Jump to content
Any thoughts on this....it arrived!!!
  • Please log in to reply
102 replies to this topic
#41 falen5
falen5
  • 6502
Posted 23 December 2016 - 09:25 PM
bibilit - thanks for the info and links. Will be needing all thoes links
Finally have the whole thing apart
starting to clean it up - that goo is a complete nightmare but its nearly all gone
#42 m_emelchenkov
m_emelchenkov
  • 6502
Posted 23 December 2016 - 09:36 PM
That's, indeed, the most interesting topic over past few weeks, or even months! Thanks, man, for sharing your proceedings!
#43 falen5
falen5
  • 6502
Posted 23 December 2016 - 11:28 PM
Testing the powersupply's
#44 falen5
falen5
  • 6502
Posted 24 December 2016 - 12:27 AM
After  rechecking the pinouts of a molex the power supply is working correctly. Tested the power supply on another IDE drive and spun up correctly.
Took the out the blown cap - 10uf 20 volt. Took out the controller board, cant see anything obvious wrong.. looks clean. Platter spins freely (just moved it a bit)
Can i replace this with a standard 10uf 20 volt radial cap or is this some kind of special cap??
think i should of just gifted this to techknight.......but its in bits at this stage!!!  and im having a laugh at trying to eletrecute myself!!
#45 falen5
falen5
  • 6502
Posted 24 December 2016 - 12:45 AM
after closer inspection can see rust on the pins of some of the ic's and on the back of the board, when you really zoom in there is grit/dirt on the board.
will give a good wash/clean, replace cap and try again
#46 techknight
techknight
  • 68LC040
Posted 24 December 2016 - 12:57 AM
that crude unregulated power supply that was running the drive scares the hell out of me. Its amazing the guy didnt kill the drive back in the day, who knows, maybe he did? Anyways that was a tantalum capacitor so its no surprise she went pop. They tend to do that from time to time. Tants get more unstable as they age. Sometimes I feel they are worse than the old paper/wax caps from the vacuum tube era.
I would use a much more modern +5v +12v power supply for the HDD.
Edited by techknight, 24 December 2016 - 01:07 AM.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, ibook g3x2, Lombard, 160, 165, 180, 180c Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, SE, SE/30, 512k, plus, LCIII, iMac G4, iMac intel, 6400/225
#47 falen5
falen5
  • 6502
Posted 24 December 2016 - 01:21 AM
thanks Techknight - apreciate it man
Theres another tant cap on there as well - ill replace them both with radials.
yeh........not using those transformers again - will replace with a psu from a pc - i swear man that thing could of exploded.........still not in the better of it. even if i managed to get the whole thing working, all back together in the box like i got it, I would be terrified every time i switched it on!!!
#48 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
  • LocationBermuda Triangle, NC, USA
Posted 24 December 2016 - 04:59 AM
I'm loving the step by step, keep up the good work!
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
#49 falen5
falen5
  • 6502
Posted 24 December 2016 - 05:19 AM
hi trash80 - 5am in ireland.......still awake
bad news on the motherboard
was looking at it after 1hour of cleaning trying to get that goo  off  - noticed allot of rust on many of the chips
decided to start taking them out and give a pins a gentle rub to clean them up......first chip and 3 of the pins broke off still in the socket - moving the chip in my hand and more fell off
tried another..1 pin broke off
74ls153 was the first - the socket was rusted too - took off the socket housing and the contacts  within the housing are grey or brown with rust
should of just bloody plugged it in before i decided to go 'cleaning'!!!
i can replace them - dam slow job - wondering if it is worth wile now
just look at the state of the pins..........there must be hundreds of broken contacts on that board
DAAAAAAAAAANNNNNNNNNNNNNNGGGGGGGGGG!!!!!!!!!
#50 falen5
falen5
  • 6502
Posted 24 December 2016 - 05:28 AM
looking at the first pic.....i have a plan
this is hacked apple.......so might be able to do a bit of DIY repair.
I can solder the chip back on with the plastic housing removed....pin by pin..straight on to the contacts
the broken missing pins i can use a bit of a leg of a cap to jump the gap
a jasus...i have to go asleep ... this is nuts man
SANTA.....BRING ME AN APPLE II WITH SHINY PINS..... AARRGGGHHHH!
GOOD LUCK PEOPLE
Edited by falen5, 24 December 2016 - 05:28 AM.
#51 Huxley
Huxley
  • 6502
  • LocationSan Francisco, CA, USA
Posted 24 December 2016 - 05:52 AM
Whatever happens by the end of this project, I hope to be among the first to purchase a signed copy of "Rust, Goo & Busted Caps: My Apple II-Fueled Descent Into Madness by Falen5"
Before the "Great Crash of '07", I was SpaceBoy on these forums.
#52 falen5
falen5
  • 6502
Posted 24 December 2016 - 01:43 PM
good man huxley!!
any opinions on the motherboard people.......is it a gonner!!
