Jump to content
Sign in to follow this
Tempest
G4 Cube or G3 iMac for Gaming?
Recommended Posts
I own two Macs and I want to know which would be better for OS 9/X gaming? A 600Mhz iMac G3 or a 450MHz G4 Cube? The Cube has a GeForce 6200 card and 1.5GB of memory. I'm not sure what the iMac has only 128MB of RAM but I can upgrade that.   My gut says the G4 cube, especially for OS X stuff, but I don't know how limited the cube is for OS 9 games.
Share this post
Link to post
Share on other sites
Just now, Tempest said:
GeForce 6200
Completely useless in OS 9 with that if you want any acceleration.
I am running a Radeon 9250 in my Cube which is accelerated in OS 9 and works reasonably well in OSX while staying cool.
While I could have gone for a flashed GeForce 4 TI 4200 to get the maximum of graphics power with full OS 9 support it would kill the Cube in no time due to power draw and heat output.
Share this post
Link to post
Do many OS 9 games require acceleration?
I'm thinking that the iMac is the way to go honestly.  Maybe it's time to sell the cube?  How much do they normally go with a 6200?
Share this post
Link to post
You might want to add a fan to that iMac if you plan on doing a lot of gaming on it. My 400Mhz DV overheats pretty badly after half an hour or so of Simcity 3000...
Share this post
Link to post
Both are a good choice with pros and cons, but the Cube can have a bigger external monitor which is nice.  While the iMacs can run on the hotter side, I wouldn't worry too much as long as you have a solid a/b.
Share this post
Link to post
I'd say both, but dedicate the iMac to OS 9 and the G4 Cube to OS X.  The iMac shouldn't overheat unless there is a hardware issue/fault - it was designed to run in a fanless state.
Later PPC games (with relatively high system requirements) I've found do struggle on the Cube, FPS games in particular - Halo is pretty terrible.   Quake II and III engine games should just run but forget anything after that.  The (flashed) Geforce 6200 is 64-bit as well so it won't be chugging out high detail or frames unless at a low resolution. A CPU upgraded Cube would crank out higher frames but the GPU (which is a great card for the Cube) will hamper things.
Edited by Byrd
Share this post
Link to post
Yeah that's what I'm thinking.  But I'm not terribly interested in playing cross platform games (I have a DOS box for that) I want to play Mac specific titles and I think those are mostly OS 9 so I'll probably stick with the iMac.
New question: How hard is it to upgrade a G3 Beige Tower?  I'd rather use that than the iMac due to space.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
