Jump to content
Trash80toHP_Mini
MicroMac Performer Redux: Cloning a 68030 Accelerator for Compact Macs
Recommended Posts
It seems yours is only running the CPU at 16MHz then and the crystal only sets the speed of the 882. It is like that on my board as well.
As I discovered when going through the PAK/3 stuff the 68000 bus interface GALs as well as the 030 state machine GALs are different for either 16MHz or async 32-50MHz operation of the 030.
It is highly likely our two boards will be the same.
The 030 clock state machine looks like it is syncing the memory accesses of the 030 to either 68000 bus accesses using /AS_00, 030 bus accesses using /AS_30, Cache access using MAT0 and MAT2 or 030 ROM access.
It also generates the 68k syncronous bus cycle signal /CYC_00 which is fed into the 68000 bus statemachine.
In the end it generates /DSACK0..1 to tell the 030 that data is ready to be read from the bus.
The CPU and FPU clock itself are directly fed into the 030, 882 and clock state machine from a crystal can - EXTCLK in my diagrams.
Share this post
Link to post
Share on other sites
Interesting, you identified the functions of GALs on you board, could you tell me the names/functions of mine so I can label them?
I'm wondering if different formulas in the 68000state machine can change the multiplier? Mine could be run at a 3x multiplier of 25MHz without changing its oddball (for a 16MHz board) 25MHz Crystal Can?
With a 50MHz oscillator, would the GALs be capable of running the CPU at 32-50(48?)MHz?
Do my functional diagrams make it easier or harder for you to see the processes than reading from a conventional schematic or about the same? I remember your diagram from the ProtoCache1 PM thread, IIRC it wasn't linear like the Eagle representations? You said something to the effect that you liked to see the flow of things(?) in a schematic tweaked to show the interactions? That schematic I could see/read a lot better than the linear Eagle type representation. Maybe it's because the only schematics I've tried to read were Apple's engineering drawings and the multiple page IIsi schematic I pieced together into one very long graphic.
U6 (68000 state machine?) is driving CLK on my board's 68030 at 16MHz, not the 25MHz Crystal Can?
Edited by Trash80toHP_Mini
Share this post
Link to post
What do you think about the notion that my tiny, but very flexible (supports Plus, SE and Classic connector installations) Accelerator could be tweaked to run in the Luggable? Dropping the Plus and Classic permutations of its three way bus and only supporting a Luggable translation of the SE PDS connector for fitment would be trivial. Clocking tweaked in the GALs for the "async 32-50MHz operation of the 030" from the Luggable's 16MHz PDS/bus clock would be non-trivial, but possible?
If I can get a PerformerMini up and running in the Luggable, then a miniaturization quest to fit it on the PowerBook 100 Processor/2MB stock RAM daughterboard could ensue? That thread was the genesis of this impossible dream after all! :ph34r:
Share this post
Link to post
That Luggable Slot is some kinda kluge, I tried a NuBus Card with the pin and row markings in it. First it was sitting backwards, plate cover to the front. Second, its pin numbering is the reverse of NuBus, but Row "A" remains on the bottom. Was anything other than the unobtanium SE PDS Card Expansion Cage interface card made for the Portable PDS?
I think I may have it sorted out now, but what a mess! Has anyone got a link to a picture of such a rare thing as this kind of unicorn poop? Got the pics set up for a good look at it when things slow down at work tomorrow.
68000 <-> Luggable PDS connections don't look too horrible, weird as all get out going by a couple of signal names, dunno.
SE PDS <-> Luggable PDS comparison comes next, If they're as similar as DCaDftMF says, that would be a good thing.
The Performer speaks SE PDS, let's see if we can get it to speak Portable PDS. Not worried about the 16M clock signal of the Portable. Looks like the GALs on my Performer might just double that 16MHz input to 32MHz on the 68030's CLK line as it presently doubles the Plus/SE 8MHz clock to 16MHz on 68030 CLK. [}:)]
Tired of buzzing connections and playing in AI for a bit. Taking a side trip into PowerBook 100 Fantasy Land, extrapolating from what might not quite be impossible dreaming for a Luggable PerformerMini. PB100 PerformerMicro would be the bombe.
the usual
Share this post
Link to post
Had another look at EvilCapitalist's thread:
He posted a great shot of his SE Accelerator, looks like it may have pads (buffers and SRAM) for unimplemented Cache. Has anybody got one with the Cache on board? The first thing that struck me was the four GALs with Pads for an unimplemented (empty) PLCC socket config:
Gals config might have been the first thing on my first visit to that thread, but I've had GALs on the brain lately. :/
Third thing that struck me was that populated ASIC socket, I just HATE finding those ICs on a board! :p
the usual
Share this post
Link to post
Just PM'd these questions to techknight, our resident Portable guru. But any feedback at all here would be greatly appreciated. Especially so as it will relate directly to GAL implementations:
These might be the last hardware pieces to inscrutable Performer in Luggable research posted above.
PDS-Signals_Page.PDF
The SE PDS linkage of Reset/Halt to same on "68000 IC/PDS" is clear, but on the Portable PDS it's not straightforward.
/SYS.RST Initiates a system reset.
It looks to me like the simplicity of the Reset/Halt linkage on SE PDS to 68000 "PDS" might be penciled in as indirectly linked to 68000 "PDS" in the Portable via connection to the Powe Manager IC so it doesn't poleaxe the system processes but acts more like:
/SYS.PWR A signal from the Power Manager IC that causes associated circuits to tristate their outputs and go into the idle state; /SYS.PWR is pulled high (deasserted) during sleep state.
WAG: this last discrepancy between the PDS implementations might be ignored?
/DELAY.CS Input indicating that system is inserting wait states; can be used to gate chip selects.
In the system state where the 68030 on the Performer is running the show while the Portable's CPU is disabled it should be unnecessary. The only thing that makes any sense to me about that signal would be its enabling the Portable's CPU to gate chip selects on a PDS card while running the card's driver routines?
Dunno, I'm winging it here as usual, whatcha think?
edit: ignore the blue lines on the diagram in my last post, the answer to that ? was "please erase me!" but I'd highlighted the pencil lines in sharpie for the scan before I found the answer. :/
boo-boo abatement/the usual
Share this post
Link to post
Forgot to mention that the answer to the /DTAK - /EXT.DTAK question implied by info on the diagram probably falls into the "68000 has been poleaxed, Performer uses /DTAK internally: ignore me!" category.
edit: uses it "internally" in the process of running the I/O data acquisition bus of the Luggable on its own.
the usual
Share this post
Link to post
I know the /DELAY.CS is used for the RAM on the portable as its slower than the rest of the BUS, but I forget the EXACT usage details.
It is described in the macintosh developer notes for this model.
Share this post
Link to post
Does it use another type of RAM than the PowerBook 100's PSRAM? Is PSRAM slower than SRAM and DRAM? Very strange. Here we go diving into the DevNotes again. :wacko:
I'm proceeding under the assumption that SE PDS /Reset=/Halt signal yanking on the Portable's /SYS.RST line will be andled fine by the Power Manager IC.
Does the rest of the 1:1 control line signal comparison between SE and Portable PDS slots look right to you?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
