Jump to content
feeef
9500 SSD Benchmarks
Recommended Posts
Hi,
I have been benchmarking my upgraded 9500 (G4/700) just to see how it did compare to other models (or basically to the original 9500). I used macbench 5.0 under 7.6.1 but it only let me test the CPU and the hard drive.
So, I tried to run the tests with 2 different hard drives. One is the SCSI drive that came with the 9500, the other is a 60GB SATA SSD drive connected through a sonnet tempo SATA adapter.
Here are the results with the SCSI drive. It does almost as good as the G3/300 :
and here it is with the SSD drive :
The speed difference is quite impressive! This setup would be perfect if I didn't have a sound issue with the SSD controller though... so I don't really use it otherwise I cannot listen to my MP3s :p
Share this post
Link to post
Share on other sites
Has anyone else tried running an SSD in a 9500? I brought my 9500 (acquired in 2012) to my condo to live with me full-time recently and was thinking about disk upgrades. SCSI2SD is an option, though I'd presume access times would be faster with a Tempo ATA card and an SSD.
Share this post
Link to post
Bit off topic,
Ive been testing 10,000 rpm 80 pin SCSI HDD in older macs - works really well.
The 8600 and G4 MDD both has Sonnet PCI SATA card with SSD - it does flies - Love the way MDD runs.
G4 MDD has SanDisk SATA SSD HDD.
8600 has m.2 SATA card.
PowerBook G3 Pismo has 44-mSATA card in it.
PowerBook PDQ and Kanga has 44-SD card.
FYI - SCSI2SD is v5.
Cheers
AP
Edited by AlpineRaven
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