#53 m_emelchenkov
m_emelchenkov
  • 6502
Posted 24 December 2016 - 07:46 PM
good man huxley!!
I think, you should re-solder each rusted contact, to almost completely exclude rust from motherboard. I think, if you will not do that, then it will be hard to diagnostic it later when you will try to turn it on and if it will not turn on the first try.
Also, if you know how to test these chips, it will be a good idea to do it while they are dismantled from the motherboard. I suppose, some of them may be broken? Really, you need to look how far corrosion goes. I hope, not too far.
Completely remove? I don't think it's a good idea. Maybe cut up (with a rasp) the plastic up to not corroded contacts and use thin wires instead original legs?
Edited by m_emelchenkov, 24 December 2016 - 07:46 PM.
#54 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 24 December 2016 - 08:27 PM
Dunno, I think I'd remove all the sockets/solder and put in new ones. Reinstall the sockets AFTER giving the board a thorough going over with every cleanup trick the gang can give you. While at it, check for continuity on all traces you can see while you have the chance to do so. Then install new sockets. Outright replacement of the sockets and that batch of '74LS logic won't be very expensive. Do further testing with mostly all new, known good components.
jt [8]
#55 falen5
falen5
  • 6502
Posted 24 December 2016 - 09:31 PM
Thanks lads - there will be no easy short cut out of it. Getting the motherboard to work is going to be a dam nightmare
should of just left it and tested it before i pulled the chips
today i repaired the broken plastic dowels for the screen and remounted the screen and analog board
I have learnt that the screen is not the screen from the original  Iskra Delta Partner. This screen fits the curves of the case perfect, but the 4 atachment metal tabs/ holes that screw the screen in situ did not line up
Thats why they all 4 were cut. I thought when the machine must of been  dropped in the past and the screen broke free that the 4 metal tabs had litterly ripped apart. They were cit to bend the 4 tabs to line up with the mounting holes.
anyway - it is all back in and solid.
There are 3 small circuits hacked onto this analog board. check all i can see for shorts etc etc. Whoever built this must of really knew electronics. Any writing I have found so far on it is all in english so I dont think it was created in yugoslavia  - who knows!!
question.....on the back of the crt there is a long spring. I have it running across the top of the crt. Where am i supposed to run this spring- as it is? up/down?, diagonaly?
what is it for anyway??
I have cleaned the board. Cant see any bulging caps, cracked solder. Checked with the pictures i took that everything is wired as it was when i first opened it
Im going to power it up in a while - get the camera rolling for the much anticapated explosion!!
if anyone is looking at this could you please have a look to see if i have done anything stupid before i power it up
If this works ill keep going..........if it blows up......so will I , and ill hit the beer
cheers people
Edited by falen5, 24 December 2016 - 09:34 PM.
#56 techknight
techknight
  • 68LC040
Posted 24 December 2016 - 10:44 PM
That monitor was an old black and white TV chassis. I can tell by the flyback transformer, they used some custom circuits by the flyback likely to tap off an additional voltage for something added. And then, you can see where the tuner was and it was removed. The little circuit board in the middle is probably a modification to allow composite video instead of IF stage.
Yeap, someone had some fun!
Edited by techknight, 24 December 2016 - 10:46 PM.
#57 Gorgonops
Gorgonops
  • 68030
Posted 24 December 2016 - 11:24 PM
I vaguely want to look up the SAMS manual for the Radio Shack TRS-80 model I and see if it's possible those are the guts from a Trash-80's monitor. (Which was literally TV with the tuner ripped out. The front bezel of the case had holes for the VHF/UHF knobs under the plastic nameplate they tacked on.)
#58 Gorgonops
Gorgonops
  • 68030
Posted 24 December 2016 - 11:29 PM
... Wait, I forgot the point. Reason it has me curious is Radio Shack used a cheap hot ground TV with no isolation transformer, and instead of adding one for safety (which was kinda a concern when you have wires running to something with a keyboard) they opted to use a high-speed optoisolator on the composite input. Said isolator lived on a little satellite board...
#59 falen5
falen5
  • 6502
Posted 25 December 2016 - 12:57 AM
Techknight - all you say makes sense - i was lost with the 3 custom boards wired into the analog board - cheers mate.
Gorgonops...i could lie and say i understand what you said ... but man i have no idea.......however I do know that you know more about this stuff than me so I accept all you say.......fair play man
truly apreciate all comments from all....im flying in the blind here people with basic knowledge
heres a vid of the repair of the 2 damaged lugs for the monitor screen supports..........long ass vid,,,, but maybey of some use to someone
Edited by falen5, 25 December 2016 - 01:05 AM.
#60 falen5
falen5
  • 6502
Posted 25 December 2016 - 01:02 AM
This is the dreaded analog board/screen test. This scared me the most....alas with good reason ....but it had to be done........
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
