Jump to content
Video Adapter Docs Scan Dump
  • Please log in to reply
17 replies to this topic
#1 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
  • LocationBermuda Triangle, NC, USA
Posted 12 October 2011 - 02:52 AM
I've tried to collect some prime examples of Mac Video Adapters and Adapter Cables along with the Documentation for them over the past 20 years or so.
A question came up about a four DIP Switch adapter, this is the only similar adapter that I've found. The small pamphlet's pages were compiled using a photo copier back in the day, so pretty they ain't, but hopefully a bit helpful to my comrades.
MacVDO
[attachment=2]MacVDO-0.jpg[/attachment]
[attachment=1]MacVDO-1.jpg[/attachment]
[attachment=0]MacVDO-2.jpg[/attachment]
_______________________________________________________________________________________
More to follow:
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
#2 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 12 October 2011 - 06:18 PM
Here are scans of all the adapters that I had readily available in my Mac Video Drawer, I've got Documentation of most of them and Documentation for several that are scattered about on Macs hither, thither and yon. [;)]
[attachment=1]VGA_Adapters_Labels.jpg[/attachment]
Notice the DA-19 <-> DA-19 ENHANCE branded "Liberty Adapter," I haven't found a use for it yet, but it's pretty darn 8-)
[attachment=0]VGA_Adapters_Switches.jpg[/attachment]
I also have a handful of DB-15 <-> 3, 4 & 5 BNC Mac Cables.
My favorite is a 4 BNC <-> DB-15 that has a 4 DIP switch, Resolution Setting Dongle attached at the Mac end.
I did a few Docs scans while I was at it, but they need some work before they're ready to post.
jt [8]
#3 krye
krye
  • 6502
  • LocationNY, USA
Posted 27 July 2012 - 12:00 PM
Neat. I have the gray one on the top left.
Back in 2001 I took a networking course. The instructor said he had a 15" monitor he was going to toss and offered it to anyone who wanted it. I said I'd take it. He went and grabbed it out of his car. To my surprise it was an old Apple monitor with the adapter attached to the cable. I thought that was a pretty neat score.
IIe, //c, ///, 128K, 512K, Plus, SE, Portable, Classic, Color Classic, LCIII, LC520, Mac TV, Performa 460, 575, iMac G3, iMac G4, G4 Cube, Blueberry iBook, 14" G3 iBook, Lombard PowerBook, 12" PowerBook G4, 2008 Mac Pro, Mac Mini, 2013 Mac Pro
#4 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 03 September 2012 - 06:54 AM
ARGH!! Looks like I need to load the adapter images locally. The frog ate one. :-/
#5 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 20 February 2013 - 12:52 AM
Damn you, Frog! }:)
I have a Miro 6-switch that's not listed yet, including documentation. And i just bought a new one, not yet clear wich maker, but according to the description it has documentation as well:
http://www.ebay.de/itm/261170673685
Should arrive soon. Do you guys accept photographs instead of scans? Might even find a sheet of acrylic glass to properly flatten the documentation. The scanner is hidden under a heap of stuff. :I
German MLA cell. Liberated: Quadra 650 (NetBSD and AU/X), LC475, Performa 630, Centris 610, IIsi, 3x Classic
Contraband: 3x iMac Bondi Blue, a few Serial- and X-Terminals, a Sun SS4, stack of Thinkpads, a '92 Piaggio Sfera for proper transportation
#6 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 22 February 2013 - 02:27 PM
The one from ebay metioned earlier. If you are in europe and you need one, get it. It's cheap and worked instantly with my 19 inch HP 1955 TFT (Ebay, 20 Euros) and with a C610, Q650, LC475 running 7.5.5. I guess others should work too. Use the 21" Multisync setting in Mode 1, that way you can switch between resolutions using the monitor applet. While there, disable gamma correction, it's not needed.
