Jump to content
Sign in to follow this
Trash80toHP_Mini
PowerBook 100 Accelerator Insanity
Recommended Posts
There's some very strange things going on in that RAM expansion connector pinout. Lots of duplicate data and address signals, what the heck is that all about?
Gotta rearrange that pinout into groups by function.
Edited by Trash80toHP_Mini
Share this post
Link to post
Share on other sites
3 hours ago, techknight said:
I love this thread.But....
1. I am more of a portable guy.
2. I wish I had a PB100, but finding one in decent condition with a decent LCD is way out of my budget so...
I will follow and help where I can, but thats limited.
THX, I'm having a blast! [:D] I've got that beat up PartsBook 100 with the bullet riddled (two rounds) screen that I'd swap for some Portable resurrection work if you wanna play along in this insane thread. [:)]
Have you got anything worked out on what the Portable uses for a memory controller or how it's set up outside of the slot docs? I can't find any info on a schematic for either Luggable or PowerBook 100 anywhere? Even the SE setup ought to be helpful, but so far I've got bopkes.
Outside of brute forcing the GALs, the easiest part of the project will be reverse engineering the Performer. That'd make a nice standalone hack in itself. And then to start building upon that foundation. Gotta track down another Performer to lobotomize. :ph34r:
the usual
Share this post
Link to post
PB100-RAM Connector Pinout-Grouped
25____A1___Address bit  1 (buffered)
23____A2___Address bit  2 (buffered)
21____A3___Address bit  3 (buffered)
19____A4___Address bit  4 (buffered)
17____A5___Address bit  5 (buffered)
15____A6___Address bit  6 (buffered)
13____A7___Address bit  7 (buffered)
11____A8___Address bit  8 (buffered)
14____A9___Address bit  9 (buffered)
16___A10___Address bit 10 (buffered)
22___A11­­­___Address bit 11 (buffered)
18___A12___Address bit 12 (buffered)
  9___A13___Address bit 13 (buffered)
12___A14___Address bit 14 (buffered)
  7___A15___Address bit 15 (buffered)
  4___A16___Address bit 16 (buffered)
  5___A17___Address bit 17 (buffered)
  6___A18___Address bit 18 (buffered)
  3___A19___Address bit 19 (buffered)
  8___/LW___Lower byte write strobe
10___/LW___Lower byte write strobe
47___/UW___Upper byte write strobe
48___/UW___Upper byte write strobe
20___/OE.RFSH___RAM output enable and refresh
24___/EXP.CS0___Chip select bit 0
34___/EXP.CS1___Chip select bit 1
50___/EXP.CS2___Chip select bit 2
70___/EXP.CS3___Chip select bit 3
51___/EXP.CS4___Chip select bit 4
45___/EXP.CS5___Chip select bit 5
27____D0___Data bit  0 (buffered) to and from main logic board
39____D0___Data bit  0 (buffered) to and from main logic board
29____D1___Data bit  1 (buffered) to and from main logic board
40____D1___Data bit  1 (buffered) to and from main logic board
37____D2___Data bit  2 (buffered) to and from main logic board
31____D2___Data bit  2 (buffered) to and from main logic board
38____D3___Data bit  3 (buffered) to and from main logic board
36____D3___Data bit  3 (buffered) to and from main logic board
32____D4___Data bit  4 (buffered) to and from main logic board
35____D4___Data bit  4 (buffered) to and from main logic board
30____D5___Data bit  5 (buffered) to and from main logic board
44____D5___Data bit  5 (buffered) to and from main logic board
28____D6___Data bit  6 (buffered) to and from main logic board
42____D6___Data bit  6 (buffered) to and from main logic board
26____D7___Data bit  7 (buffered) to and from main logic board
41____D7___Data bit  7 (buffered) to and from main logic board
57____D8___Data bit  8 (buffered) to and from main logic board
64____D8___Data bit  8 (buffered) to and from main logic board
59____D9___Data bit  9 (buffered) to and from main logic board
66____D9___Data bit  9 (buffered) to and from main logic board
61___D10___Data bit 10 (buffered) to and from main logic board
68___D10___Data bit 10 (buffered) to and from main logic board
53___D11___Data bit 11 (buffered) to and from main logic board
67___D11___Data bit 11 (buffered) to and from main logic board
54___D12___Data bit 12 (buffered) to and from main logic board
65___D12___Data bit 12 (buffered) to and from main logic board
56___D13___Data bit 13 (buffered) to and from main logic board
63___D13___Data bit 13 (buffered) to and from main logic board
55___D14___Data bit 14 (buffered) to and from main logic board
58___D14___Data bit 14 (buffered) to and from main logic board
60___D15___Data bit 15 (buffered) to and from main logic board
62___D15___Data bit 15 (buffered) to and from main logic board
  1___GND___Ground
  2___GND___Ground
69___GND___Ground
33___GND___Ground
49___nc___No  connection
52___nc___No  connection
43___+5V___+5V  RAM  power
46___+5V___+5V  RAM  power
I guess the address lines only need to be buffered one way, but the data needs bi-directional buffering. That makes sense, it'll be interesting to look into why there appear to be two data buses. WAG at this point would be that 4MB on the expansion card has its own bus and that the other 2MB share their data bus with the 2MB on the main logic board.
