Jump to content
maceffects
Orange Micro NuBus PC Card - Need Help
Recommended Posts
I just found and bought an Orange Micro OrangePC NuBus 66mhz card, the seller says it looks like the 220 version but since it only has PCMICA card slots and no external connectors, I would assume it is actually just a 200.
Anyway, long story short, I am trying to figure out what software/drivers I need, and where to obtain them.
Member Charlieman stated in an earlier post:
*** OrangePC NuBus 200 Series
With the NuBus 200 Series, Orange adopted a "pick and mix" approach to features and processor speed. Depending on your budget, you could buy a 486 card with VGA or SVGA graphics, real serial and parallel ports and a PCMCIA expansion connector. The VGA/SVGA chip is provided by Video 7. The PCMCIA connector, which replaced the ISA slot on previous NuBus cards, was intended for a sound or network card, but other devices may work. Orange Micro advised users to use monolithic network drivers, rather than installing Card Bus or PCMCIA management drivers. Almost everyone who managed networked PCs in the early 1990s will agree with this recommendation. The cards have a single 72 pin SIMM slot and the processor can be upgraded. Orange Micro specified 32MB as the largest SIMM but it would be worth trying a 64MB or 128MB SIMM if you have one lying around.
The 210 is the entry level model with limited graphics capability (VGA) but a real serial and parallel port. The 250 has better graphics (SVGA) and a PCMCIA connector, but no serial or parallel ports. The 290 is the top of the range model with all of the functionality provided by cheaper models. A 220 model later appeared with similar functionality to the 210 but with SVGA graphics. Orange Micro's cards were more expensive than an Apple Houdini card of the same period, but had more PC compatibility (eg the ability to support software protection dongles).
The 200 series cannot use a separate monitor and video is displayed in a window on the Macintosh desktop or, for best performance, in full screen mode. A multiscan monitor that supports 640x480 and 800x600 resolution is required.
For your interest, this is the card I just purchased
(https://www.ebay.com/itm/302849838866)
Share this post
Link to post
Share on other sites
Share this post
Link to post
6 hours ago, Unknown_K said:
PS. I see it sold for best offer, how much?
Thanks for the help, I totally forgot about the internet archive. I thought the higher end models had connectors not just PCMICA like this one appears.  I won it for $100 which is pretty fair considering the rarity.  I have like $650 into my Quadra 950 and this will be the finishing touch.
Edited by maceffects
Share this post
Link to post
The higher end models of the 300/400 series do have an octopus cable with audio, serial, video, gameport , printer ports etc. That card is cool because it is the only one with pcmcia they made.
Share this post
Link to post
Interesting, I think there is a lot of incorrect info about the 200 series online.  I am thinking of finding a Sound Blaster PCMICA card, but I am not sure which might work for this unit.
https://www.ebay.com/itm/Creative-PCMCIA-Sound-Blaster-Audigy2-ZS-Notebook-Sound-Card/263890061942?epid=1808107520&hash=item3d7112ca76:g:zd8AAOSwV01bewRN&autorefresh=true
This one is PCMICA but shows it requires Windows XP...  I think I would be using Windows 95 so I am not sure if it would work.
Share this post
Link to post
I'd love one of these cards, been looking for years, 386 or 486.  Closest I've gotten is owning a Mac286 card, but it's limited to a low 286, CGA, 1MB RAM.
The Audigy2 PCMCIA sound card is 32-bit cardbus and not compatible with 16-bit slots.  16-bit PCMCIA sound cards are hard to come by, there are devices such as an OPL2LPT external parallel sound card that might do.
Share this post
Link to post
Cardbus have those round balls on the end and won't fit let alone work in a 16 bit PCMCIA slot. You are stuck with the usual modem/ethernet/scsi/wifi/special CDROM controllers for that slot.
I like collecting those Nubus OrangePC cards. Think I have (2) 386 models and (2) 486 ones.
Share this post
Link to post
Necro'ing this thread for a related question. I've got the same card (OrangePC 290) and I'm seeing visual artifacts appear soon after opening any program with graphics (e.g. Windows 3.1, Simcity). My guess is this is a VRAM issue, but I haven't stress tested this card to know if this happens after a while in DOS as well. Any ideas? Would I have to resolder new VRAM chips on?
Note on the 'A20 Hardware Error', I think that's from swapping in a 486 overdrive instead of 486dx2-66 rather than the video issue, but that's just a guess.
Share this post
Link to post
A20 is a keyboard error. I don't think that card has its own video chip or VRAM since there is no video out cable. The video is using the macs built in hardware for display. Does the card work 100% with the original CPU?
Share this post
Link to post
Same issue with the original 486dx2-66 (the solitaire image was from that). Interesting I didn't realize it used internal video but that makes sense.. I figured the two large chips to the bottom right of the 486 were VRAM but I guess they're the 128k cache the card comes with.
Sounds like I should swap back in the dx2 and see if the A20 error comes up again. I can also swap the RAM, haven't tried that. Any other ideas?
Share this post
Link to post
Ok, looked up that WD90c30 chip and it is a VGA chip. I had looked that CirisLogic chip up and it is not for video so I called it a day.
Share this post
Link to post
The Cirrus Logic chip is the PCMCIA controller. Note that it is impossible to make a 100% Sound Blaster compatible PC Card since the standard lacks any sort of DMA pins.
Share this post
Link to post
Ok so VGA and VRAM is on-board. Am I right in assuming the visual artifacts are likely VRAM related then? I've read about something like this happening before from other vintage hardware, but want to isolate the problem best I can before I go looking for new chips & someone to fix it. Thanks!
Share this post
Link to post
Curious card. Has anyone got a version with the IC implemented on the pads far left or botttom right? PCMCIA alone seems quite a limited choice for I/O on the backplane.
Share this post
Link to post
I have that card (or somewhat close):
Mine has all the chips filled and I noticed the CPU has an added voltage regulator with heatsink (for dx4 chips).
1286434746_OrangeMicro2520Orange2520PC252034025202528Nubus2529.thumb.jpg.6085b8c5b8643b4d801a05c0ee6edbc9.jpg
Share this post
Link to post
The last NuBus model was the 340, which could take a DX2, DX4, or 586 processor. Nice card. Had a built in Soundblaster compatible chip, audio line out/in, etc...
400+ series were PCI only. 660 was the last one made.
Edited by Paralel
Share this post
Link to post
And now for a bit of hijacking... (I promise I won’t take long).
The latest OrangePC card is the 660, correct? And can it support a PIII? There are reports online of such a setup but it might be just fake... if it’s not I need one of those for my Quicksilver.
Share this post
Link to post
Regarding the 660: Support for Intel Pentium MMX and classic Pentium 100-233 MHz, Cyrix 6x86MX, 6x86L, 6x86 PR166-233, MII PR266-300, AMD K5, K6, K6-2 166-450 MHz, AMD K6-3 400 MHz.
So, K6-3, not P3.
Share this post
Link to post
If you do want a Pentium III on a card, you'll need to look a little newer than OrangeMicro and a little bit away from Macs. Sun had the PCi line of compatibility cards and they went all the way to the Athlon XP. I've got a pair of IIpros here based on a 733 MHz S370 Celeron. Fun cards since they're often faster than the host computer they're in (like an Ultra 5 in my case).
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
