Jump to content
Alex
Quadra 950 Capacitor burned (C26)
Recommended Posts
On 1/15/2018 at 2:00 AM, Franklinstein said:
No idea what that cap actually does other than explode.
I love your reply! I hear you are an old timer on here. Great that you are back. A little humor is always amazing. No, but I read your whole answer of course and appreciate it!
Kind regards
—Alex
Share this post
Link to post
Share on other sites
According to the datasheet the input voltage should be between 7 to 25 volt. 16v seems plausible.
However, choosing a capacitor with a lower ripple rating than the original can cause stress in the capacitor and make it fail again. So sometimes choosing the cheapest capacitor can break things. Also, choosing a capacitor with a higher max temperature and rated longer life will usually help.
This video explains a lot of the capacitor differences and why it matters to choose the correct one (and why some blows ;)): https://www.youtube.com/watch?v=ZAbOHFYRFGg
Really interesting :)
Share this post
Link to post
Great video, I am still watching but in terms on tantalum, it appears that Tantalum Polymer is the way to go. Tantalum MnO2 (do blow up) are less and less popular, likely because Tant Polymers are used more and more in phones and tablets but not only for that reason, Tantalum Polymers don't blow up.
The presenter in the video does not recommend Tantalum MnO2 and he suggested the following (what he termed as his real point)
  • If you use a Tantalum MnO2 don't apply more than half the rated voltage. (get a higher rated part)
  • If you use a Tantalum Polymer reduce the rated voltage by 10% – 20%. (get a higher rated part)
So yes, a very interesting video, I learned quite a bit and some of it was over my head.
Edited by Alex
Share this post
Link to post
So now, after this video I went to Kemet.com and am wondering which part to settle on; https://search.kemet.com/component-edge/#/browsing?search=47uF 6.3v&id=353
I did a search for 47uF 6.3v
I should be ordering according to a derating guideline of 20%(>10v), 10%(≤10V). The other part that confuses me is the ESR/Impedance value, I have no idea what it should be. We never discussed that part of things in this thread. Any ideas?
Someone help pick the right cap please :)
Edited by Alex
Share this post
Link to post
Just a quick update. I believe I figured it out.
I think I meant tolerance and I believe the lower the better and the same applies with ESR, the lower the better. I just wanted to put this extra bit of knowledge here.
Share this post
Link to post
Also pay attention to package size.   You want a capacitor that will conveniently fit on the old pads and not be too short, nor too long.   I can't tell for sure, but from the photo it looks like you need a size D or similar.
ESR is sort of the internal resistance of the capacitor.   Capacitors charge and discharge at different speeds, depending on the capacitance and resistance that they see in the circuit.   A capacitor with a higher ESR is likely to respond more slowly, (charge or discharge more slowly) because the ESR adds to the R in the 1/RC time equation.    But for large capacitance bypass caps, a slower response time may actually be desirable.  In the low capacitance (1 - 100 picofarad) bypass caps meant to compensate for high frequency voltage/current variations, a low ESR is much more important.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
