Bolle Report post Posted July 9, 2018 Thickness is the issue I think. I have a few cheapo ROM SIMMs in 1.2mm and 1.6mm thickness. The first is too thin to make good contact and the latter will only fit into the slot with some force. The original seems to be 1.4mm if I remember right. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 9, 2018 Not tried it yet lago the wife had other plans for my evening and not in a good way, chores and being taxi to the kids oh well, anyway interesting is it poor design then as surely 95% of them would be used in se/30’s at the prime candidate for needing 32 bit clean rom and having 128mb expansion capabilities? I suppose we should be happy someone even designed it at all! Ok I’ll get more bands from work and maybe some blutac as a wedge. Thanks for that as I don’t want to keep opening the case. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 9, 2018 Thanks bolle, shame it doesn’t work that well Share this post Link to post Share on other sites
trag Report post Posted July 9, 2018 My memory says that old time SIMMs should be .050" thick which is .050 X 25.4 = 1.27mm. So one should probably aim for 1.3mm. 1.6mm would be the more modern .063" thickness, which is what the PCB companies default to. If you don't specify, you get 1.6mm thick. I don't think it should be possible to wedge 1.6mm board into a .05" socket. Unless there's more than one kind of 64 pin SIMM socket? When I ran off my batch of IIfx SIMMs, I specified .05" thick and they fit the sockets just right. I've never tried plugging one into a ROM SIMM socket though. I'll try to remember to do that when I get home. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 9, 2018 Let me know how you get on by the way thumbs up to the IIFX cracking machine if only i had space Share this post Link to post Share on other sites
trag Report post Posted July 10, 2018 I put one of my unpopulated IIfx SIMMs into a IICX ROM socket and it fit very snugly, but properly. I should have thought to try one of the ROMinator SIMMs I have in the same socket for comparison. Anyway, point behind last night's test is that .05" thick works great in the IICX ROM socket. Leaves me wondering what thickness was used for the ROMinator. I would have tested in an SE/30 but don't have one easy to hand at the moment. The IICX should have the same socket installed. Share this post Link to post Share on other sites
trag Report post Posted July 11, 2018 Okay, tried the ROMinator SIMMs in the IIcx and they fit less snugly, but the fit seems good enough. I don't think elastic would be needed to make it work. The ROMinator looks slightly less thick to the eye than my .050" boards, but putting them edge to edge, I can't feel a difference. I wonder if the difference in thickness is .047" vs. .050". I've seen some PCB houses offer .047" instead of .050". I'm not sure how much difference 3 mils would make. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 On 7/9/2018 at 9:34 AM, lagomorphonic said: SE30_Neal if you're going to use an elastic band you'll need to make sure it *really* pulls on the card. I had to triple up the bands on mine and still occasionally will need to press on the ROM-inator on bootup (the corner of is is just barely accessible if the case is open. Get something non-conductive and press it forward if the rubber bands alone don't work just to see if that's the problem). Ideally I will put some tiny solder blobs on each of the pins at some point to help maintain the tension. It's a bit annoying that these are "known to be faulty by design" for use in the SE/30 considering it is probably one of the most desirable old Macs for it to be used in. So logo are you saying i need to solder blobs to the contacts at the bottom for better contact? I have no problem with getting that does as i cant be doing taking it apart all the time? Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 1 hour ago, trag said: Okay, tried the ROMinator SIMMs in the IIcx and they fit less snugly, but the fit seems good enough. I don't think elastic would be needed to make it work. The ROMinator looks slightly less thick to the eye than my .050" boards, but putting them edge to edge, I can't feel a difference. I wonder if the difference in thickness is .047" vs. .050". I've seen some PCB houses offer .047" instead of .050". I'm not sure how much difference 3 mils would make. Hi trag I believe its an se/30 only issue the rominator site mentions a simm shim for se/30 but I’ve googled that i get nothing so I’m at a loss about what that is Share this post Link to post Share on other sites
Bolle Report post Posted July 11, 2018 If you decide to solder little blobs onto the SIMM be sure to solder them onto the backside, otherwise it might actually make things worse for some SIMM sockets. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 19 minutes ago, Bolle said: If you decide to solder little blobs onto the SIMM be sure to solder them onto the backside, otherwise it might actually make things worse for some SIMM sockets. Thanks Bolle, back side, is that the side with the skull or the side with the chips? Do you think blobs of solder will work? Share this post Link to post Share on other sites