I like that, "main logic board" sounds a lot better and has a more specific meaning than "daughterboard." The other is now the "RAM board" for the same reason. "Memory expansion card" leaves a lot to be desired.
Share this post
Link to post
HRMMM?
Chapter 1    Macintosh PowerBook 100 Hardware
Note:
If you design your RAM expansion card correctly, it will also work in future Macintosh-family, 68030-based portable computers. A 68030-based machine has a 32-bit data bus, whereas the 68HC000 in the Macintosh PowerBook 100 has only a 16-bit data bus. You should design the expansion card as a 32-bit device, but if you correctly partition the data lines and chip select lines on the card, you can use the same card in either type of machine without loss of performance.  The card should have 32  data lines coming out to its connector, and the chip select lines for the upper 16 data bits and the lower 16 data bits should be separated to allow for individual selection of either the upper 16 bits or the lower 16 bits of data. The separated chip select lines are necessary for the Macintosh PowerBook 100 because it can get access to only 16 bits at a time. A 68030-based machine does not require separated chip select lines because it has a 32-bit data bus; therefore, the lines are tied back together on the computer’s main logic board.
This is gonna take some thinking about. Anybody got a handle on this paragraph? Sounds a bit like the 16 doubled up data lines are a 32bit bus if looked at in terms of a 68030 board and they would be high and low 16bit chunks to the 68HC000 of the PB100?
Share this post
Link to post
Maybe this will be closer to the way it may work. Sorted so the top set has the lower pin number for each bit.
May need to take a look at how they group on the double row connector? Dunno, it's a start. :blink:
Share this post
Link to post
On 1/14/2018 at 7:08 AM, techknight said:
Good thing is, the RAM could be connected to the 030, and used in 030 style decoding. Dont need the UDS/LDS 16-bit switching as needed on the standard bus, so it would be wired behind that logic.
Elaborating on that decoding method would be most helpful. Avoiding memory controller portion of the CPU Glu ASIC's complications and doing all memory ops directly off the 68030's internal bus would almost be too good to be true.
Might need to retain the stock 2MB of PSRAM on the accelerator to POST though?
I'm VERY curious about how the Compact Mac accelerators address SIMMs on board? Can anyone clue me in on that?
Share this post
Link to post
You do remember this one right here, don't you?
4 GALs to handle everything.
Another 4 GALs for the RAM.
I think we talked about this before. RAM is sitting on the 030 bus - all 4 SIMMs have to be populated at once.
The Mac will not work without memory on the main logicboard if I remember correctly. It really shouldn't as the memory on the accelerator is software activated and only works together with Compact Virtual.
Share this post
Link to post
Sweet! Nope, I forgot about the Quesse card with that nifty RAM daughtercard. How convenient is THAT! [:D]
I see a tad more than the four GALs.
HCT74 -  Dual D-Type Positive-Edge-Triggered Flip-Flop (if I'm misreading HC174, which is the same think in Hex)
________ probably part of the GAL based Memory Controller setup? Positioning makes me think there's nothing else on that side.