[attachment=0]aesp-adapter.jpg[/attachment]
Finally. My 13" Mac CRT days are over! :approve:
Edit #1: Works also flawless with a modern LG Flatron IPS224 22" Full HD IPS TFT
#7 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 23 February 2013 - 10:59 AM
Another adapter, this time Miro branded. It sucks. I wish i hadn't payed 10 Euros for it.
[attachment=0]miro-adapter.jpg[/attachment]
Here is a quick table of what worked with a modern display, the LG Flatron IPS224 22" TFT, wich you can get for about 150 Euros at Amazon:
Miro MC2, MacOS 7.5.5, LG IPS224 TFT
Q650 C610 P475 IIsi
640 x 480 + -¹ - +
832 x 642 + + - -
1024 x 768 + + - -
1152 x 870 + + - -
Msync 640 - -² - +
Msync 832 - - - +³
Msync 1152 - -² - +³
+) Works!
-) Monitor stays blank, thinks no signal is there
¹) Monitor says out of Spec
²) Until MacOS starts, then it goes blank
³) 640 x 480 only
I also tested another display, a HP 1955 19" TFT, wich in it's documentation claims to support Mac modes 832x642 and 1152x870 and even a Sun mode. However, with this adapter it didn't work at all.
It works fine with another adapter and i can recommend the display. It's very cheap, you can get it used at Ebay for 20 Euros. The robust VESA-Stand (with pivot) is worth it alone. I only wish i had the 17" model, wich electronically is the same, but in a smaller display.
#8 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 24 February 2013 - 05:22 AM
Localized and fixed . . .
. . . what frog? [}:)]
http://allrecipes.co...ized-frog-legs/
#9 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 24 February 2013 - 12:53 PM
So the frog ate your image and then you ate the frog? Poetic justice. :approve:
Should we make a large matrix that lists makers of display/mac/adaptor and wich modes work? Like the small table i posted?
#10 olePigeon
olePigeon
  • 68LC040
Posted 28 February 2013 - 05:54 PM
Here's one for an adapter I got recently.
#11 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 28 February 2013 - 11:06 PM
Nice. :approve:
The construction and configuration looks exactly like the AESP Adapter. I wonder if all 10 switchers are really just all the same.
#12 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 04 March 2013 - 01:45 PM
Some more adapters and their documentation:
http://www.brix.de/c...ga-adapter.html
#13 Ike
Ike
  • 6502
  • LocationTilburg, The Netherlands
Posted 11 March 2013 - 12:23 AM
i have two Unimac Fly adapters with a single row of Dip switches, it really works on every mac i have with my dell something something 15" LCD panel. They all seem to do 60Hz 640x480 or sometimes 1024x768 when you tell the adapter to do so, even the ones with onboard video.
Compacts: ED (512Ke), Plus, Plus, SE HDD, Classic.
68K: IIci, Performa 400, Performa 450.
PPC: 7100/66 With G3 card, 4400/200 , 9600/200.
Fun stuff: PowerCD, eMate 300, Huge Wacom artpad A3 tablet.
#14 tecneeq
tecneeq
  • 6502
  • LocationGermany
Posted 11 March 2013 - 12:56 AM
Make pics, scan docs. :approve:
Posted Image
#15 NJRoadfan
NJRoadfan
  • 68000
Posted 10 July 2013 - 03:28 AM
Manuals for Belkin MacVGA adapters.
http://www.belkin.co...1381revised.pdf
http://cache-www.bel... ... itches.pdf
Belkin also made a HDI45 to VGA adapter for the Powermac x100 series using the dial and dipswitch style controls that the first F3H1381 manual shows.
#16 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 06 July 2014 - 03:19 PM
My attachments from the old forums software seem to be borken. Can they be fixed in the IP?
jt [8]
#17 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 23 November 2015 - 03:33 AM
Ran across the missing pics on imageshack, so here they are, other than the label side pic the frog ate.
Kind of silly to have a sticky topic without the original content. LOL! ::)
jt [8]
#18 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 30 July 2017 - 03:56 AM
FAX scanned these to myself from work. Dunno what happened, ICK! But they'll do. :-/
jt [8]
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
