Jump to content
Sign in to follow this
KnobsNSwitches
Ethertalk crossover cable
Recommended Posts
This is probably a dumb question. But I just want to make sure.
I've got a color classic running 7.5, and a PowerBook 1400 running 8.6. My file transfer method is usually modern computer-> compact flash into 1400 -> and then serial cable localtalk to color classic, (or for some bigger files, SCSI EZ135). But I did copy a CD ISO over localtalk and that...took forever.
If I got an ethernet card for the color classic, is it as simple as a cat5 crossover cable between the 1400 and the Color Classic to transfer files? No hubs or switches, no IP config, just go to the chooser?
Share this post
Link to post
Share on other sites
I am dealing with this right now and could not get a connection between my CC Mystique and Core2duo MacBook using a x-over cable.  I can ping back and forth but could never get it to connect in chooser.
Next thing I am going to try is going through a router with a non-x-over cable.
Share this post
Link to post
This guy on eBay has been selling off a huge lot of these cards for like two years. $10?? I bought three. Don't even worry about crossover cables.. Install Open Transport and Fetch, hook it into your LAN and then FTP/AppleShare over IP everything!
https://www.ebay.com/itm/Macintosh-Color-Classic-Ethernet-Card-Apple-LC-575-PDS-Farallon-New-Networking/231332620598?epid=1431958381&hash=item35dc7fa936:g:zSgAAOxyyFhTeL5i
You will need to do a bit of configuration but it looks like it's clearly outlined here:
http://appletothecore.me/files/color_classc_network_card_install.php
Edited by hfrazier
Share this post
Link to post
The crossover cables do indeed work, but, yes, configuration is necessary. It WILL work once you get things configured. Any issues setting AppleTalk to Ethernet or anything like that?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
