Jump to content
Sign in to follow this
CVKealey
M2115 service manual?
Recommended Posts
Anyone happen to have a service manual for the M2115 external SCSI HDD? I have two of them I've reassembled from pieces and can't seem to get them to work. The problem is that I can't seem to figure out where the scsi ID switch connects. I think it should connect to the drive itself, but can't see where. Any help would be appreciated.
Share this post
Link to post
Share on other sites
On 1/27/2018 at 7:56 PM, IlikeTech said:
Before you go attaching the switch, try using a jumper to change the drive ID and see if it works.
Actually, I found the original drives that came out of the enclosures which have the appropriate header for the ID selector switch. What I was hoping to use the enclosure for is testing some 2.5" SCSI drives. I have the correct 50-pin-to-34-pin adapter board, and I believe have the ID jumpers set correctly to make the drive show up as ID 2, but they weren't showing up at all. I'm not sure if the controller in the M2115 is toast, but now that I've found the right drive, I can verify if that's the case or not.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
