Jump to content
Sign in to follow this
agg23
Mac SE with CD?
Recommended Posts
Can you use an external CD with a Macintosh SE? I need some way to take data over to it until I get my other floppy-enabled mac out.
Thanks,
agg23
Share this post
Link to post
Share on other sites
Yes. Find yourself a slow SCSI CD drive (say, 2x or 4x, max), and it should work. If you encounter a driver problem, the "CD Sunrise" driver works well with many third-party drives. There's no audio CD support with that driver, but since you're just looking to transfer data, that shouldn't be a problem.
Share this post
Link to post
I took a cd drive out of a old PowerMac 7100, stuck it in a external case, and hooked it to my SE. I booted up and it can't read any cds. Apple HD setup (or whatever it's called) sees it as a drive that needs to be initialized. Do I just need that "CD Sunrise" driver?
Thanks,
agg23
Share this post
Link to post
Yes, but keep two points in mind:
1.) Apple-branded SCSI drives will probably work better
2.) You can't start up the Mac from a CD
Share this post
Link to post
It is Apple-branded, but it is an internal used as an external.
I don't really care.
Thanks
Share this post
Link to post
I'm not really sure why you felt the need to tell me that, but oh well.
I don't know either :)
I am running 6.0.5. I am still trying to find a way to copy the sunrise driver to a floppy (my other Macs are in our garage).
Share this post
Link to post
You will have difficulty reading many discs if you are using system 6 (I recommend upgrading to 6.0.8 in any case). You will need to find the desktop manager init and place it in your system 6 folder. This will avoid your getting stuck in a loop in which the OS attempts to rebuild the desktop of the CD.
Beyond that, you will need to observe the usual Rules of SCSI, amended for the Compacts: Have the external drive supply termination power; make sure that a terminator is present; make sure that each device on the bus has a unique ID; sacrifice a chicken.
Share this post
Link to post
A few of notes:
- CD Sunrise will only support HFS CDs. So ensure that you are creating HFS CDs if you are using a CD drive to transfer files onto the SE.
- Apple's CD driver will support ISO CDs, but it only supports Apple branded drives IIRC. It is the drive that matters, not the enclosure.
- Apple CD-ROM drives will be no more and no less reliable than third party drives. If you do run into an issue, it will be because of a SCSI ID issue or termination issue.
- Try using the serial ports to transfer small files. Not only is it bi-directional, but you won't fill landfills with as much crap.
Share this post
Link to post
Another good option, although not free, is FWB CD-ROM Toolkit. Versions earlier than 2.0 will work on both System 6 and 68000 processors. I currently have an Apple CD 300e attached to a Classic with this as my driver, although I use it for audio CDs. I've used 300e drives on machines as early as the Plus without any problems.
As for booting up with CDs, most machines made before 1990 cannot do this. There should be a list somewhere online of the Macs that can or cannot boot from a CD. If not, I believe the list is in Charles Rubin's "What do I do Now?" book, which was part of the Macintosh Bible series.
Share this post
Link to post
That might work because I have an Apple CD 300i Plus that I'm trying to use.
What do you mean by that???
Share this post
Link to post
I install the CD Sunrise driver today with System 6.0.8 and when I stuck a CD in the drive I get a error of some sort (I can't remember right now). What else could I try?
Thanks,
agg23
Share this post
Link to post
What kind of CD did you try? Are you sure it's undamaged? Is it a burned CD, or a factory-pressed one? If the former, expect trouble in older drives.
Is it an HFS disc? HFS+? ISO? The more information you can provide, the more likely someone can offer specific advice.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