Bolle Report post Posted July 11, 2018 I have done so on some of my ROM SIMMs and it makes it better (but still not really 100% perfect) Backside should be the one without chips. The front of the ROM is facing towards the burn-in connector of the logicboard when inserted into the socket. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 Ok thought so im no electronics person but my sister is ex ministry of defence electronics specialist so I’ll get her to solder it for me otherwise there’d be blobs every where lol do you need to add much? If i grt it soldered and use bands hopefully that will be enough Share this post Link to post Share on other sites
Bolle Report post Posted July 11, 2018 (edited) Here is a SIMM with blobs compared to one without: Edited July 11, 2018 by Bolle Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 Thanks Bolle, that really helps being able to see it, yes i see its a bit of pain but think i get this done the weekend. brilliant i hope it’s enough neal Share this post Link to post Share on other sites
joethezombie Report post Posted July 11, 2018 2 hours ago, SE30_Neal said: I believe its an se/30 only issue the rominator site mentions a simm shim for se/30 but I’ve googled that i get nothing If you download the ROMinator II manual, it details the issue on the last couple of pages. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 11, 2018 1 minute ago, joethezombie said: If you download the ROMinator II manual, it details the issue on the last couple of pages. Thanks buddy Share this post Link to post Share on other sites
trag Report post Posted July 12, 2018 22 hours ago, joethezombie said: If you download the ROMinator II manual, it details the issue on the last couple of pages. Ah, got it, read it. I see that the manual clearly states the socket in the SE/30 is a little different from in other models. I think I may experiment with replacing the ROM socket with a new one. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 12, 2018 37 minutes ago, trag said: Ah, got it, read it. I see that the manual clearly states the socket in the SE/30 is a little different from in other models. I think I may experiment with replacing the ROM socket with a new one. Yes i read that too but only after buying it and unsuccessfully installing it, taking the simm to my sisters this weekend to add solder to the contacts to help it fit better. Share this post Link to post Share on other sites
pb3623 Report post Posted July 13, 2018 I've tried everything from the paper clip "spring," to the rubber band, to a trimmed-down plastic card/shim and the fit still leaves something to be desired... sometimes mine doesn't chime at all or, if it does (after a whack to the right side), it's not stable until I pop the case, take out the board and give the ROM a tune-up, fit-wise. I don't blame Doug for the design at all - it's got to be a tough supply chain and next to impossible to capture like .76 mm (the difference between .50" and .47" as you noted above) like 25+ years later. Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 13, 2018 On 7/12/2018 at 12:14 AM, joethezombie said: If you download the ROMinator II manual, it details the issue on the last couple of pages. Thanks buddy much appreciated Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 13, 2018 Thanks Pb, i might try to make a plastic shim as well as solder the pins. Why would apple make it different only on the se/30 thats so annoying Share this post Link to post Share on other sites
lagomorphonic Report post Posted July 23, 2018 Sorry I haven't been in in awhile. Looks like you got yourself quite sorted SE30_Neal? Did soldering the pins work? I haven't had the chance yet. I've been too busy/lazy. I just leave my case lid open and press on the ROM-inator manually if it doesn't work! The rubber bands I had in place stopped working Share this post Link to post Share on other sites
SE30_Neal Report post Posted July 24, 2018 On 7/12/2018 at 12:14 AM, joethezombie said: If you download the ROMinator II manual, it details the issue on the last couple of pages. Yes i’ve had the pins soldered, not had chance to get it fitted yet as ive been away, back yesterday so should be able to try over the next few days. Will let you know. Share this post Link to post Share on other sites
seanrox Report post Posted May 15 (edited) I know it's been awhile for any follow up comments in this thread, however I recently had the same issue with my ROMinator not being snug in the SE/30 ROM socket. Check out this thread, specifically this comment for some nifty 3d printed holders which is the solution I went with and works great without the worry of rubber bands breaking at some point, like during a record setting game of Crystal Quest As a side note, you can also use small binder clips, which I did prior to the 3d printed clips. If you go this route, be sure to put some electrical tape on the metal part of the binder clips to avoid any possible short from the metal clip touching something it shouldn't. Edited May 15 by seanrox Share this post Link to post Share on other sites
