Jump to content
Brett B.
Couldn't help myself...
Recommended Posts
I also scored a Late '06 Mini out of the trash today (my boss threw it away...)
Works great, has a 1.83 Core Duo.  I ordered a 2.13GHz Core 2 Duo for it.  I wanted one of these to use as a Windows server but ended up with a laptop instead - I may do some reconfiguring anyway.  Low power use was my goal, the laptop PSU may still use less but takes up a lot more space on my rack.
Share this post
Link to post
Share on other sites
The Core2Duo upgrade on the Mini was successful - after about 30 failed attempts.  The 2,1 firmware flash did not work exactly like the instructions I found said it would, then I had issues with the 1GB and 2GB memory sticks, and it would just not boot at all for a while with the Core2Duo installed.  So after disassembling and reassembling way more times than was necessary, I discovered the intricacies of the Intel Mini, as well as a reminder to myself that the CPU socket has to be locked in place for the machine to function.  Now I have a fully functional machine.  :lol:
I do not have a 10.6 install disc - except for a 10.6 install disc that came with a late 2010 Mini that I have at work... is my best option to just pony up and buy the $20 upgrade from Apple or is there some way to make the disc I have work?  It will boot to it but says I get a compatibility error when I go to install.  Hate to spend $20 on old software if I don't have to.
Share this post
Link to post
I ended up ordering a 10.6 retail DVD from ebay - was $15.  I also installed a 500GB 7200RPM drive in the Mini - that was a nice performance boost.  The old 5400 drives are just so slow.
As a side note, Windows 10 runs fairly well on this thing.  Way better than I would have expected.  I downloaded the Netflix and Hulu apps from the Windows store and have been using it as a media PC... it replaced a very loud Gateway tower.  Works great although video playback skips occasionally, worth the tradeoff just because of the lack of noise, though.
I also ordered 8x 16MB 30 pin SIMMs for my SE/30.  Totally unnecessary but it's gonna be cool. :D
Share this post
Link to post
Do the Intel minis have enough GPU to stream HD Netflix content? I use an old quad core PC with a ATI video card for my Netflix box and it can stream 1080p .x264 and .x265 content fine with no noise.
Share this post
Link to post
I think so?  I was looking around in the Netflix settings the other night for that and couldn't find anything that would let me limit content to SD.  I have the HD subscription, seems like there was an option but maybe they removed it.
Anyway the Netflix app on Windows 10 does not work well.  I keep getting this "USB device not recognized" and the plugged in/unplugged alert sound happens constantly but only when the app is open, and never anywhere else.  The Hulu app works great.  I have just been streaming Netflix through Chrome instead, works fine there apart from the occasional lag.  The Core 2 Quad Gateway box it replaced worked perfect but it also had a lot more memory, 2 more cores and a nice-for-it's-age graphics card.
Share this post
Link to post
Oh yeah, I forgot, I also found 2x 64MB 72 pin SIMMs a while back.  I finally got around to installing one of them in my LC475.  So I have a total of 68MB now.  I think that is my record for most memory in a 68k at this point although the SE/30 will have it beat.  I need to see if the other 64MB stick will work correctly in my LC630 but it will take some serious effort on my part to take my desk apart so I can unplug everything.
Share this post
Link to post
I now also have a mid 2012 13" MacBook Pro.  I haven't "daily driven" a Mac since OS9 was new software so this is more or less new territory for me.  My main laptop for quite a while has been a Dell Latitude E6420... love the thing, it's just about as old as the MacBook and they have about the same specs but the Mac just seems kinda doggy.  Takes well over a minute to boot into Mac OS (Mohave.)  May do an SSD upgrade - the Dell has one and it is at the Windows login screen in 12 seconds.
Share this post
Link to post
Lol that’s not surprising at all. Literally the late 2009 Core2Duo original 13” MBP with a solid state drive, 4GB of ram and a hack to force Mojave to run on it would kick the crap out of ANY spinning disk MacBook Pro’s boot time (dual or quad core i3 to i7, doesn’t matter) assuming they still had their factory drives, which scuttled along at a leisurely 5400rpm. If you are trying to daily drive a Mac for the first time in 15 years at least stock it with hardware that will make it enjoyable and not migraine inducing. We’re over half a decade into the SSD age.
Amazon has a Samsung 860 Evo 500GB SATA SSD for only $80. We’ve definitely hit affordable SSD storage prices.
Share this post
Link to post
Mac OS X is criminally bad at handling itself without an SSD. I put a 2TB hard disk in my Mac mini, because I had a need to have that much space and didn't want to use or buy another external, and it's making the particular task I wanted to do (torrenting) much worse than it would be, even if I was just torrenting to a spinning disk and booting to an SSD.
One more issue that may or may not be hurting, the SATA Cables inside some of the MacBook Pros is known to bed. If the SSD itself doesn't help, replacing the SATA cable should.
Share this post
Link to post
It's pretty amazing what even a Fusion drive can do. My 2010 iMac was sans SSD with only it's HD in it. Once I waited a few years for prices to come down, installed an SSD and made a Fusion drive out of both of them...the startup time boost is just incredible.
Oh, and a few months after getting a new 2014 Mac Mini for a file server with a 5400 RPM drive, I got an OWC SSD instead because I couldn't tolerate how long it took to even open an application any more.
Edited by LaPorta
Share this post
Link to post
I have used a couple Crucial SSD drives that are $35 shipped (240GB.) Cheap and seem to be good quality. I ordered another one for this MacBook, I'm sure it will help quite a bit.  My stash of SATA hard drives is really growing... I hope I'll be able to use them someday. Kind of a shame to have large, low mileage drives that are uselessly slow.
I really find it odd that this MacBook maxes out at 8GB memory. Will it actually see more? Even the mid 2010 mini I have at work has a much higher ceiling, I have 12GB in it at the moment and it cost 1/10 what the MacBook did.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
