Jump to content
Macintosh PowerBook 145/160/170 battery replacement
  • Please log in to reply
71 replies to this topic
#61 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 05:36 PM
So, I had the machine booted up with the SCSI2SD last night, ran like a champ.
Didn't even come close to draining the battery before shutting down for the night.
Booted it up this morning, and it appears the battery has almost completely drained - anyone else see this behavior? I'd think there shouldn't be power drain while the system is shut off.
Macs: soon-to-be-tricked-out PB160 w/10MB RAM and custom battery. Upcoming upgrades: 66MHz crystal, SCSI2SD, wifi/ethernet access via DreamPi. Powerbook G4 5,4 w/1GB ram, dualboot OSX 10.5 and MorphOS. Mac Mini G4 1.25GHz running MorphOS. Core i5 Mac Mini slotloader that's eaten my damn Gunlord CD.
PCs: Too many, running too many things.
#62 zuctronic
zuctronic
  • 6502
  • LocationChicago
Posted 22 March 2017 - 05:41 PM
Maybe it's trying to charge a dead PRAM battery? I actually have a similar issue. I also wonder at what voltage level does it force sleep / shutdown. I have a rebuilt batpack with 10 cells in it and this new printed one with 5 cells and neither seem to last as long as I'd expect.
#63 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 05:44 PM
My first thought was PRAM battery. I'm running 6 in the printed pack (the system regulates battery output anyway) and while running last night I never saw the meter level drop at all.
I do need to swap the PRAM battery anyway, guess that'll be the next fix.
#64 zuctronic
zuctronic
  • 6502
  • LocationChicago
Posted 22 March 2017 - 05:48 PM
Hmm... I know I can fit 6 cells in there, but it seems a bit ill-advised - I don't know enough about the voltage regulator. Are you sure that won't burn anything out? I'm completely ignorant in this area, I'm just afraid of destroying something that's difficult to repair.
I have the opposite problem though, the voltage drops down to "two bars" very quickly and then hangs there for about an hour before it dies hard.
#65 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 05:59 PM
Well, the PSU itself is 7.5v/2A. The system doesn't run at that voltage/current, it's regulated down. Same for the "6v" from the stock battery. Battery voltage fluctuates enough that good regulation is required. Most can handle a decently wide range; not sure what the PB160's battery regulator maxes at, but I've had no ill effects other than the system overall getting slightly warm - not anywhere near as warm as my G4 gets, but you'd want to have this on your lap on a cold night.
I could install a switching DC-DC convertor to give it a steady 6V out, but the issue then is more wasted energy from the conversion as it's a two-step process now, when it could be done with just the one. My friendly engineer buddy assured me that 6 cells in the pack was rather safe.
Worst case, I'll pin down the regulator coming off the battery inputs, and work out a swap for something more efficient which would reduce heat *and* extend battery life slightly.
...heck that actually sounds like a good idea, might do that anyway.
#66 zuctronic
zuctronic
  • 6502
  • LocationChicago
Posted 22 March 2017 - 06:02 PM
Ah, your explanation makes perfect sense and makes me feel a lot more comfortable about using six cells. Did you also take the klixon from the original battery pack?
#67 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 06:05 PM
Nope, I'm actually just running straight battery. I had a fuse on it but then realized that the fuse itself actually shorted the back (which probably just blew immediately)
#68 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 06:10 PM
The protection really isn't as needed unless you're charging the cells from the PB itself, and right now I just charge them individually in the Eneloop's included charger.
#69 zuctronic
zuctronic
  • 6502
  • LocationChicago
Posted 22 March 2017 - 06:29 PM
I see. But also if the only way these PBs know the charge level is via the voltage output, it might not charge 6 cells properly or fully anyway - right?
#70 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 06:47 PM
Also probably true. Generally, I'm probably going to stick to external charging for the individual cells.
#71 Rajel
Rajel
  • 6502
Posted 22 March 2017 - 10:33 PM
And this is actually something of an issue with these rebuilt packs - NiMH cells hold voltage pretty well, the voltage drop is really slow for most of the runtime, and then it drops very sharply.
Basically, the metering is pretty much useless.
#72 Westinghouse
Westinghouse
  • 6502
  • LocationCanada
Posted 23 March 2017 - 06:22 PM
Techknight, I came across a mention of putting a resistor between two pins in another of your posts on the subject.
https://68kmla.org/f...crazy/?p=297998
Wondering if you remember which two pins?
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
