Jump to content
68k family
Centris 610 won't boot...
Recommended Posts
Had my centris 610 re-capped a year ago since it became all voodoo... Since then it has worked flawlessly, until Friday night when my daughter turned it on and nothing... Monitor remains asleep but the hard drive spins up and the power led lights up. I've disconnected the SCSI devices (color onescanner, 1.2gb Apple HD, canon slide scanner) I've resat the ram, checked the pram battery, removed the dos card... Everything. Still nothing. We still use this machine quite a bit and have since my parents bought it new for me in 1993. Don't want to see it go. Anyone have any ideas?
Edited by 68k family
Share this post
Link to post
Share on other sites
Start out by checking voltages, then, I might suggest removing all of the ram and seeing if it boots with just on-board ram, If all else fails I spare a spare board for this guy but I suspect if you haven't recapped the power supply it may be time...
Share this post
Link to post
No startup chime. Power supply is still stock from 1993. What are my test points for voltages and what am I looking for? Ram was removed and still nothing. Ram works in my performa 631.
Share this post
Link to post
Yep, I know how to use a multimeter, just needed to know what I am looking for - thanks! I will check this out this afternoon. I'll report back with my findings.
Share this post
Link to post
Shouldn't the PSU fan kick off briefly when power is applied? Put a piece of paper into the blades from underneath to see if the fan works.
Monitor: Which monitor? What happens when the monitor is disconnected?
Share this post
Link to post
Any luck?
Share this post
Link to post
Monitor currently in use is a 15" Apple Multiple Scan... Came originally with a Macintosh Color Display that still works, just on a different machine. I did try this monitor and no monitor... Same result. PRAM battery checks good too.
Share this post
Link to post
Noticed another thing... I let the machine run after I checked the voltages and noticed the processor was warm when I came back... I know the 040's ran warm, but this guy is doing nothing. Also, the num, caps and scroll lock lights flash when initially powered on... So the keyboard is posting.
Share this post
Link to post
Hmm, maybe it needs a re-recap haha... Maybe you should post a picture of your logic board...I'm sure the kind folks here would be willing to take a gander...
Share this post
Link to post
there is a cap that goo's up and rotts up legs/pads of a  TI-VLSI I/C over right next to the PDS slot, witch is unique for the C/Q 610 MB.
Ryan did you send him a price for your Capped working 610?
I was the one that re-capped this thing over a year ago.
pretty sure it has tantalums.
I remember this 610 because i had to tear apart my PM6100 to test it.
And it worked like a top.
i remember he got it back though, and then he said that it was dead just as it is now.
i told him that it worked great here and to maybe check the voltages at the psu.
then i never herd anything from him.
so i am under the assumption that something he did got it to work. and has been working all this time until recently.
Maybe, I did not clean the legs of that VLSI good enough with a tooth brush and acetone?
So maybe try that?  get a tooth brush and some acetone and be careful because those legs can bend over.
we don't need another ROLLERMANZ.......
but wet that whole area really good with the acetone, and lightly scrub, maybe carefully pat dry with some TP paper and then do it again.
Share this post
Link to post
How does 40 + 20 shipping sound? And I would like your old one please since I was planning on making a plexiglass case for my logic board... This Centris board is surprisingly snappy at 20 MHz...
Edited by 360alaska
Share this post
Link to post
It also occurred to me that a stuck reset / programming button might give these symptoms...
Stuck and dusty switches usually cause reboots, but it's worth a look. I'd try a RAM SIMM swap (not much that you can do with soldered RAM) and always unplug the floppy drive.
Share this post
Link to post
I never did try with the floppy drive disconnected... That never occurred to me. Yes, uniserver, you recapped the board - and did a beautiful job I might add... I do electrical work for a living and I hate soldering. Nothing ever turns out right - but the board never worked. I got caught up in a massive job change, two deaths in the family and a ton of other crap so I never investigated further nor did I respond to you. Truly unprofessional and unacceptable on my part.
I really want to get this board going somehow and it just seems like it's something really dumb from keeping it going.
I did check the interupt and reset switches... Both are good. I will also double check the VLSI and make sure it's clean.
Does the board you have have the full 040? I assume that's the 25mhz quadra board?
Share this post
Link to post
Nope, it's a 20mhz centris 610 board... The q610 board has a separate oscillator for the internal Ethernet card so it can run the processor at 25 MHz... At least it works though :)
Share this post
Link to post
sounds like a great price to me, does your c610 have AAUI ryan?  I know some versions completely omitted the SONIC networking chip as well.
Share this post
Link to post
I would like to have a crack and it, you can send PayPal to 360alaska @ gmail.com and you can take my board out when you get it and put yours and send it back, sound good? The board came from a centris I bought that was damaged in shipping, If I can fix your board I will be putting the bits into a custom plexiglass case...
Edited by 360alaska
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
