Jump to content
Welcome Back! - Read Me First Read more... ×
KnobsNSwitches
Sonnet 68030 PDS accelerator driver ?
Recommended Posts
I have acquired a Sonnet accelerator with an 030, I've found a couple pages that refer to this as an Allegro, which is a name the also used on some USB cards later on, but I haven't found software to enable it yet. Does any one have a link? All I have found are presto plus drivers.
Thanks!
Share this post
Link to post
Share on other sites
I wonder if we contacted Sonnet they might provide/release their ancient driver collection to the retro-computing community? Probably too much to ask, but maybe the source code too?
Share this post
Link to post
Well, a technician at Sonnet was most helpful when I contacted them in regards to the cable for the Encore/ZIF. He sent me the wiring diagram in PDF format.
I suppose that there is no harm in tying.
Share this post
Link to post
Great find! Nothing else I tried had the downloads available, but I got the Cache Reset utility for my Crescendo L2. Didn't even know there was a problem, hoping it might help with my seemingly dead accelerators.
Share this post
Link to post
Not sure you even not a driver for those.
The 030 at least should just work and in case there is cache on there that should also just work (at least it does on most LC accelerators)
Share this post
Link to post
I know it has been a while.
I did a quick search, this is what I have online, I searched for Sonnet.
I also checked my massive optical collection and attached a txt file with the results. Sorry I did not go through the results but maybe something is there for you.
If you know the precise name of the file I might have it but I need a file name to be more effective.
hypercard_sonnets
hypercard_sonnets_meta.sqlite
hypercard_sonnets_meta.xml
pr071609_sonnettakescaiou.html
Sassys Sonne.ttf
Sonne.ttf
Sonnet Technologies, Inc.
Sonnet Technologies, Inc..webarchive
sonnet_bkgnd-jp.pdf
sonnet_bkgnd.pdf
sonnet_blk.eps.hqx
sonnet_blk.eps.zip
sonnet_clr_rvrs.eps.hqx
sonnet_clr.eps.hqx
sonnet_clr.gif.hqx
Sonnet_Crescendo_7200_1.0.hqx
sonnet_firmware_updater_v31.pkg.zip
sonnet_firmware_updater_v32.dmg.zip
sonnet_ipodbattery.eps.zip
sonnet_logo.sit
sonnet_logos_and_products
sonnet_pci_x_update_v126.hqx
sonnet_sata10.pkg.sit
sonnet_sata12.pkg.zip
sonnet_sata202.pkg.zip
sonnet_sata203.pkg.zip
sonnet_sata204b1.pkg.zip
sonnet_ships_2nd_gen_g3_pr.pdf
sonnet_warranty0608.pdf
sonnet_wht.eps.hqx
sonnet_wht.eps.zip
sonnet_x_tuneup_v127.hqx
sonnet_y2k.pdf
sonnetcache_v13.pkg.sit
sonnetcache_v131.pkg.sit
sonnetcache_v131.pkg.zip
SonnetCache1.4b1RM.pdf
sonnetcache14.pkg.zip
sonnetcache14b1.pkg.zip
sonnetlogo
sonnetlogo.eps.hqx
sonnetlogo.gif.hqx
sonnetraid_linux318.zip
sonnetraid_linux321.zip
sonnetraid_mac321.zip
sonnetraid_win318.zip
sonnetraid_win321.zip
Sonnets.hqx
wayback sonnet
www.sonnettech.com
Sonnet Search Results.txt
Share this post
Link to post
Nice work! Unfortunately, neither "Allegro" nor "Presto" is mentioned in the readme I found and posted in a new topic in Peripherals:
The Sonnet Card Drivers Thread
I've had problems getting a couple of L2 cards up and running. I found the update history very informative. Is there a unified driver (supports several cards/accelerators) for their 030 era offerings?
Sonnet acquired products from other companies in the early days, might this be one of those and the drivers for it available under the original brand/product name?
Edited by Trash80toHP_Mini
the usual
Share this post
Link to post
Thanks!
I did a "contents" search for "030" and I am attaching what came up. Maybe this helps you narrow down the search to something more concrete. As I understand it, the card (called an Allegro by Sonnet) is installed in a Mac (please mention which Mac it is and the OS installed) but the card is not operating and/or visible by the system and therefore not working as expected so you've come to the conclusion that you might need a driver. Is this correct?
Also, if possible, please attach photos of the card itself. It might help gather more details.
As mentioned, include the Mac you inserted the card into and what OS version it is running as this too can shed some light on why the card is not operational but I am going to attach what I find here:
I included a PDF that mentions an Allegro card.
I also attached what I believe is the related software.
I am searching some MacWorld and other Magazines from '94 to see if the name Allegro comes up. Whatever else I find I will let you know.
chart.pdf
allegro_v11_se30.hqx
allegro_v11_se30.sit.hqx
allegro_v12_macii.hqx
allegro_v12_macii.sit.hqx
allegro_v28_se_lc.sit.hqx
Allegro.hqx
Share this post
Link to post
Alex, thank you for your detective work. The ads from MacAddict are fantastic.
I have some results to share! The short version: the card seems to work, NO extensions needed.
I've tried the 2 different allegro extensions I've found (with handy '030!' icons and all), and both system 7.1. and 7.5.3 hang on startup when reaching that extension.
I had trouble tracking down a copy of Metronome to verify speeds but thanks to the posters here I got a copy.
I had installed the sonnet card originally in my Color Classic, and without metronome to verify, it didn't seem to be working. I also have a performa 550 board for the CC, and installing that is a night and day difference; you can feel the speed. Installing the alegro in the color classic didn't seem any different. Also, in the CC the card got very hot.
But I did some further experimenting with an LC II.
Here's the stock LC IIIMG_5864.thumb.JPG.aa336755fa27d439f39a6f2617fc7e9a.JPG
Here's with the card installed and all extensions off:
And finally another test with extensions on (not the Allegro one, just my 7.1.1 set), I just thought this was a funny result. I think my copy of metronome might be a bit too optimistic here:
Edited by KnobsNSwitches
Share this post
Link to post
Makes perfect sense: p.304 of DCaDftMF3e (Designing Cards and Drivers for the Macintosh Family third edition)
• Table 14-1 PDS expansion connector signal descriptions for the Macintosh LC
/HALT  -  Signal indicating that 68020 processor should suspend all bus activity.
Haven't looked at the LC PDS interface and its signals in a very long time. Yank on that brake line and the train stops, switches engines and is off and running Simply fast.
Share this post
Link to post
Ah, the DCaDftMF3e, a volume we all have on the shelf ;-)
This reminds me, what would be a good way to benchmark compare the 550 logic board vs this card in a Color Classic? I mean, my standard benchmark would basically be launch Marathon, but I'm not sure that even runs at 512x384. I can't recall any ancient history version of geekbench but I'm sure there was...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
