Jump to content
reallyrandy
512k Floppy Drive won't eject
Recommended Posts
I have a 512k that I'm restoring and the floppy reads fine but will not eject. When I manually eject with a paper clip, the disk gets stuck and won't come out. So I cracked the case and removed the drive and carefully removed the disk without damaging it.
When I manually push the eject tab, the drive pops upward but does not propel the disk forward. Not sure if I can (or want to) fix it if I can find a good working one. If one of you guys fixes stuff like this, we could make a deal. I'm assuming it's a 400k drive since it came out of a 512k.
Here's pics:
Share this post
Link to post
Share on other sites
I used sadmanonatrain's guide to completely remove the carrier.  It's not hard, 4 screws and a clip.  Then, you can soak it in solvent and work the bits back in forth to completely remove the old grease.  Reassemble and then carefully add a small amount of new grease to the contact points.
https://drive.google.com/file/d/0B6j6P7lBWw-BNHQ4dXRYZkFGdzQ/edit
Share this post
Link to post
Or spray some WD-40 on the contact points (making sure to not get overspray on the drive head). Work it around, wipe down, and put on some new lithium grease. It saves the effort of having to disassemble.
Share this post
Link to post
I used WD40 on my Macintosh 128K drive with the same problem and it totally fixed it.  However now every-time I run it there is definitely a WD40 smell coming from the drive.  Its been 2 years and it is still there.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
