Jump to content
G5 Video Card Options
  • Please log in to reply
20 replies to this topic
#1 itsvince725
itsvince725
  • 68000
  • LocationPennsylvania
Posted 21 December 2016 - 02:36 AM
My G5 (2.3GHz dual processor) currently has a Radeon 9650 video card with 256MB of VRAM. My question is...was that the best you could do for a "Early 2005" Power Mac G5 like mine? If there's a 512MB upgrade, I'd love to chase it down, but I don't know a thing about PCI-X video cards.
Macs I Own: Power Mac G3 B&W (350MHz), Power Mac G5 2.3DP, Performa 630CD, PowerBook 180, SE/30, 2x iMac G3 (Bondi Blue Rev B, Indigo 400MHz DV), SE dual-floppy, IIsi, Performa 6116CD, Quadra 950
#2 bunnspecial
bunnspecial
  • 6502
Posted 21 December 2016 - 02:47 AM
First of all, you don't need to worry about PCI-X since the video is AGP.
The only 512mb option is a very rare flashed Gainward Bliss nVidia 7800GT.
In terms of retail/BTO options, the best was the Radeon X850 XT. The X800XT is a lot easier to find and nearly as good. I actually have an 850, but unfortunately it's decided to show something resembling a Van Gogh painting... I'm using an X800 instead in the dual 2.7 I'm running until I can figure out the issue with the 850.
The Geforce 6800 Ultra is also a great choice. These are a bit slower than the X800/X850 but are easier to find. In addition, the 6800 is dual DVI while the X800/850 are DVI+ADC. If you want to run a 30" Cinema display, the 800/850 on have one dual link DVI port, while both 6800 Ultra ports are dual link. Of course, if you want to run an ADC monitor, a card with an ADC port makes like easier. One potential downside to the 6800 is that it is a dual height card.
The Radeon 9800 is a good choice for the somewhat more budget conscious G5 owner.
My current set-up is a 23" Acrylic cinema display(ADC) along with a generic Dell 17" Ultra-Sharp. My plans very soon are to use a 30" Cinema along side the 23", although I need to find a way to make room for it on my desk.
#3 itsvince725
itsvince725
  • 68000
Posted 21 December 2016 - 02:59 AM
So what you're telling me is that the 9650 wasn't very good? I mean, I figured it was merely okay, but you make it sound like just about every other option my era of G5 could have is better.
#4 TheWhiteFalcon
TheWhiteFalcon
  • 68030
  • LocationUtah
Posted 21 December 2016 - 03:13 AM
Well, it wasn't the base card, the 9600 was.
Desktops: Cube, iMac G4, 128k, 512k/Plus, SE/30, IIsi, Q700 PVT. Laptops: 180, PDQ, Pismo, TiBook, iBook Clamshell, MBP 15", MBA 13", MB C2D, Unibody MacBook Portables: MP 130, 2100, eMate, iPhone 3GS, 7 Plus, iPad Air.
#5 itsvince725
itsvince725
  • 68000
Posted 21 December 2016 - 03:15 AM
So what kind of prices do these cards command?
#6 Unknown_K
Unknown_K
  • 68LC040
  • LocationOhio/USA
Posted 21 December 2016 - 03:35 AM
The only dual 2.3ghz G5 is the last gen dual core PCIE model.
•Video: Nvidia GeForce 6600 LE. Nvidia 7800 GT with 256 MB and Nvidia Quadro FX 4500 with 512 MB optional
Prices are crazy because a mac ROM PCIE videoc ard is kind of rare, plus the 7800 series is flacky.
Favorites: big box Mac IIs, 950, 800's
Wanted: Anything Nubus, Video capture and editing hardware and software for 68k mac. Original software including A/UX.
Looking for 9150, Mac II, Color classic, 840av motherboard, and Nubus cards.
#7 itsvince725
itsvince725
  • 68000
Posted 21 December 2016 - 03:49 AM
That's not what everything I've ever read says, there was a 2.3 dual processor AND a 2.3 dual core, separated by a few months.
#8 TheWhiteFalcon
TheWhiteFalcon
  • 68030
  • LocationUtah
Posted 21 December 2016 - 04:03 AM
Yep, April to October 2005, M9748xx/A
#9 Unknown_K
Unknown_K
  • 68LC040
  • LocationOhio/USA
Posted 21 December 2016 - 06:35 AM
Oops, missed it.
Anyway for AGP you have the 6800 ultra (long card), flash a 7800GS AGP, or the 9800XT.
#10 rsolberg
rsolberg
  • 6502
  • LocationVancouver Island, Canada
Posted 21 December 2016 - 06:57 AM
There have been very few performance-oriented AGP graphics cards with more than 256MB VRAM. Even fewer can be flashed with a PPC Mac ROM- the very specific model bunnspecial has noted is the only one I'm aware of.
If you search for 512MB AGP cards on eBay and the like, you'll mostly find entry level cards with slow and narrow memory interfaces- these would be inferior to your existing card. (If a suitable PPC Mac ROM existed)
If you want more performance for 3D gaming, a higher end 256MB card such as a Radeon 9800 Pro or X800XT (either Mac Edition retail or a suitable flashed PC card) would be my first choices. Bunnspecial does a nice job outlining the options above. I saw Mac ROM flashed 256MB X800XT cards for US $140 on eBay when I searched for "G5 AGP".
