Jump to content
itsvince725
Vince's Conquests
Recommended Posts
I seem to be acquiring more Macs and Mac-related stuff at a fairly steady clip so I decided to make my own conquests thread...I won't re-post the 630CD or the PowerBook 180, so my first conquest to show off is the Mac SE/30 I got off eBay. It's a bit grungy and yellow (and a thorough Magic Eraser/Goo Gone treatment didn't do much) and it needs a recap but it's in good physical condition and has a network card, so it's not all bad.
Share this post
Link to post
Share on other sites
Nice!
I believe that using Hydrogen Peroxide/retr0brite will fix the yellowed plastic, but I don't know. Some people hate retr0brite, some people adore it. Just keep it away from UV radiation.
EDIT: Also, check the caps, rom, or card if it's simasimacing.
Edited by Carboy7
Share this post
Link to post
Yeah...first boot gave me fan, no chime, and jumpy horizontal black and white stripes (which tells me the screen probably needs the horizontal and vertical hold adjusted).
Unfortunately I lost my damned 1/4" bit extender so I don't have anything long enough with a T15 Torx to open this baby up! Guess it's gonna sit until I can get the case open...
Share this post
Link to post
There is a thread from a few days ago that lists torx options towards the tail of the thread https://68kmla.org/forums/index.php?/topic/28728-vintage-mac-torx/?hl=torx
I'm still using a regular torx screwdriver (after removing the handle), which gave it just enough extra length to work.
Congrats on the SE/30, they are nice machines once you get them recapped.
Edited by Juror22
Share this post
Link to post
I ordered one of these off eBay, as the price was right and they explicitly market it as working on compact Macs:
http://www.ebay.com/itm/331657821608?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Meanwhile, today brought Macintosh project #2! A 2.3DP PowerMac G5 with no RAM and no hard drive. Yeah, I kinda overpaid for it ($100), but I was planning on maxing out the RAM and changing the hard drive to a SSD anyway. Anyone know where I can get the guides that you need to keep hard drives inside the G5 drive bays?
Share this post
Link to post
Developer's Transition System. It was a platform from back in 2006 when Apple was switching its stuff to Intel processors from PPC. It is extremely rare, as the computers had to be given back to Apple after one year.
The case is basically the same as the Power Mac G5, but there is a tiny Intel board on the inside, called "Barracuda".post-6438-0-45776900-1477800318.jpg
Share this post
Link to post
Nope, I definitely don't have one of those! This guy had three 2.3DP G5s (and two MDD G4s that I didn't pursue...this time) that he got from some kind of auction. Probably a business that closed down or something.
Seriously though, what do I need to keep hard drives locked into the weird tracks in the drive bay? I need a hard drive for this thing ASAP so I can actually put an OS on it but it won't do me any good if it's bouncing around, that's what messed up the original dual drives in my G3.
Share this post
Link to post
Nope, nothing in there...
I can't find 2GB non-ECC DDR RAM so the G5 is getting 8 1GB sticks and a 160GB Intel 320 SSD with a fresh install of 10.4.11 and 9.2.2 for Classic Mode.
Share this post
Link to post
So I got my Torx 15 "Mac Bit" today to open the SE/30...only to find there wasn't any screws holding it together anyway! Now I'm gonna have to find screws.
Here's the logic board, it came out fairly easy aside from disconnecting the analog board connector. I had a hell of a time until I found the locking clip on the back!
The one little can near the CPU (C13) clearly leaked and damaged a trace near the CPU, but I didn't see any other obvious signs of damage...and that trusty Tadiran battery hadn't leaked a drop. Now it's bagged and ready to be sent to Unknown_K for recapping tomorrow.
Also, I bent up the thin metal pan that fits in the bottom of the rear casing... :( Do I really need that?
Edited by itsvince725
Share this post
Link to post
Damn, I bought a set of screws for no reason! Oh well...
I decided to forgo the SSD this time to save money, so 8GB of RAM and a 320GB HDD are on the way.
Share this post
Link to post
Got a pair of iMac G3s today from a Craigslist ad, one's a Bondi Blue Rev B tray-loader (dated October 28th 1998) and the other is an Indigo 400MHz DV. The Bondi is getting upgraded to 9.2.2 (probably tomorrow) and I might as well update the DV to 10.4.11. The Bondi had a Maxell PRAM battery but by some miracle, it hadn't leaked! What luck!
Share this post
Link to post
Updated the Bondi to OS 9.2.2 today and installed Office 2001 on it for the hell of it. Someone upgraded the RAM to 256MB but it still has the original 233MHz processor card and a 4(!!!)GB hard drive. Gonna have to fix that post haste...
Of course, what might need fixing first is the analog board, as the CRT pops occasionally (especially when turning the machine on after leaving it sit awhile). Also, just as comparison, here's the system specs of my B&W G3.
Share this post
Link to post
I got my SE yesterday and today I finally had a chance to take a good look at the thing...I noticed the CRT isn't flush with the front panel of the case. :( And even worse, it turns out my worst fears were realized, as the standoffs that hold the CRT to the front of the case are sheared off on the right side. :(
Is it even worth trying to fix these? At the very least I have to remove both the analog board and the CRT to glue the standoffs back into place, and I don't even have any kind of discharging tools so I'd probably get electrocuted trying to do it.
Share this post
Link to post
I wouldn't worry too much about discharging. My impression is that the SE has auto-discharging circuitry that will keep you more or less protected, especially if you leave it for a few days before attempting anything. I took apart a few SE/30s to do some cleaning earlier this year with no formal discharge protection and I did just fine. YMMV, though.
Share this post
Link to post
I never know if the flyback transformer has been swapped for one without a bleeder resistor, or if it is still in working condition. And I don't like getting electrocuted. Even if it's not going to kill me. Just a personal quirk of mine, I guess. So whenever I need to mess with connections on the analog board, I discharge the tube. It only takes a moment to make sure.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
