Jump to content
SCSI2SD and Apple IIGS?
  • Please log in to reply
30 replies to this topic
#1 agent_js03
agent_js03
  • 6502
Posted 03 March 2017 - 05:27 PM
I have a SCSI2SD card which I am currently using in my LC III.
A coworker of mine has given me a complete Apple IIGS system complete with printer and a buttload of software. It has a SCSI card installed but the hard drive it came with does not work. According to the codesrc website:
http://www.codesrc.c...p?title=SCSI2SD
the SCSI2SD should work in the Apple IIGS with my SCSI interface card. When I google about it, I have found many people who have photos of their IIgs booting GS/OS from their SCSI2SD. But none of them go into detail on how they managed to set up the disk in the first place. There is a lot more info on the macintosh. I know one guy said he transferred hard disk images to it via ADTPro, but that doesn't explain how he set up the partitioning in the first place.
I am wondering what I need to do to get the partitions right and get format/initialize the sd card for my Apple IIGS (rom 01). Anyone  have any good links? I have a Copy II plus disk and some other disk utilities. Maybe those will help.
Thanks in advance
#2 NJRoadfan
NJRoadfan
  • 68000
Posted 03 March 2017 - 05:43 PM
Which SCSI card is installed? The RamFAST has a ROM based setup/formatter you can use.
#3 agent_js03
agent_js03
  • 6502
Posted 03 March 2017 - 07:04 PM
I am pretty sure it is the Apple II high-speed scsi card. I will check when I get home. It looks like the picture anyways.
#4 Johnnya101
Johnnya101
  • 68000
  • LocationLancaster, NH
Posted 03 March 2017 - 08:18 PM
Theres the site What is the IIGS? Which has full blown hard drive images. Im guessing just put that in?
resized.gif       BRENT RAMBO APPROVES
Apple IIGS, Classic II, SE/30, Color Classic, Quadra 700, 2x Imagewriter II,  Macintosh Color Display, Power Mac 7100 and 7200, LC II, Macintosh Color Display,  and a box full of ADB keyboards... Soon to be owner of another Quadra 700 and PowerBook 165c
#5 agent_js03
agent_js03
  • 6502
Posted 03 March 2017 - 08:37 PM
So then is it just a matter of writing the image directly to the SD card? I don't have to worry about initialization or partitioning?
#6 olePigeon
olePigeon
  • 68LC040
Posted 03 March 2017 - 10:08 PM
I believe you need to partition and initialize the card, then install the GS OS software.
#7 Johnnya101
Johnnya101
  • 68000
Posted 03 March 2017 - 10:23 PM
Hmmm... When I got my Floppy emu (I know, different) it did not need to be initialized. Just name it like smart0 or something. I know, different!
I guess you can always try not doing anything?
#8 Johnnya101
Johnnya101
  • 68000
Posted 03 March 2017 - 10:25 PM
Oh wait hold on. Any way to connect it from your card, and boot into GSOS from a floppy? That ways you can format the disk then do what you need to.
#9 NJRoadfan
NJRoadfan
  • 68000
Posted 05 March 2017 - 03:50 AM
GS/OS includes a drive partitioning tool for use with the HS SCSI card. All of Apple's SCSI cards use Apple Partition Map, so one could even use a Macintosh to prep the drive. Just remember that ProDOS partitions are limited to 32MB in size.
#10 agent_js03
agent_js03
  • 6502
Posted 05 March 2017 - 03:39 PM
Cool, so all I have to do is configure a few 32mb volumes, then initialize them from my LC III, and then I should be able to just format it in ProDos from my GS using Copy II plus right?
#11 Johnnya101
Johnnya101
  • 68000
Posted 05 March 2017 - 04:32 PM
Yup sounds right.
#12 olePigeon
olePigeon
  • 68LC040
Posted 09 March 2017 - 10:55 PM
Should work.
#13 theslownorris
theslownorris
  • 6502
Posted 15 March 2017 - 02:06 AM
I am happy to report v5 works great.
I have a Rom1, apple scsi card (rev c clone), and I run a scsi2sd (v5) just fine, even bus-powered. Works great with my ROM 3 too!
scsi2sd v6 is another story. It formats fine but locks up when I try to write with scsi2 enabled. I will be experimenting more soon.
#14 NJRoadfan
NJRoadfan
  • 68000
Posted 15 March 2017 - 02:19 AM
There is no point in running a SCSI-2 drive on an Apple II. Its simply too slow to take advantage of it (even with a DMA card like the RamFAST). The 8-bit bus runs at 1Mhz, and you aren't going to see close to the 1MB/sec theoretical transfer speed. I know the RamFAST had problems running with some SCSI-2 hard drives, but that card used a very non-standard implementation. The card itself doesn't assign itself a SCSI ID on the bus!
#15 agent_js03
agent_js03
  • 6502
Posted 15 March 2017 - 11:05 AM
Is there a better solution for mass storage? That is all I am really after, mass storage. My floppy drives don't work that well. They won't eject.
As of right now I was able to format the SD card and even copy System 5.0.2 over to it and started booting from it. But for some reason the SCSI driver in System 5.0.2 does not work. I did install it, but it doesn't recognize the drive. So basically it doesn't boot all the way up.
I am tempted to move in the direction of the floppy emu from big mess o' wires, though I hate to spend that much. Maybe once I sell my Apple IIe then I will be able to justify such a purchase and will have enough from the sale to get it.
#16 Johnnya101
Johnnya101
  • 68000
Posted 15 March 2017 - 12:43 PM
The floppy drives most likely need to be cleaned and decreased and such if they won't eject.
You'll want those floppy drives for an IIgs! They are useful!
#17 NJRoadfan
NJRoadfan
  • 68000
Posted 15 March 2017 - 12:46 PM
Fixing the floppy drives isn't that hard. They need to be cleaned and re-lubricated after 20+ years.
As for the SCSI card, you should be installing System 6.0.1 if you have the RAM, otherwise install 5.0.4. You can troubleshoot GS/OS booting by holding down 'space' on boot to get a verbose output of what is loading. GS/OS will load without a SCSI driver installed (SCSI.Manager, SCSIHD.Driver), although it won't be as fast at disk I/O (It relies on the ROM driver).
I would blast the SD card (format it on a PC or something), prep/format the drive using Advanced Disk Utility (On the System Tools 2 disk for System 6.0.1), and then install GS/OS.
#18 agent_js03
agent_js03
  • 6502
Posted 15 March 2017 - 02:47 PM
I took one of them apart and saw that the teeth had been broken off of the second gear on the eject mechanism. That particular one was apparently made of a more brittle plastic than the others.
I can still  use the floppy drives, it is just a pain because I have to stick a pin into it in order to manually eject. It kind of disrupts the functionality. Plus the floppies that were given to me with the IIGS are 30 years old and a lot of them are starting to fail.
Edited by agent_js03, 15 March 2017 - 02:49 PM.
#19 agent_js03
agent_js03
  • 6502
Posted 15 March 2017 - 02:49 PM
So the drivers for 5.0.2 and earlier won't work for that?
I do have plenty of RAM, but I would have to find some way of getting 6.0.1 on 800k prodos floppies... I don't have a cable for adtpro. I guess I could write them from my lc iii.
#20 Johnnya101
Johnnya101
  • 68000
Posted 15 March 2017 - 04:11 PM
You could. Whenever you get the money, save your self hours and get a floppy emu! HD emulation, floppy emulation it's awesome.
Edited by Johnnya101, 15 March 2017 - 04:12 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
