Jump to content
Sign in to follow this
mpe
Macintosh Plus keeps tripping RCD
Recommended Posts
I recently acquired a Macintosh Plus (version with the international 220V analog board - as I am in UK).
It seems to be working fine. However, there is a strange issue with it.
When switched off and connected to a wall socket (the switch on the back is off) it always after a couple of minutes keeps tripping RCD fuse in my house. So it looks like it is leaking current to ground somewhere.
It is not the power cable. I tried to visually inspect the analog board, measure input voltage and ground using a multimeter and did not find anything suspicious or obviously broken.
Any ideas?
Share this post
Link to post
Share on other sites
probable C33 and C36 these will be cracked after all the years of service and create a shortcut.
you can remove the capacitors, you can test the mac without them,
Share this post
Link to post
Thanks. C33 and C36. Is that on the original board? The only scheme I found is for the 120V board where this part is actually slightly different. Anyway, I guess these are two small line filter caps (4700 pico farad, Y class) just next to the power inlet. I will try to replace them.
Share this post
Link to post
C33 and C36 are the numbers for the international board. these are the 4700 pf line filter caps
Edited by marcelv
Share this post
Link to post
Replaced C33/C36 and the board seems to be fine now. Thanks!
These were relatively easy to replace. I even didn't have to take the board out. I am happy I didn't have to replace the bigger caps...
Originals don't look too good:
Edited by mpe
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
