the QS.
Share this post
Link to post
The connectors will likely not line up, but as I said, I put mine in without the backplate and it works fine. As you said, if you're not going to be constantly plugging/unplugging I don't  think  you'll have a problem.
Share this post
Link to post
So i get my new video card and DVD drive in and put everything back together, and sure enough my 80GB hard drive that I got a year ago from the headgap store dies on me!  Damn...if it's not thing it's the other.
I'd like to replace it with an SSD drive, any way to get that working with an IDE interface? Or even Compact Flash to IDE.  What are peoples thoughts on replacing HDD's at this time?  Seems like anything spinning is just bound to fail sooner rather than later, the QA not being what it used to be on these.
Share this post
Link to post
I used a SATA to IDE bridge in mine to put in an SSD:
https://www.microcenter.com/product/317195/sata-to-ide-bridge-board
The only downside is that that particular adapter was designed for a 3.5" SATA drive as opposed to a 2.5" SSD so the bracket I got to hold the drive in place doesn't fit.  I haven't had any issues yet with the drive just being loose inside though since it's not like I'm picking up my Cube and shaking it like a piggybank.
Share this post
Link to post
Thanks I will look into this.
So I tried my old 20GB drive last night with similar results.  The 80GB gives me the folder with a question mark, the 20GB gives me the disk with a question mark.  I guess it's not that big a stretch that both drives could have gone bad.  Still given that I switched the video card and replaced the internal DVD drive, could it be anything else I need to troubleshoot?
I've zapped the PRAM, and hit the reset button for the Real-Time-Clock on the motherboard. Anything else I could do to get this thing up and running short of a new HDD?  I know the 80GB is bad because of the noise it makes, the 20GB i'm not so sure... working on replacing them regardless but just wondering as it seems like a coincidence that they would both be out.  What magical key sequences should I be trying? :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
