Jump to content
800k floppy drive help!!!!
  • Please log in to reply
10 replies to this topic
#1 jimjimx
jimjimx
  • 6502
  • LocationChicago, IL, USA
Posted 10 January 2017 - 01:01 PM
I  pulled out my 512kE, after about 5 or 6 months since I last used it, flip the switch, plop in the floppy, and I hear a motor continually running, and get the "Can't Find Startup" screen….
I shut down, poked the disk out, flipped the switch again,  and the same happens….
How do I fix this, or who do I send it to to be repaired?
I also have a M0131 that does nothing that does nothing that needs to be repaired….
Well….  It spins the disk for a second, then does nothing…..
So…. What do I do?  Where do I go?  Who do I send to?
I've used this for the last 20 years without a problem...
…And the Donkeys on eBay are asking over $100 for a working 800k, yet, they list it as "untested", and "as is"….
#2 anthon
anthon
  • 6502
Posted 10 January 2017 - 06:19 PM
My first step would be to give the drive a tune-up by blowing all the dust out, cleaning the heads with alcohol, and lubricating it according to the guide on the wiki. While you have it apart, give it a close visual inspection for any obvious damage.
#3 bibilit
bibilit
  • 68000
  • LocationParis area -FRANCE-
Posted 11 January 2017 - 08:21 AM
A motor continually running is the sign that the eject motor plastic gear is worn or broken.
Not much to do, you will have to replace it or have it repaired.
Someone used to sell new ones here.
Nothing works for a lifetime without a problem.
Macintosh Classic and II ,CC, SE, SE/30,IIsi 25mhz(RasterOps video),Q 700,LC, LC III,LC475, PBook Wallstreet/Bronze/5300cs/1400c/100/Tibook Imac G3 slot-in, Bondi and G4 / PMac G4 sawtooth, QS, MDD, Yikes!, Cube, Imac Core 2 Duo, Ibook G3 (white/clam) G4 + Newton 120, eMate 300,Quicktake 150,  PowerCD
#4 Johnnya101
Johnnya101
  • 68000
  • LocationLancaster, NH
Posted 11 January 2017 - 11:00 AM
There's a guy on eBay selling 3D printed ones
resized.gif       BRENT RAMBO APPROVES
Apple IIGS, Classic II, SE/30, Color Classic, Quadra 700, 2x Imagewriter II,  Macintosh Color Display, Power Mac 7100 and 7200, LC II, Macintosh Color Display,  and a box full of ADB keyboards... Soon to be owner of another Quadra 700 and PowerBook 165c
#5 jimjimx
jimjimx
  • 6502
Posted 11 January 2017 - 01:11 PM
Thanks. I'm going put it away, and think about what I want to do with it / about it...
#6 anthon
anthon
  • 6502
Posted 11 January 2017 - 08:22 PM
The replacement for the gear that usually breaks is here:
http://www.shapeways...oppy-drive-ejec
That's a pack of 4. If you just want one, try ebay:
http://www.ebay.com/...e-/262290290414
Open the gearbox first to confirm that this is the gear that is broken.
#7 jimjimx
jimjimx
  • 6502
Posted 12 January 2017 - 10:04 AM
I found the full set of ALL the gears here..
http://www.shapeways...k-floppy-drives
--jim
#8 bibilit
bibilit
  • 68000
Posted 12 January 2017 - 02:21 PM
Most of the times, only one is broken
this one
http://www.shapeways...=more-from-shop
#9 jimjimx
jimjimx
  • 6502
Posted 14 January 2017 - 04:55 PM
I thought about this again….
Has anyone had any experience with these "3D printed" gears?
Are they strong?
Do they last long?
Are there problems?
Do they react (Disintegrate) with oil and or grease?
Etc., etc., etc.
--jim
#10 Johnnya101
Johnnya101
  • 68000
Posted 14 January 2017 - 04:57 PM
I have experience with 3D printed materials. It depends what you get it ordered in. Abs would probably be the best for this situation, but you can even get it printed in gold or ceramic!!
Check out shapeways material charts.
#11 jimjimx
jimjimx
  • 6502
Posted 14 January 2017 - 05:28 PM
I'll assume…...
You haven't read the thread...
I don't think I have an option of ordering ABS, but i'd be "getting" what he already printed….
My question remains...
--jim
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