Edited by rsolberg, 21 December 2016 - 06:58 AM.
68000: Mac SE Superdrive, 68040: Mac Colour Classic "Mystic" w/VGA mod
#11 bunnspecial
bunnspecial
  • 6502
Posted 21 December 2016 - 11:34 PM
Just to show off a bit, from left to right here's a Radeon 9650, Radeon 9800, Geforce 6800 Ultra, Radeon X800XT and Radeon X850XT. These are all Mac edition cards.
The PC Radeon FireGL X3 actually flashes beautifully into a Mac edition X800. These were at one time cheap and plentiful on Ebay, although someone has been buying them up recently. They are easy to find pre-flashed. Unlike the Mac edition, these have dual DVI. They also require external power-you will need to snake a molex splitter up to the optical drive to use one. They work great, though. A friend of mine recently soldered a 128K Mac ROM chip onto one of these and was able to flash it with the full X850XT ROM(most PC cards only have a 64K ROM chip, which requires a reduced ROM and brings its own problems).
#12 itsvince725
itsvince725
  • 68000
Posted 25 December 2016 - 04:36 AM
Oh! Just out of curiosity...could I put the 9650 in my G4? Sure 256MB of VRAM is kinda extraneous for a G4, but if it works, I might as well give the card a new home.
#13 bunnspecial
bunnspecial
  • 6502
Posted 25 December 2016 - 06:22 AM
I maintain a pretty heavily used PPC system for both legacy software and legacy peripherals. For about two years-up until last week-that system was a dual 1ghz PowerMac G4 Quicksilver(I've since replaced it with a dual 2.7 G5, something I'd been planning for a while but just hadn't take the time to do).
In any case, I ran a G5 Radeon 9600XT in the Quicksilver. This is a very similar card to the 9650, except that it has(I think) 64mb of VRAM and has ADC+DVI. The 9600 gave me CI support in Leopard, and I wanted ADC to be able to drive my 23" Cinema
The 9600 and 9650 will both work in 4x G4s(Digital Audio, Quicksilver, MDD) provided that you tape pins #3 and 11 on the back side. Once this is done, the card is drop in. On the ADC 9600, I had to do a bit of additional work to get ADC working since the power tab is in a different location(I lost the ability to boot the computer from the monitor button, but retained USB support). This, of course, isn't that relevant to you.
The 9650 I picture above is currently taped and was that way when I received it exactly because it had been used in a DA G4.
This series cards is one of the best to "hack" into a G4 for core image support. In fact, a later retail card from the series-the 9600 Pro PC&Mac-drops into a 4x G4 without taping. ATI officially quit endorsing them for use in pre-MDD computers, although both the ones I have(which I bought in shrink wrapped retail boxes) work fine in Quicksilvers.
If you plan to boot into OS 9 on your G4, though, forget it as you will get no hardware acceleration.
Also, I'll just mention that my Quicksilver had a short "retirement." It's now running OS 9 exclusively(although I'm going to reinstall the OS X hard drive pair) and has a Geforce 4Ti. It's getting set up as a "gaming machine."
#14 itsvince725
itsvince725
  • 68000
Posted 25 December 2016 - 06:27 AM
Taping pins? How exactly do I do that? Do you have pictures?
Also, my MDD is a FW 800 model so it can't run OS 9 anyway.
#15 waynestewart
waynestewart
  • 6502
  • LocationVancouver BC
Posted 25 December 2016 - 07:18 AM
This site is a pretty good resource
http://www.jcsenterp...Things_PPC.html
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
#16 bunnspecial
bunnspecial
  • 6502
Posted 25 December 2016 - 03:19 PM
Here's a good guide on taping cards
http://themacelite.w...m/pins-3-and-11
#17 asaggynoodle
asaggynoodle
  • 6502
Posted 25 December 2016 - 06:30 PM
In addition to what was mentioned here, just about any of the cards mentioned here will all be overclockable quite significantly especially the ATI ones. So if the price difference is quite substantial from one card to the next, you can always find a solid guide on volt modding (which is unbelievably easy on these old cards). Then go ahead and use something like ATIccellerator and max out the clock on it. I mean realistically if you can get an extra ~30-40% for simply putting some pencil lead over a resistor on the Voltage Controller and dragging a slider, it might be a good try instead of spending a couple hundred for a card that's only the same bit faster.
#18 trag
trag
  • 68020
  • LocationAustin, TX
Posted 25 December 2016 - 10:11 PM
There's one (unmodified) on Ebay right now for about $30 after shipping. Item number 272437805013. There was a period a few years ago when some kind of sales channel was full of them for about that price. Replacing the Flash chip is definitely the way to go in my opinion.
#19 Unknown_K
Unknown_K
  • 68LC040
  • LocationOhio/USA
Posted 25 December 2016 - 10:46 PM
There are not that many options for the PCIE G5 towers compared to the AGP ones.
#20 itsvince725
itsvince725
  • 68000
Posted 25 December 2016 - 11:24 PM
That's surprising, I expected the opposite.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