HCT245 - Octal Bus Transceiver 3-State Outputs:  I see one pair, I bet another pair is hidden underneath the SIMM
________ driving/buffering that interboard connector setup on the 32 bit data bus would be my guess.
You haven't got one in your collection do you, Bolle?
Does anyone? Posting some HiRes pics of both sides sans SIMMs would be a wonderful thing.
Share this post
Link to post
The accelerators usually used the on-board ram as a virtual memory/disk routed via the MMU.
Trash: I know the portable inside and out. Not the backlit, but the non-backlit. the MISC GLU does the bank switching/decoding for the on-board RAM. My portable, I removed the buffer ICs and changed the CPLD code on my RAM card and actually "took over" the 1MB of onboard RAM. That knocked me down to 8MB, but it ran faster as the on board-RAM is slower than what I used in my RAM card.
I also have the pinouts for BOTH LCD panels, Never got around to it, but I was going to adapt a backlit cable for a non-backlit display for testing boards.
Edited by techknight
Share this post
Link to post
I'm guessing the version with the optional memory upgrade card is an early edition. PCB's (c)1990, what's the date on yours?
Any HiRes pics you can post of it would be greatly appreciated. I'm especially curious about the Bus Transceiver or lack thereof on your board. For just the SIMM interface they might not be necessary on yours, but between that and the interboard connector they'd almost certainly be required on the one above.
Share this post
Link to post
Yep, that's why I was wondering early on if the Luggable and PB100 would be compatible with Compact Virtual, given the extra memory to play with. [;)]
That's another reason I recently figured that we couldn't do without the stock 2MB of PSRAM. It's almost certainly needed for the 68030 running in "68000 mode" to pass POST and then to set Compact Virtual in motion for addressing expanded memory.
Quote
That's exactly why I was elated to see you interested in this project. Thanks, I'd skimmed the docs on the two ASICS. I misinterpreted the verbiage and missed the thin lines connecting the entire memory subsystem to Misc.GLU:
Miscellaneous GLU logic chip
The Miscellaneous GLU logic chip provides random logic functions
such as modem–serial port multiplexing, pseudostatic RAM chip
select and refresh, and the clock control logic functions associated
with the Power Manager system.
Quote
Studying the saga of your MemCard's development is definitely on my reading list. [:)]
the usual
Share this post
Link to post
We know the PowerCache runs in the SE/30 sans mobo CPU, but does it still need a driver to let itself know that it's NOT just the stock CPU? I always figured the drivers were only needed to set up the Cache?
I've been guessing that the Performer will run in place of the 68000 at boot time, but it will still need drivers to let it know it's a 68030, not the stock 68000? I'm wondering if the "Mac" only sees the Performer as a fast 68000 if it's installed in place of the CPU without driver support?
Do Socketed and PDS adapted PowerCache accelerators use the same drivers? If so, is there a mechanism to let the driver know not to shut down the stock CPU for one and to do so for the other?
Is it as simple as grabbing hold of one of the stock processor's control lines and not letting go? Getting mixed up a bit, but ISTR something like that being mentioned somewhere. :blink:
Wondering if the Performer might hang when there's no longer a stock CPU to shut down?
the usual
Share this post
Link to post
It's a larger board with integrated RAM sockets and completely different CPU/FPU positions, dated 1988:
Edited by itsvince725
Share this post
Link to post
Nice! I only see two, are there two more SIMMs on the other side of the board? Is that empty socket labeled 68020?
The later version seems a lot more tightly integrated with but a handful of GALs/PALs/whatever. GALs were a new thing in '85. In '88 you've got all that discrete DIP logic/DIP PALs or Gals and then just two years later everything is simplified into a few SMT GALs and a handful of SMT standard logic ICs!
edit: forgot to ask for BIG piccies! [:D]
the usual
Share this post
Link to post
That would be much appreciated! Maybe getting a look at the way the logic is set up on yours will give some clues as to what's going on in the more tightly integrated later version.
Just realized I really need to downshift and cruise for a bit here. I'm not used to seeing anywhere near this much participation in one of my hacks threads. I'm getting a little manic, not good. :mellow:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
