Jump to content
Woz IIgs w/ AE Vulcan 20mb HDD
  • Please log in to reply
40 replies to this topic
#21 waynestewart
waynestewart
  • 6502
  • LocationVancouver BC
Posted 30 July 2015 - 07:45 PM
I don't know of any way to deal with bad blocks using the Partition Manager.
For now, can you turn off the bad partition and just use the good one?
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
#22 miniMOJOman
miniMOJOman
  • 6502
Posted 30 July 2015 - 08:04 PM
ARG, I just found out you can press the AE keys together in Part Manager and it will scan the drive and create what is called a "VALID PARTITION BLOCK"... I ran the scan, and then it couldnt create the valid partition block... I am thinking this HDD is just dead lol....
#23 miniMOJOman
miniMOJOman
  • 6502
Posted 30 July 2015 - 08:07 PM
Before I found the "AE" key combination, it had 2 partitions but they weren't set to "ON"... which I believe you can only set them to on, once you create a valid partition block.. this is all very new to me.. haha
#24 miniMOJOman
miniMOJOman
  • 6502
Posted 31 July 2015 - 04:40 PM
GREAT, so I was running the scan yesterday at the shop, and it literally took 5 hours to scan through 300 of the 700+ cylinders.  So I left it on overnight, probably a big mistake, when I came in this morning the IIgs was off.  I think the Vulcan Power Supply crapped out overnight in the heat/power... It doesnt turn on anymore :-(... I dont see any bulging caps or anything in the PSU and I have no idea how to start diagnosing where the power problem is.. but I guess this baby will have to go on the backburner until I find out how to repair it :-( sad day
#25 miniMOJOman
miniMOJOman
  • 6502
Posted 31 July 2015 - 04:48 PM
So when i remove the Vulcan Hard Drive from the Power Supply, it turns on.. .does that mean the PSU is failing, or the hard drive somehow is causing a short or something?  Seems like the PSU might not be supplying enough power anymore?  So confused
#26 miniMOJOman
miniMOJOman
  • 6502
Posted 31 July 2015 - 04:54 PM
LOL I just unplugged the IDE hard drive from the Vulcan power supply..The power supply turned on and powered the IIgs w/o the hard drive in it... so then I plugged it into just a bare power cord from another computer... the disk spun up fine.. so I put it back in the vulcan powersupply and it works fine now?
#27 CelGen
CelGen
  • 68000
  • LocationKamloops, Canada
Posted 03 August 2015 - 07:57 PM
What did I tell you about the flat-out-A W F U L reliability of those drives?
Just get rid of the damn drive. It's the source of all your problems right now.
#28 CC_333
CC_333
  • 68LC040
Posted 03 August 2015 - 09:39 PM
Would some kind of 1-10 GB IDE drive work?
I have a bunch I don't want or need at present.
c
Main Macs: Early '09 Mac Pro, Mid '12 MacBook Pro 13" --- Secondary Macs: Early '08 Mac Pro, Mid '12 MacBook Pro 15"
Playthings: Mac SE/30, 3.0 GHz Mavericks-based HackServe, Many others... --- Desired: Lisa, Kanga PowerBook G3, Apple IIc, Apple II, Spare parts, etc.
#29 waynestewart
waynestewart
  • 6502
Posted 04 August 2015 - 06:16 PM
Won't work. There's only a few drives that'll work with your card. If you changed the EPROM to the Vulcan Gold then there's more than a dozen that'll work. Any drive that'll work will be from the same era your drive was made.
The drive can be replaced with a Compact Flash but finding one that'll work is difficult. I borrowed CFs from a lot of friends obsolete cameras before I found some that would work. The nice part is that they're a lot faster than the drives. The odds of finding a compatible CF go up if you have the Vulcan Gold EPROM
#30 CelGen
CelGen
  • 68000
Posted 06 August 2015 - 01:22 PM
Again, give it a 32mb Compact Flash card and it's happy.
#31 miniMOJOman
miniMOJOman
  • 6502
Posted 06 August 2015 - 06:38 PM
yah, the hardrive ended up smoking, so I took it out and I removed the vulcan parts for the time being.. I need to get a CF card thingy.. I dont know where to find one!!
#32 CC_333
CC_333
  • 68LC040
Posted 06 August 2015 - 09:42 PM
I have a bunch!
