Jump to content
toples50
PowerBook 5300ce startup problem
Recommended Posts
Can be a problem in the charging board area.
There is a daughter board where the battery comes in contact for charging purposes, a lot of capacitors in there, if the board is missing or bad, the 5300 won't boot.
Share this post
Link to post
Share on other sites
The 5300 is easy to open.
Remove the Floppy drive and the battery.
There is a couple of screws in the bottom, lift the keyboard, remove the side plastic hinge covers and trackpad.
The battery and Pram battery are on the right, but IIRC the HD should be removed also.
Share this post
Link to post
I don't know where you can find a new PRAM battery, IIRC those are not the common ones, but are rechargeables batteries.
Share this post
Link to post
Thanks guys.Is it worthy to keep the machine and fix it or to sell it?Is it rare the ce model?The hinges are very strong for 5300...
Share this post
Link to post
This model was the top of the range, i think only had seen one for real.
The Cs and C are common, not the Ce.
The Pram battery is not required to boot, better removed it anyway.
Did you tried the reset switch on the back ?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
