Jump to content
MacFox
Powerbook G3 "Main Street" Long Startup
Recommended Posts
Over a year ago, I bought a Powerbook G3 Main Street (the one with the passive matrix screen).  Since I owned it, it takes a long time to start up.  When I plug it in, the HDD starts up immediately and the power light comes on and then the HDD stops.  I press the power button, hear the startup chime, and then silence for the next two minutes.  After two minutes the HDD starts up again and the screen turns on and everything is normal.  The computer runs fine otherwise.  At first I thought it was just a quirk of this particular model, but now I'm beginning to wonder if maybe something is wrong.  I tired replacing the HDD and nothing changes.  Maybe it's nothing, but I thought I would ask here for your opinion on the matter.
Share this post
Link to post
Share on other sites
It's normal for PBG3 WallStreet/MainStreet to do so when PRAM battery is old or just dead. Try reset PRAM, leave it plugged on power block for a while , or change the PRAM battery (not so easy on the WallStreet...).
Edited by galgot
Share this post
Link to post
It's most likely the startup RAM test; you can disable this check by holding down command + option when double clicking the Memory Control Panel, then deselect the start up test
Share this post
Link to post
Mine also does the first part when you plug it in and the HDD spins for a second.  I think as pointed out it is because of the dead PRAM battery.  They are rechargeable but I have 3 PBG3s and none of them will charge.  They are a pain to replace in the first gen models but a bit easier in the lombard/bronze keyboard models.  Of course the cells are pricey.  I wish there was an alternative.   Mine, however, turn on and boot right away.  There is not a 2 minute delay.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
