Jump to content
td75
Mac 128k blown fuse on analog board
Recommended Posts
Hi everyone! I'm new to this forum and was hoping someone could help..
I recently acquired an original Mac 128k in good condition but unfortunately does not turn on. I found a bit of corrosion on some of the traces on the analog board which I have cleaned up. I also found the fuse was blown on the analog board and the fuse holders both fell apart when I removed the fuse. The capacitors all look good, no leaking or bulging. I have now replaced the fuse holders and fuse (1.6A 250V slow blow) but unfortunately the fuse blows as soon as I turn it on :( Is this the correct fuse? This is what I removed so assume is correct..
Any idea what component/s could be faulty that would cause the fuse to blow? Is it worth replacing all the capacitors on these analog boards even if they look good?
The original owner said the Mac worked when they last used it about 10 years ago! He said he thought it may just need a PRAM battery fitted as this was taken out. I remember reading somewhere that these Mac's can still turn on without PRAM battery fitted, but may be wrong..
Any help would be greatly appreciated!
Share this post
Link to post
Share on other sites
Thanks for your reply. I will get all the caps replaced and see if this helps.
Is there any way I can test the fly back transformer for faults using a multimeter? If it is faulty any idea if they are repairable or still an available part?
Share this post
Link to post
You can indeed do a basic test with an ohmmeter. See the Classic Mac Repair Guide for the details.
That said, the probability of the flyback being the problem is somewhat low. It's not zero, but the current-limiting circuits in the power supply should act to prevent drawing enough primary current to pop the fuse. Again using the ohmmeter, verify that the bridge rectifier and main filter capacitor aren't shorted. Ditto for the SCR. Do a careful visual inspection of the board (both sides) to see if there are any tell-tale signs of overheating that might be a clue.
Share this post
Link to post
A fuse that blows instantly almost always means a shorted component on the primary side of the power supply. The most common is the chopper transistor which will be a power transistor or MOSFET on a heatsink near the big filter capacitors on the input side. It could also be a shorted main filter cap or a bad rectifier but the chopper is the first thing I'd check.
A fault on the output side will usually cause the power supply to shut down. Often there will be a soft chirping or ticking sound if you listen carefully, as the supply tries repeatedly to come up but shuts down. Some early switching power supplies, notably those used in the Apple II will whine audibly under this condition.
Share this post
Link to post
Yup, exactly. The "chopper" device in the classic macs is Q11 in the Repair Guide. The SCR often goes south along with Q11, which is why it's mentioned. But Q11 should definitely be checked, as you advise. Q9, too, is frequently a victim.
Share this post
Link to post
Thanks for all the advice on this. I will hopefully get a chance over the weekend to do more tests. Will update as soon as I have tested all the components & hopefully find the culprit!
Share this post
Link to post
Had another look at the board tonight and found two diodes shorting out in position CR24 & CR25 on bridge rectifier. Have replaced all four diodes CR22 - CR25 with part 1N4007.
Have also found CR20 and CR21 rectifiers are faulty. Have read the filter capacitors C24-C26 and C29-C31 are also weak spots. So will get all these replaced.
Is it best to replace all the capacitors on the analog board or just the filter caps? Hopefully this will solve the power issues..
Share this post
Link to post
Sounds like you've made a lot of progress -- congrats!
The only other cap I'd bother with on the analog board is C1. If the others look ok, you can probably leave them be. Once you get the thing to power up, you'll be in a better position to evaluate what other steps (if any) you need to take.
Keep going!
Share this post
Link to post
Have now also replaced CR20 & CR21 rectifiers. Fuse no longer blows! But Mac doesn't turn on either :( Speaker is just making a clicking noise now. I have a C1 capacitor (part no ECWF2395JB) on order but I think there must be something else at fault as the current C1 cap does seem okay.
Share this post
Link to post
I am not sure where you are but I have an original analog board with CRT pulled from a dead motherboard unit if you need it. It has been tested with a 512 and a plus motherboard, but it is out of a 128.
Share this post
Link to post
Thank you very much for your offer - I'm based in the UK. It's really difficult to find replacement parts here in the UK, I guess parts are becoming scarce worldwide.
BTW is there an option to get an email when someone reply to a post?
Share this post
Link to post
I think in the preferences for PM's and such you can receive emails. I get them, I probably set it up when I first signed on so I don't know exactly where in the settings.
The board is yours if you want it, but that little crt makes it twice as heavy, I could remove the yoke from it but you could weigh yours to see if trying to get this one is worth it for you. I am not using it and you are more than welcome to it. Last thing I sent over the water over there was expensive but its your call.
Share this post
Link to post
Shipping a CRT overseas is going to be risky and expensive, but there is no reason you can't separate the board and the tube. I'm sure there are others here who could use a good tube for their compact Mac.
Clicking likely means the power supply is starting up and shutting down repeatedly. Look for shorted components on the secondary side, particularly the rectifier diodes on the outputs and the horizontal drive transistor in the monitor section.
Share this post
Link to post
Yes probably wouldn't be worth shipping a CRT but the power supply would definitely help :) I don't even know if the logic board and CRT are working till I can get this to turn on..
I won't give up yet! I will keep looking and will probably end up replacing every component on this board!
Could a faulty CRT or logic board prevent power supply turning on?
Share this post
Link to post
A fault in the logic board could. It's not common, but a shorted IC could cause the supply to shut down and tick like that. It would be extremely unlikely for a CRT to fail in such a way as to cause this. As long as the vacuum is intact, the tube is probably fine.
Share this post
Link to post
Don't do that -- use test equipment and logic to narrow down the suspects. Judicious use of an ohmmeter will get you very far, so you don't need very sophisticated equipment for the majority of problems.
Did you check the SCR, for example? It frequently is destroyed by other faults with the power supply. If you've fixed the original problem, but not replaced a shorted SCR, you'll get symptoms very similar to what you seem to be reporting.
Also, make sure that the voltage adjustment pot hasn't been turned to a high voltage setting. That, too, will trigger a periodic shutdown behavior. I recommend setting the pot to the minimum voltage setting to start. Viewed from the foil side of the analog board, that corresponds to a maximally clockwise position (the opposite of what one might expect).
Check for short circuits across any of the supplies.
The CRT is highly unlikely to be a source of this problem. However, do check the logic board. Once again, a simple ohmmeter check will be revealing.
Share this post
Link to post
Thanks for your suggestions. I only have a basic multimeter so can do some basic testing. Do you know where the SCR is on the power supply and any idea how I can test if this is faulty?
Also I replaced CR20 and CR21 rectifiers as they tested faulty with diode test in circuit. After replacing with new rectifiers they still show faulty with diode test, i.e. current passes both ways, but when removed from circuit they work correctly. Is this correct or is there a fault here?
Share this post
Link to post
Have been testing around the rectifiers and wondering if the transformer T3 is faulty? Looks like a sticky residue on it and not sure if this is normal? Also how would I test if this is faulty?
Share this post
Link to post
He says that the speaker is clicking, not the power supply.
Share this post
Link to post
speaker is clicking because the voltage is pulsing. The power supply is tripping into overcurrent and restarting. there is an RC time constant that determines when it restarts.
Anyway, that could mean any one of the rails has been shorted, or low impedence to ground. ohm meter will tell this. I am thinking sweep circuit, maybe a shorted HOT, or floppy drive, something... could be anything.
and in rare cases, it could be a component on the primary chopper side causing false overcurrent or false start conditions, which I tend to lean more towards due to the fact that the recitifiers were shorted, could have been a lightning or a surge victim.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
