Jump to content
macosten
520c: Help Needed
Recommended Posts
Better to flip back to original position since Vmain is 1.5A. With only 1A you may run out of power when using floppy drive with backlight at max intensity for example... and it will stress your power supply uselessly ;)
Edited by tjjq44
Share this post
Link to post
Share on other sites
Alright. Luckily I used duct tape to seal my bodgework so while it looks like a growth it does work (for the time being) and I can just take the tape off to reverse it.
Do you suggest I just dremel the PSU brick open, or should I still try getting it apart with a flathead screwdriver (despite already having chipped the plastic)?
Edited by macosten
Share this post
Link to post
For what it's worth, I bought a IBM 16V 4.5A PSU on eBay, and connected the red & orange wires from the Powerbook cable to the positive, and everything else to negative.
My Powerbook 520 works just fine.
Although since the batteries are dead, I can't say if the charge circuit is fully working.....
Here's the one I bought:
https://www.ebay.com/itm/GENUINE-IBM-02K6657-02K6669-16V-4-5A-ThinkPad-AC-Power-Adapter-Charger-OEM/252818420883?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140107095009%26meid%3Ddf53b130a53e4c909fc21325c44da5dd%26pid%3D100040%26rk%3D1%26rkt%3D4%26mehot%3Dlo%26sd%3D263471999128%26itm%3D252818420883&_trksid=p2046732.c100040.m2060
--jim
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