I'll have to look at them, but some are 32 MB, 64 MB and maybe a couple are 128 MB.
Are there any brands/models that are known to work reliably?
c
#33 CelGen
CelGen
  • 68000
Posted 07 August 2015 - 02:01 PM
I used a card branded by Kodak but one with Canon or Nikon branding might also work. On paper any CF card 32mb and under will work but god knows how modern cards behave with controllers this old. It's once you go over that I can't really say as you exceed the maximum partition size for ProDOS.
#34 NJRoadfan
NJRoadfan
  • 68000
Posted 07 August 2015 - 02:21 PM
The Vulcan supports multiple partitions, so 32MB isn't a hard limit. The problem is that the firmware only supports a limited amount of CHS combinations, similar to the old BIOS drive types before "User Defined" came about. I wouldn't be surprised if the table is close to or identical to them. The Vulcan ROM is completely inflexible and refuses to work if it detects something not matching its on board drive table.
http://webpages.char...chhelp/0054.HTM
http://vintage-pc.tr....com/types.html
Here is the semi-official Vulcan drive list: http://mirrors.apple...es/vulcan.specs
Edited by NJRoadfan, 07 August 2015 - 02:25 PM.
#35 miniMOJOman
miniMOJOman
  • 6502
Posted 07 August 2015 - 07:12 PM
I need to get the CF card first, aren't they unavailable?!   I know I can get the actual CF card, I am speaking of the adapter for the IIgs....  here are some pictures for your enjoyment of the hoard of software/books I got with this WOZ IIgs
#36 sstaylor
sstaylor
  • 6502
  • LocationOgden, Utah
Posted 07 August 2015 - 07:37 PM
If you search ebay for something like "cf card lot" you can often come up with auctions for a dozen different cf cards of low capacity for fairly cheap.  Maybe one or two will work...
IIe Plat, IIgs, Plus, SE FDHD, SE/30, Classic, Classic II, IIsi, IIci, Q700, Centris 650, LC, LCIII, PM 6500, 5400, 6100, 7100, 8500, iMacs: Bondi, Indigo, FlowerPower, G4 15"; G3 Beige tower, G3 B&W, G4 AGP, G4 MDD, Mini G4, Cube 450, Mini 1.66Core Duo, G5 1.8dual, Backlit Portable, PowerBook 170, Wallstreet, Lombard, PB G4, iBook blueberry, PB 13" 2007, Duo2300 & Dock
#37 CC_333
CC_333
  • 68LC040
Posted 07 August 2015 - 08:23 PM
http://www.ebay.com/...=item3ce7077745
This one might work? The listing's for a single card, though.
c
#38 waynestewart
waynestewart
  • 6502
Posted 10 August 2015 - 09:21 PM
These are the ones that I have that work with my controllers. The 16s and 32s work with the 40mb EPROM but the 64s only work with the Vulcan Gold EPROM.
https://drive.google...4SzA&authuser=0
#39 gdanie
gdanie
  • 6502
Posted 09 September 2015 - 05:41 PM
http://ae.applearchi...ple_iis/vulcan/
Also, I wouldn't even bother with the Apple RAM card. ggLabs sells a 4MB card on ebay, no worries about running out of memory with one of these. If you need to get a disk image to the IIgs, use ADTPro (or the FloppyEmu if you have one). Power Mac manual inject floppy drives aren't all that reliable at making 800k disks.
The Vulcan controller is notoriously picky about what type of drive is connected to it. Very few CF cards will actually work with it.
I got the 4mb RAM card from gglabs and I can testify that it is awesome.  Well worth the money.
#40 corradokid
corradokid
  • 6502
  • LocationSan Francisco, CA
Posted 13 May 2016 - 03:39 PM
Thanks for the info.
Now... A Woz IIgs as I remember is  modified ROM 0. Modified how, I do not know.
ROM 0 IIgs' were from the first year of production (Sept '86 to Aug '87,) including the first 50,000 limited edition "Woz Edition" (I had one when new!) I believe GS/OS requires ROM 1 or newer and all owners of a ROM 0 IIgs were offered the free upgrade to ROM 1 (chips were upgraded, motherboard the same.) No further upgrades were offered for the IIgs (ROM 1 to 3) as 3 was not required for software.
Apple IIgs (Woz edition) — Macintosh IIci — PowerMac G4 (533MHz) — 15in MacBook Pro (late 2011)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
